Binomial Expansion - Fractional Powers
In summary, the Binomial Expansion only holds when n is an integer and when |x| is less than 1. If n is not an integer or if |x| is 1 or greater, the series diverges. This is because when n is an integer and |x| is less than 1, the numerator becomes zero after n+1 terms, allowing the series to converge.
Mathick
23
Hello!
We know from 'Binomial Expansion' that \(\displaystyle (1+x)^n=1+nx+\frac{n(n-1)}{2!}x^2+...\) for \(\displaystyle \left| x \right|<1 \). Why doesn't it work for other values of \(\displaystyle x\)? I can't understand this condition. I would be really grateful for clear explanation!
Mathematics news on Phys.org
Mathick said:
Hello!
when n is integer after n+1 terms the numerator becomes zero and so Binomial Expansion holds. for any x
but when n is not an integer there are infinite terms and if |x| is 1 or more then the series diverges and for |x| < 1 this converges as x^n tends to be zero.
FAQ: Binomial Expansion - Fractional Powers
What is binomial expansion in fractional powers?
Binomial expansion in fractional powers is a mathematical process used to expand binomial expressions raised to fractional powers. It involves using the binomial theorem to find the coefficients of each term in the expansion.
How do you expand a binomial expression raised to a fractional power?
To expand a binomial expression raised to a fractional power, you can use the binomial theorem, which states that (a + b)^n = ∑ (n choose k) * a^(n-k) * b^k, where n is the power and k is the term number. This formula allows you to find the coefficients of each term in the expansion.
What is the purpose of using binomial expansion in fractional powers?
The purpose of using binomial expansion in fractional powers is to simplify complex expressions and make them easier to solve. It also allows you to find the coefficients of each term in the expansion, which can be useful in further mathematical calculations.
Can binomial expansion be used with any fractional power?
Yes, binomial expansion can be used with any fractional power. However, the calculation can become more complex as the power increases, so it is important to use a calculator or computer program for larger powers.
What are some real-life applications of binomial expansion in fractional powers?
Binomial expansion in fractional powers is used in various fields such as economics, engineering, and physics. It can be used to model population growth, calculate probabilities in statistics, and solve electrical circuit problems, among others.
