MHB Binomial Experiments: Find Probability of x=5, x>=6, x<4
The discussion centers on calculating probabilities for a binomial experiment involving U.S. adults' trust in national newspapers. The correct values for the experiment are n=9, p=0.6, and q=0.4, with x representing the number of adults who trust the newspapers. The user initially confused the probability p with 0.63 but confirmed it should be 0.6 based on the problem statement. Calculations for the probabilities of exactly five, at least six, and less than four trusting adults can be done using the binomial probability formula or calculator functions. The user ultimately resolved their confusion regarding the values and methods needed for the calculations.
aprilryan
Hi all,
I'm a bit confused on this problem in my book.
"Specify the values of n, p, and q and list the possible values of the random variable x.
Sixty percent of U.S. adults trust national newspapers to present the news fairly and accurately. You randomly select nine U.S. adults. Find the probability that the number of U.S. adults who trust national newspapers to present the news fairly and accurately is (a) exactly five, (b) at least six, and (c) less than four."
I have the values.
n=9
p=.63
q=.37
x=5
x is at least six
x<4
Would I have to do them on the calculator using binomial pdf and sum commands or find the mean, standard deviation and variance?
Note: I have been shown to do these types of problems on the calculator using the binomial pdf and sum commands.
Mathematics news on Phys.org
aprilryan said:
Hi all,
I have the values.
n=9
p=.63
q=.37
x=5
x is at least six
x<4
Where does $p = 0.63$ comes from? I would say it should be $p=0.6$ according to the question.
Yes, it was .60. Thanks, I've got this one figured out!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
