Binomial Probability Clarification
In summary, the question is whether there are values of p (0≤p≤1) for which the variance of a binomial distribution with a fixed n is equal to 0. The answer is yes, but only when p=0 or p=1. This is because the variance of a binomial distribution is given by np(1-p) and when p=0 or p=1, the variance is equal to 0. The maximum variance for a binomial distribution occurs when p=1/2, which represents the maximum uncertainty in the outcomes. This can be seen by graphing the variance as a function of p, where it peaks at p=1/2.
exitwound
292
For fixed n, are there values of p (0≤p≤1) for which V(X) = 0? Explain why this is so.
For X~Bin(n,p), V(X)=np(1-p). So the only solutions for this equation are when p=0 or p=1. There are too many variables for me to keep track of and understand. Is p the probability of X occurring? And n is the number of trials in the experiment? If so, if the probability of X occurring is zero or one, how does that relate to variance of the outcomes of the experiments? I'm confused.
Can you explain roughly what variance means in words? And why p=0 and p=1 giving you zero variance makes perfect sense? Look up a nonmathematical definition of 'variance'.
Variance is the amount of...dispersion of results around a certain point. I don't know how p and V(X) are related other than the equation. I know p is the probability of {success} of ... something. I don't know what that something is though. Is it X? I'm totally confused on what all the symbols in Binomial Probability mean.
Ok, yes, p is the probability of "success". If you do n trials and p=0 how many times do you succeed? Same for p=1. Is there any 'dispersion of results'?
Say I roll a die and the probability of getting a 1 is 0%, (due to the die being weighted) which would mean that the probabiltity of not getting a 1 is 100%. If I do n, all of my results are 1, therefore the variance is 0. And if the probability of getting a 1 is 100%, then all results are 1, and again no variance. I didn't realize this until I wrote out this experiment actually, coincidentally forgetting that we're dealing with dichotomous experiments. Is it that easy?
Saying "dichotomous experiments" makes it sound hard. But, yes, it's that easy. If p=0 or p=1 then you know exactly what will happen. There is no dispersion. If p=(1/2) or anything else not 0 or 1 then you can get anywhere from 0 to n successes. There is dispersion and nonzero variance, just as the formula np(p-1) tells you.
The second half of the problem asks: When is V(X) maximized? If we take the derivative and set it equal to zero, we get 1-2p=0 which means p=.5 which says that the maximum variance occurs when p=.5. This is where I get confused.
If the expected value of the Binomial is E(X)=np, and the variance is V(X)=np(1-p), I am not quite sure I picture what's happening. When p=.5, what is actually going on?
You are doing the math part right. If p is high, you 'usually' succeed, if p is low you 'usually' don't. With p=0 and p=1 being extreme cases of that. Doesn't it make sense that p=(1/2) is the maximum uncertainty? Hence maximum variance? These are all just words. The fact is that V(1/2)=n/4 is the largest value of the variance you get for any value of p. Try p=1/4 or p=3/4. Don't you trust you own math?
I can "do" the math but I don't really understand it. When p=1/4, V(X)=n(1/4)(3/4)... when p=3/4, V(X)=n(3/4)(1/4)...which is the same. But I'm not really able to 'picture' what the variance is doing. For instance, if my possibilities of outcomes is 0 or 1, and the probability of getting the 1 is (1/4), why is the variance around the expected value any different than if it's 1/2, or 3/5, if the only two outcomes are 0 and 1?
Because 3n/8 is less than n/4. That's why. Graph V as a function of p. It peaks at p=1/2 doesn't it? Look up web apps that will show you graphs of binomial distributions for various values of n and p if you can't 'picture' it. For fixed n the value of p that gives you the biggest spread in outcomes is p=1/2.
FAQ: Binomial Probability Clarification
What is binomial probability and how is it different from other types of probability?
Binomial probability is a statistical measure that calculates the likelihood of a specific number of successes in a fixed number of independent trials, where each trial has two possible outcomes (success or failure). It differs from other types of probability, such as continuous or normal probability, which deal with continuous variables and have an infinite number of possible outcomes.
How is binomial probability calculated?
Binomial probability is calculated using the formula P(x) = nCx * p^x * q^(n-x), where n is the number of trials, x is the number of successes, p is the probability of success, and q is the probability of failure (q = 1 - p). This formula takes into account the number of ways a specific number of successes can occur in a given number of trials, as well as the individual probabilities of success and failure.
What is the significance of the binomial probability distribution?
The binomial probability distribution is significant because it allows us to make predictions about the likelihood of a certain number of successes in a series of independent trials. This is particularly useful in fields such as genetics, where we can use binomial probability to predict the probability of inheriting a specific trait.
Can binomial probability be used in real-life situations?
Yes, binomial probability can be used in real-life situations to make predictions and analyze data. For example, it can be used to predict the probability of a certain number of people in a population having a specific disease, or the likelihood of a certain number of customers purchasing a product.
How can I apply binomial probability in my research or experiments?
Binomial probability can be applied in research and experiments by using it to calculate the likelihood of obtaining a certain number of successes or failures in a fixed number of trials. This can help in determining the significance of results and making conclusions based on the data gathered. It is important to ensure that the conditions for using binomial probability are met, such as having independent trials and only two possible outcomes for each trial.
