Biology: Solutions equilibrium
In summary: Since the membrane is permeable to both NaCl and glucose, the concentrations of NaCl and glucose on either side of the membrane will equilibrate. This will cause no osmotic pressure, meaning the level of glucose in side A will stay the same despite a decrease in the level of NaCl. The water level in side A will decrease because the solution is becoming less dense due to the presence of more glucose.
future_vet
169
The solutions in the arms of a U-tube are separated at the bottom of the tube by a differentially permeable membrane. The membrane is permeable to sodium chloride but not to glucose. Side A is filled with a solution of 0.4 molar glucose and 0.5 molar sodium chloride (NaCl) and side B is filled with a solution containing 0.8 molar glucose and 0.4 molar sodium chloride. Initially the volume in both arms is the same. If you examine side A after three days, you should find...?
The solution is: a decrease in the concentration of NaCl, an increase in the concentration of glucose and a decrease in the water level.
However, since the membrane is not permeable to glucose, why does the glucose level change? Why does the water level decrease?
Thanks!
You didn't mention which arm of the U tube would see a decrease in level.
I would think that since the membrane is permeable to NaCl that the concentration of NaCl in both sides of the U tube would equilibrate and there would be no osmotic pressure from that component. The glucose side would exert an osmotic pressure since it cannot cross the membrane but it is not clear, from the answer you gave, if the glucose side would see an increase in level or a decrease in level. You can figure that out, I'm sure.
All the changes are in side A..
You have either changes of the solution level on both sides or on none. This is simple mass preservation.
Let's try backing up a step in the thought process and see if these questions help you answer the above questions. Besides NaCl, what else in the tube can move through the membrane? And, how does that "other" substance moving through the membrane change if concentrations of either NaCl or glucose differ on either side of the membrane?
FAQ: Biology: Solutions equilibrium
What is solutions equilibrium in biology?
Solutions equilibrium in biology is the state in which the concentration of solutes in a solution is balanced and there is no net movement of particles between the solution and its surroundings.
How is solutions equilibrium maintained in biological systems?
Solutions equilibrium in biological systems is maintained through various processes such as diffusion, osmosis, and active transport. These processes help to regulate the concentration of solutes and maintain equilibrium.
What factors can disrupt solutions equilibrium in biology?
Factors such as changes in temperature, pressure, or the addition or removal of solutes can disrupt solutions equilibrium in biology. Enzymes and cellular structures also play a role in maintaining equilibrium and can be disrupted by external factors.
How does solutions equilibrium relate to homeostasis in living organisms?
Solutions equilibrium plays a crucial role in maintaining homeostasis in living organisms. Homeostasis is the process of maintaining a stable internal environment, and solutions equilibrium helps to regulate the concentrations of substances within the body to keep it in balance.
Can solutions equilibrium be achieved in a non-living system?
Yes, solutions equilibrium can be achieved in a non-living system, such as a beaker of saltwater. However, in living systems, solutions equilibrium is constantly being disrupted and restored in order to maintain homeostasis.
