Birefringence deviation angle?
In summary, according to this conversation, the deviation angle of the extraordinary ray is dependent on the angle and the geometry of the setup.
spareine
129
39
The best known effect of birefringence is the lateral displacement of the extraordinary image. Why is this effect rarely quantified? I couldn't find a table of materials specifying the deviation angle δ of the extraordinary ray (say, for an angle of incidence equal to zero). Birefringence seems to be quantified exclusively by Δn = ne-no, and δ cannot be derived from Δn.
Well, for normal incidence there is no deviation so what will be the point to make tables with a bunch of zeros? :smile:
The deviation depends on the angle and the geometry of the setup. You have to calculate it itself for your specific problem.
The birefringence value (Δn) allows you to do it.
Well, for normal incidence the extraordinary ray does have a deviation. That's why it is extraordinary, it doesn't obey Snell's law, in contrast to the ordinary ray. If you happen to have a calcite crystal you could see it with your own eyes. It is also mentioned in many places, for example Wikipedia: "So even in the case of normal incidence, where the angle of refraction is zero (according to Snell's law, regardless of effective index of refraction), the energy of the extraordinary ray may be propagated at an angle." (click)
I know there are tables for those two refractive indices. However, again, if a laser beam enters a calcite crystal, at an angle of incidence equal to zero, it is still split into two rays. The ordinary ray travels along the normal. The extraordinary ray travels at angle δ with the normal. You cannot explain that lateral deviation by any value of ne and no.
You can, provided you also know the relative orientation of the crystal axis to the surface of the material on which your laser is shone. The theory has long been developed, which can be found in almost any photonics textbook.
Yes, you are right.
blue_leaf77 said:
... can be found in almost any photonics textbook.
Maybe someone knows a simple equation for the lateral displacement without a photonics book?
Again, you need to know the crystal's optic axis orientation with respect to the incoming ray. For an arrangement such that the input plane is parallel to the so-called principal plane of the (uniaxial) crystal (like the one in the picture below), one can prove that the deviation angle ##\theta_s## between e- and o-rays is given by
\cos \theta_s = \left( \frac{\cos^2\alpha}{n_o^2} + \frac{\sin^2\alpha}{n_e^2} \right) \left( \frac{\cos^2\alpha}{n_o^4} + \frac{\sin^2\alpha}{n_e^4} \right)^{-1/2}
where ##\alpha## is the angle subtended by the incoming ray and optic axis. If you want to know more about how optics axis direction is defined in commercial crystals I suggest that you look up the section for Birefringence in "Optics" by Eugene Hecht.
Related to Birefringence deviation angle?
1. What is birefringence deviation angle?
Birefringence deviation angle, also known as the angle of deviation, is the angle between the original direction of a light ray and its direction after passing through a birefringent material. This phenomenon occurs when light travels through a material with two different refractive indices, causing the light to split into two polarized rays with different velocities and directions.
2. How is birefringence deviation angle calculated?
The birefringence deviation angle can be calculated using the equation θ = arctan[(nt-n0)/d], where θ is the deviation angle, nt is the refractive index of the transmitted ray, n0 is the refractive index of the incident ray, and d is the thickness of the birefringent material. This equation is based on Snell's law and assumes that the two refractive indices are perpendicular to each other.
3. What factors affect the birefringence deviation angle?
The birefringence deviation angle is affected by the thickness and refractive indices of the birefringent material, as well as the wavelength and polarization state of the incident light. Additionally, any external stress or strain on the material can also change the birefringence deviation angle.
4. What are the applications of birefringence deviation angle?
Birefringence deviation angle has various applications in optics and materials science. It is commonly used in the manufacturing of optical components, such as polarizers and waveplates, for controlling the polarization of light. It is also used in stress analysis of materials and in the study of liquid crystals.
5. How is birefringence deviation angle measured?
The birefringence deviation angle can be measured using various optical techniques, such as polarimetry, ellipsometry, and interferometry. These methods involve analyzing the polarization and phase changes of light passing through a birefringent material. Advanced techniques, such as spectroscopic imaging polarimetry, can also be used to measure the birefringence deviation angle with high precision and accuracy.
  • Classical Physics
  • Other Physics Topics
