Bismuth sulphide structural diagram
In summary, the conversation discusses the structural diagram of Bismuth(III) Sulphide and the number of electrons needed to form bonds. It is suggested that the structure should have two singly-charged species and a compact shape, rather than multiple charged atoms in a linear structure. It is also important to determine the charges on each atom in order to accurately construct the diagram.
PhysicBeginner
35
Can anyone tell me if the structural diagarm of Bismuth(III) Sulphide looks like this:
S-S-S
l l
Bi = Bi
They want to have a total of 40 electrons.
They have a total of 28.
That leaves a difference of 12 e-, divide by 2e- per bond, meaning there are going to be 6 bonds.
The structural diagram would look like this (i think).
That's a good attempt, rocketboy...but I don't think it's the right structure. For one thing, it creates too many charged species (with the central S-atom having to accommodate a 2+ charge)
I can think of a structure that requires only two singly-charged species.
PhysicsBeginner : It's an important part of the process that you figure out the charges on the different atoms. To do this, you must also determine the number of non-bonding electrons on each atom.
The failure of your structure lies in the following :
1. It requires 4 charged atoms (and it requires an S to hold a positive charge and a Bi to hold a negative charge; both of which are against their tendencies)
2. It proposes a long, linear molecule, which is energetically less favorable than a more compact structure, like the one suggested by rocketboy.
3. There's a structure that is more compact still, and yet has only 2 charged species (an S- and a Bi+).
Related to Bismuth sulphide structural diagram
1. What is the chemical formula for bismuth sulphide?
The chemical formula for bismuth sulphide is Bi2S3.
2. How is the structural diagram of bismuth sulphide represented?
The structural diagram of bismuth sulphide is typically represented using a ball-and-stick model or a space-filling model, which show the arrangement of atoms and the bonds between them.
3. What is the crystal structure of bismuth sulphide?
The crystal structure of bismuth sulphide is orthorhombic, meaning it has three axes of different lengths that intersect at right angles.
4. What are the properties of bismuth sulphide?
Bismuth sulphide is a black or gray solid with a metallic luster. It is insoluble in water but can be dissolved in acids. It has a high melting point and is a semiconductor, meaning it can conduct electricity under certain conditions.
5. What are the applications of bismuth sulphide?
Bismuth sulphide has various applications in industries such as cosmetics, electronics, and optoelectronics. It is used as a pigment in makeup products, a component in solar cells, and a semiconductor material in electronic devices.
  • Atomic and Condensed Matter
  • Linear and Abstract Algebra
