Bivariate distribution question
  • MHB
  • Thread starter Longines
  • Tags
    Distribution
In summary, the conversation was about how to solve a question involving integration from -infinity to +infinity. The participants discussed different methods and eventually found the solution by completing the square. They also mentioned finding $f_Y(y)$ and $\mathbb E[XY]$ as possible next steps.
Longines
Hello all,
How would I do this question by hand?
I know I integrate from -infinity to +infinity for $f_x,y$, but I have no idea how to do it by hand! My algebra soup is bad, can someone please help me?
View attachment 3237P.S I heard some of my friends talking about some 'trick' you can do with the exponential part of the equation to solve it quicker.. but I don't know what they were talking about.
Thank you
Hi there,
Usually with integrals in this form where you are integrating from $-\infty$ to $\infty$ I can find a way to do it by converting to polar coordinates, however I haven't found that yet. I think some users here might be able to see the proper substitution though - ZaidAlyafey, mathbalarka, MarkFL and ILS are all very skilled in integration. :)
I'll post back if I think of it and hope you get some more input soon.
Longines said:
Hello all,
Thank you
Hi Longines,
Let's start with $f_X(x)$.
$$f_X(x) = \int_{-\infty}^\infty f_{X,Y}(x,y)dy
=\int_{-\infty}^\infty \frac{1}{\pi\sqrt 2}\cdot e^{-x^2-\sqrt 2 xy-y^2}dy \tag 1
Complete the square:
$$-x^2-\sqrt 2 xy-y^2 = -(y+\frac 12 \sqrt 2 x)^2-\frac 12 x^2 \tag 2
Substitute (2) in (1):
$$f_X(x) = \int_{-\infty}^\infty \frac{1}{\pi\sqrt 2}\cdot e^{-(y+\frac 12 \sqrt 2 x)^2-\frac 12 x^2}dy
= \frac{e^{-\frac 12 x^2}}{\pi\sqrt 2}\int_{-\infty}^\infty e^{-(y+\frac 12 \sqrt 2 x)^2}dy
Substitute $u=y+\frac 12 \sqrt 2 x$:
$$f_X(x)
= \frac{e^{-\frac 12 x^2}}{\pi\sqrt 2}\int_{-\infty}^\infty e^{-u^2}du
= \frac{e^{-\frac 12 x^2}}{\pi\sqrt 2} \cdot \sqrt \pi
= \frac{e^{-\frac 12 x^2}}{\sqrt{2\pi}}
What do you think $f_Y(y)$ is? (Wondering)@Jameson: Sorry, no trick with polar coordinates. ;)
Hutchoo said:
Wow, thank you so much for this! This was exactly what I was looking for. I think the reason why I couldn't do it was because I didn't think of completing the square which is what's needed to solve the question.
Thank you!
Good!
Were you also able to find $f_Y(y)$ and $\mathbb E[XY]$?
for reaching out with your question. Bivariate distribution questions can be solved by hand using techniques from multivariate calculus and algebra. The first step is to determine the joint probability density function (PDF) of the two variables, denoted as $f_{x,y}$. This can be done by integrating the joint PDF over the entire range of both variables, in this case from -infinity to +infinity. This will give you the marginal distribution of each variable.
Next, you can use the joint PDF to calculate the correlation coefficient, which measures the strength and direction of the relationship between the two variables. This can be done by finding the covariance of the two variables and dividing it by the product of their standard deviations.
As for the "trick" your friends mentioned, it is possible they were referring to using the properties of the exponential function to simplify the calculations. However, it is important to have a solid understanding of the underlying concepts and equations before attempting any shortcuts.
I suggest reviewing the fundamentals of bivariate distributions and seeking help from a mathematics tutor or online resources if needed. With practice and patience, you will be able to solve bivariate distribution questions by hand. Good luck!
FAQ: Bivariate distribution question
What is a bivariate distribution?
A bivariate distribution is a statistical concept that describes the relationship between two variables. It shows how the values of one variable are related to the values of another variable.
How is a bivariate distribution represented?
A bivariate distribution is often represented using a scatter plot or a 2D graph. The x-axis represents one variable and the y-axis represents the other variable. Each data point on the graph shows the value of both variables for that specific observation.
What is the purpose of studying bivariate distributions?
Studying bivariate distributions allows us to understand the relationship between two variables and how changes in one variable affect the other. This can help us make predictions and identify patterns in data.
What are some common types of bivariate distributions?
Some common types of bivariate distributions include linear, nonlinear, and multivariate distributions. Linear distributions show a linear relationship between the two variables, while nonlinear distributions show a non-linear relationship. Multivariate distributions involve more than two variables and show how they are all related.
How is the strength of the relationship between two variables measured in a bivariate distribution?
The strength of the relationship between two variables in a bivariate distribution is measured using a correlation coefficient. This number ranges from -1 to 1 and indicates the strength and direction of the relationship. A correlation coefficient of 0 indicates no relationship, while a coefficient of 1 or -1 indicates a perfect positive or negative relationship, respectively.
