MHB Bivariate tests with dummy variables
  • Thread starter Thread starter Cookie G
    Variables
Bivariate tests can be conducted using dummy variables, which represent categorical data in a binary format. While dummy variables simplify analysis, they may lose some information from the original variables. Pairwise correlations can be performed by comparing combinations of dummy variables, such as geographic regions with different poverty levels. The discussion highlights a concern about the adequacy of information retained when using dummy variables for bivariate tests. Understanding the limitations and methods of analysis with dummy variables is crucial for accurate interpretation of results.
Cookie G
I'm not sure if this belongs in the Basic area or here.
I have a dataset with variables that I think it makes sense to make them into dummy variables (some are categories, some are ordinal). I've been asked to do bivariate tests and regression. I don't understand how I can do bivariate tests when I'm using dummy variables.
Thanks
I guess I just use the dummy variables for the bivariate tests. It just seems less than ideal because in a sense one dummy variable has less information than the original variable.
For example, if I have geographic region and poverty level, I could do pairwise correlations. region 1 with pov level 1, region 1 with pov level 2, region 1 with pov level 3, region 2 with pov level 1, etc.
I've not been able to figure out any other way to do this. Please let me know if I'm missing something.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
