Bizarre Electrical Engineering Project....is it possible?
In summary: I don't think this would work, it would just produce a continuous flow of electrons instead of a sphere.
bodykey
46
Ok, I've got a project I want to try, mostly for the "why the heck not?" idea, just for the giggles, you know? I just want to see if it's even possible to do. Here's the goal:
Goal: Create a complete and uninterrupted sphere of electricity.
This isn't as easy as one might think. It doesn't "have" to be a sphere, I just figure a sphere would be the easier to do this with. The key thing here to note is that I'm not concerned with the efficiency at which electricity is produced nor am I concerned with what happens to the electricity after it's produced. I ONLY care about covering the surface area of the object ENTIRELY in electricity to the point that there is no point AT ALL left naked and free of electrons.
Now I understand that electricity works kind of like water in that it flows and it must have a loop in order to operate. The other thing to note is that the sphere would have to pretty much levitate (because it can't touch anything, otherwise the sphere wouldn't create a complete sphere of electricity, it'd have a "hole" in the sphere...it MUST be complete)
With that brings several questions. Does the ball have to generate the electricity by rotating along a magnet? Would you use magnets to actually rotate it with a motor on either side (the motor rotates and magnets close to but not touching the sphere causes the sphere to rotate, which produces electricity)...
I'm not an electrical engineer, but this is something I've literally thought of since childhood and I've always wondered...is it possible?
Given an unlimited budget, could this actually be done, and if so, how?
Thanks everyone, I look forward to your interesting responses.
BodyKey
Google ball lightning
What you describe sounds like ball lightning:
https://en.wikipedia.org/wiki/Ball_lightning
Check out the explanations and experiments section.
EDIT Seems I was beaten to the punch by anorlunda.
Hmmmmmm that is interesting. I've literally been researching this for years and that itself never came up. I wonder if this has ever been purposefully manufactured? o_O
I don't think anyone knows how to do that, and even reports of natural ball lightning often are dubious.
Ah, I should've read billy_joule's post more closely, apparently there have been apparent experiments done, but as you said rootone, none have really been successful at it.
Why exactly would you think this would be so hard to do and based on that, what specific hurdles would one have to overcome to actually achieve this or something like it?
It's not clear to me exactly what you mean by "electricity".
(1) Do you want a sphere which has a uniform charge on its surface so that there is an excess of electrons everywhere? If so, this is pretty easy, Just take a conducting sphere, and charge it up. Then there will be a uniform charge everywhere on the surface.
(2) Or do you want a current flowing everywhere on the surface of the sphere? If so, this is not possible. There is a mathematical theorem called Schur's lemma that guarantees that there will be at least one point on the sphere where the current is zero. It's the same as trying to imagine that the wind is blowing everywhere on the surface of the Earth. It is not possible, there must be at least one point where the wind velocity is zero.
Does this mean then that reports of naturally occurring ball lightning just have to be discounted as some kind of illusion?
I do suspect that.
and this
FAQ: Bizarre Electrical Engineering Project....is it possible?
1. Can electricity be generated from unconventional sources?
Yes, electricity can be generated from unconventional sources such as human body heat, plant energy, and even bacteria. These sources may not produce as much electricity as traditional methods, but they are still viable options for sustainable energy production.
2. Is it possible to create a device that can wirelessly transmit electricity?
Yes, wireless electricity transfer is possible through the use of electromagnetic fields. This technology is being developed and has the potential to revolutionize the way we use and distribute electricity.
3. Can electrical signals be used to control human behavior?
No, there is no scientific evidence to suggest that electrical signals can be used to control human behavior. While the brain and nervous system use electrical impulses to communicate, these signals do not have the power to control our thoughts or actions.
4. Is it feasible to create an electrical device that can manipulate time?
At this time, there is no known way to manipulate time using electricity. The concept of time manipulation is still theoretical and requires further scientific advancements before it can be considered a possibility.
5. Can electricity be used to create force fields?
While electricity can be used to create electromagnetic fields, which can have a repulsive force, it is not possible to create a force field in the way that is portrayed in science fiction. Force fields would require a much more advanced understanding and manipulation of physics than we currently have.
