Black Body and the colored objects around us
In summary, blackbody theory is an explanation for the color of objects in the world. The sun is a good example because it emits radiation across all wavelengths, including the invisible infrared spectrum.
fog37
1,568
108
Hello Forum,
A quick discussion about blackbody theory. As a premise, this is what I know:
A blackbody is an ideal body that absorbs all types of radiation incident on it, no matter its wavelength. Once absorbed, the energy is used to increase the blackbody's temperature and when the temperature is nonzero, the blackbody will also start emitting a portion of that same radiation (energy) that it previously absorbed. The emitted energy is distributed over all wavelengths (the emission spectrum depends on the temperature ##T##).
  • When steady-state is reached, the rate of energy absorption is perfectly matched by the rate of energy emission and the temperature stops increasing and remains fixed. Is it possible to know how much of the absorbed energy goes into raising the blackbody's temperature ##T## and how much of the absorbed energy becomes emitted radiation before steady-state is reached? For example, at steady-state, if the absorbed power is 100W, the emitted power would be also 100W. But before reaching steady-state, if the absorbed power is 100W, the emitted power may be just 30W and the remaining 70W should solely go, I believe, into increasing the temperature (i.e. average kinetic energy of the composing molecules). What happens to the molecules and their average kinetic energy when steady-state is reached?
  • Ordinary objects have a certain color because they absorb sunlight energy of all wavelengths except for the energy at the wavelength that corresponds to their color which gets instead reflected. Does that mean that ordinary colored objects are far from being blackbodies and are far from following blackbody theory? Which objects resemble blackbodies or greybodies? The sun is yellowish but seems to be a good example of a blackbody...
Thanks!
The sun emits radiation because of the nuclear reactions taking place, releasing energy.
It's been awhile since I studied this, but ordinary colored objects should behave much differently than a blackbody.
Well, as a follow-up to my own question, I think there are always the following three processes involved when an opaque object (not transparent, so no transmission) has radiation falling on it:
a) Absorption
b) Reflection
c) Emission
Ideal blackbodies don't reflect any energy at all. They only absorb and emit. But teal life objects that have color do absorb, reflect and emit radiation when some radiation is incident on them. Example: a red apple in sunlight. The apple reflects energy at about 650nm (red color) and absorbs all the energy at the remaining wavelengths. Because of this absorbed energy, the apple's temperature is raised and at steady-state the energy is emitted with a peak wavelength in the emission spectrum that is in the infrared (not visible to the human eye)...Does that sound correct?
The apple's temperature is not due to absorbed energy in sunlight only but also to the energy absorbed by other objects (air, etc.). Is that correct?
Yes the apple can receive direct radiation of heat from the sunlight, as well as from the air molecules (Convection, I believe), and the table or other object that it is resting on (Conduction)
Generally yes. But there is a certain energy density/ wavelength-temperature (or frequency-temperature) distribution that is followed (in equilibrium) [see ahead (cf. 'Planck's law [of black body radiation]')].
Model for 'black body' serves a small opening (or hole) in a cavity, which follows Planck's law (see also section "Derivation" and the quote:)
"Consider a cube of side L with conducting walls filled with electromagnetic radiation in thermal equilibrium at temperature T. If there is a small hole in one of the walls, the radiation emitted from the hole will be characteristic of a perfect black body. We will first calculate the spectral energy density within the cavity and then determine the spectral radiance of the emitted radiation."
The sun is just a 4π (solid angle) opening (or cavity) [taken as integral], that's why it's considered a black body ! ...
I hope that helps.
[P.S. looking at the proof (of a theory etc.) I think always helps to understand it better.
Note: your other (i.e. 1st) question is a non-equilibrium question and the answer I think depends on the system, but it is not generally described via black body theory.]
I wish the OP came back to tell us what he thinks ...
So sorry, my apologies. I had too much homework to do.
I am now comfortable with the idea that a blackbody is a perfect absorber ( in the sense that it absorbs all the energy that is incident on it). The absorbed energy will eventually be emitted but not necessarily in the same spectral region in which it was absorbed which means that the absorption coefficient at wavelength ##\lambda## will not be necessarily equal to the emission coefficient at the same wavelength ##\lambda##, correct? However, Kirchhoff's law states that the two coefficients are equal at every wavelength for a blackbody...where is the problem?
fog37 said:
The absorbed energy will eventually be emitted but not necessarily in the same spectral region in which it was absorbed which means that the absorption coefficient at wavelength λ will not be necessarily equal to the emission coefficient at the same wavelength λ, correct?
No. As you said next, Kirchhoff's law says that the coefficients are equal. But that doesn't mean the absorption and emission brightnesses are equal, since the temperatures of the body and incoming radiation are not necessarily equal. If the body is colder than the light source, the object will absorb light and preferentially reradiate at higher wavelengths due to the T^4 term.
The Sun is a pretty good black body because it is really big (and therefore rather opaque) and has many degrees of freedom. The mean free path for photons in the upper solar atmosphere is small compared to the length scale of the atmosphere. Photons will continually scatter between various particles (mostly electrons and protons), picking up random Doppler shifts with each collision.
Related to Black Body and the colored objects around us
1. What is a black body?
A black body is an idealized object that absorbs all electromagnetic radiation that falls on it. It does not reflect or transmit any light, making it appear completely black.
2. Why do black bodies appear black?
Black bodies appear black because they absorb all light that falls on them, regardless of the wavelength or color. This means that no light is reflected or transmitted, giving the appearance of a black object.
3. Why do objects around us have different colors?
Objects around us have different colors because they reflect and absorb light differently. A red object appears red because it reflects red light and absorbs other colors. A blue object appears blue because it reflects blue light and absorbs other colors.
4. Can colored objects also be black bodies?
Yes, colored objects can also act as black bodies if they have a high enough absorption of light. For example, a black car may appear black because it absorbs most of the light that falls on it, but it can still absorb and emit other wavelengths of light.
5. How do black bodies affect temperature?
Black bodies play a crucial role in determining temperature, as they absorb and emit radiation. The temperature of a black body is directly related to the amount of radiation it emits, with hotter objects emitting more radiation. This concept is used in various fields, including astronomy and thermodynamics.
  • Other Physics Topics
16K
  • Atomic and Condensed Matter
26K
  • Astronomy and Astrophysics
