Black body radiation, Planck's law, derivation
In summary,Planck's law states that the spectral radiance of a black body is described by the Planck formula. Equation One derives this from the Stefan-Boltzmann Law. Equation Two derives this from the energy density of radiation per unit frequency interval. Equation Three derives this from the power radiated per unit area.
Max Loo Pin Mok
The following are 3 equations of Planck's law or Planck's distribution function. Are they all correct? How do they derive from each other?
Equation One:
From page 512 of http://metronu.ulb.ac.be/npauly/art_2014_2015/shockley_1961.pdf
We denote by Qs the number of quanta of frequency greater than vg incident per unit area per unit time for black-body radiation of temperature Ts. For later purposes we shall also introduce the symbol Qs(vg, Ts) in order to be able to represent situations for different values of the limiting frequency.
Equation Two:
From page 1 of https://edisciplinas.usp.br/pluginfile.php/48089/course/section/16461/qsp_chapter10-plank.pdf
Energy density of radiation per unit frequency interval u(v) for black-body radiation is described by the Planck formula:
Equation Three:
From https://en.wikipedia.org/wiki/Planck's_law
The spectral radiance of a body, Bv, describes the amount of energy it gives off as radiation of different frequencies. It is measured in terms of the power emitted per unit area of the body, per unit solid angle that the radiation is measured over, per unit frequency. The SI unit of spectral radiance in frequency is the watt per steradian per square metre per hertz (W·sr-1·m-2·Hz-1).
Likes dextercioby and Charles Link
Science news on Phys.org
Edit: Give this one an A+ for a very good question. This is one that requires a careful look at a couple of quantities. ## \\ ##See https://www.physicsforums.com/threa...-density-of-a-black-body.956343/#post-6063569 ## \\ ## See also: https://www.physicsforums.com/threa...erivation-of-plancks-law.958747/#post-6079472 ## \\ ## Both of these previous discussions might help answer your question. ## \\ ## I haven't checked every factor of ## 2 ## and ## \pi ## in the 3 equations you posted, but yes, these 3 quantities are all connected. The first "link" shows how to get from the second relation to the 3rd, with a factor of ## \frac{c}{4} ##. ## \\ ## Going from the second relation to the 3rd, it also gets divided by ## \pi ##. That is because a blackbody radiates as ## I(\theta, \phi)=I_o \cos{\theta} ##, where ## I ## is the intensity in watts/steradian, and ## I_o ## is the on-axis intensity. (This is because an ideal blackbody looks equally bright when viewed from an angle, but the observed area is ## A \cos{\theta} ##, e.g. when a circular area is observed at an angle it appears elliptical with the area reduced by the factor of ## \cos{\theta} ## ). ## \\ ## The radiated power over a hemisphere is ## P=\int\limits_{0}^{2 \pi} \int\limits_{0}^{\frac{\pi}{2}} I(\theta, \phi) \sin{\theta} \, d \theta \, d \phi=I_o \pi ##. ## \\ ## (Notice for a blackbody radiating over a hemisphere, because of the ## \cos{\theta} ## factor, the effective solid angle over which the power ## P ## is radiated is ## \pi ## steradians rather than ## 2 \pi ## steradians. This is shown by the equation ## P=I_o \pi ## ). ## \\ ## Meanwhile the brightness ## B ##, which also is often indicated with the letter ## L ##, satisfies ## P=I_o \pi=LA \pi ##, so that ## L=B=\frac{P}{A \pi} ##. Thereby the division by ## \pi ## along with the ## \frac{c}{4} ## factor in going from the 2nd to the 3rd expression. ## \\ ## .............................. ## \\ ## Another useful quantity, designated by ## M ## is the power radiated per unit area. ## M=L \pi =B \pi ##. ## \\ ## ## \int\limits_{0}^{+\infty} M_{\nu}(\nu, T) \, d \nu=\sigma T^4 ##, which is the Stefan-Boltzmann Law. ## \\ ## To get ## M_{\nu}(\nu,T) ## from the ## u_{\nu}(\nu,T) ## of the second expression, you only need to multiply by the above factor of ## \frac{c}{4} ## that is derived in the first "link". ## \\ ## It can be shown that ## \sigma= \frac{\pi^2}{60} \frac{k_b^4}{\hbar^3 c^2} ##, because the ## \int\limits_{0}^{+\infty} M_{\nu}(\nu,T) \, d \nu ## integral, although a difficult one, can be evaluated in closed form. ## \\ ## From this, you should be able to see that ## \int\limits_{0}^{+\infty} B_{\nu}(\nu,T) \, d \nu=\frac{\sigma T^4}{\pi} ##. ## \\ ## .............................. ## \\ ## To get the first expression, you basically take ## M_{\nu}(\nu, T) ## and divide by the photon energy ## h \nu ## to get the number of photons ## Q_{\nu}(\nu, T) ## that are radiated. The reason for the limits that they chose for this integral should be quite obvious. ## \\ ## .............................. ## \\ ## Additional comment: Most textbooks are not complete enough in their treatment of the Planck function to address the subject of this post. They may give ## u_{\nu}(\nu,T) ##, or they may give ## B_{\nu}(\nu,T) ## or ## M_{\nu}(\nu, T) ##, but most of them do not properly tie these all together.
Likes Max Loo Pin Mok and dextercioby
Thanks for your reply. I'll work on this again after I've covered some other areas.
Likes Charles Link
Related to Black body radiation, Planck's law, derivation
1. What is black body radiation?
Black body radiation refers to the electromagnetic radiation emitted by a perfect absorber and emitter of energy, also known as a black body. A black body is an idealized object that absorbs all radiation that falls on it and emits radiation at all wavelengths.
2. What is Planck's law?
Planck's law, also known as the Planck radiation law, is a mathematical equation that describes the spectral energy density of black body radiation at a given temperature. It was developed by German physicist Max Planck in 1900 and is considered one of the foundational principles of quantum mechanics.
3. How is Planck's law derived?
Planck's law is derived from a combination of classical thermodynamics and quantum mechanics. It involves using statistical mechanics to describe the energy distribution of a large number of oscillators, and then applying the principles of quantum mechanics to obtain a continuous function that accurately describes the spectral energy density of black body radiation.
4. Why is Planck's law important?
Planck's law is important because it provides a theoretical foundation for understanding the properties of black body radiation, which is essential for many areas of physics and engineering. It also played a crucial role in the development of quantum mechanics and helped to resolve the ultraviolet catastrophe problem in classical physics.
5. How is Planck's law used in practical applications?
Planck's law is used in a variety of practical applications, such as in the design of light bulbs and other lighting sources, as well as in thermal imaging and remote sensing technologies. It is also used in astrophysics to study the radiation emitted by stars and other celestial objects, and in climate science to study the Earth's energy balance.
  • Quantum Physics
  • Quantum Physics
  • Thermodynamics
  • Quantum Physics
  • Quantum Physics
