B Black hole evaporation mechanism
  • B
  • Thread starter Thread starter Gingerot
Gingerot
Evaporation of a black hole by Hawking radiation defies common sense. Let us assume that a vacuum fluctuation leads to the birth of an electron-positron pair, with an electron being born below the event horizon and a positron above the event horizon. The positron flies away to infinity. But the electron falls into the central singularity. In this case, there is an increase in mass in the singularity! How is this process related to the “evaporation” of a black hole? The mass at the singular point increases.
Don't you think that's a bit naive ?
It isn’t. You’ll see Hawking radiation described that way in the popular press, but that’s not what’s really going on and it will confuse you if you take it too seriously.
from the original paper on what is now called Hawking Radiation:
(in talking about the particle-pair description): It should be emphasized that these pictures of the mechanism responsible for the thermal emission and area decrease are heuristic only and should not be taken too literally.
Likes vanhees71 and Vanadium 50
@Gingerot
There is no good math-free way of describing how Hawking radiation works, which is why so many pop-sci writers fall back on the misleading “explanation” you’ve seen.
The process can be described as negative energy falling into the black hole while positive energy escapes out to infinity, but that’s not a complete either. You will get some help from here and you can get the real thing from Hawking himself here.
Likes vanhees71, berkeman, BvU and 1 other person
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
