Black hole microstates and string theory
In summary, the connection between strings, branes, and black hole entropy is that in string theory, strings and branes are considered to be quantum mechanical vibrating extended charged black holes. These black holes, while not astrophysical in nature, can still be counted and their entropy can be related to the number of BPS states. String theory also offers multiple descriptions of these objects, allowing for a more comprehensive understanding of their properties.
quantumfireball
91
Can someone give me a Pop science explanation of what do strings and Branes have got to do with black hole entropy.
The no of degrees of freedom or the no of microstates of the black hole corresponding to a given macrostate is given by exp(S),where S is entropy of black hole which is related to area of event horizon.
So how do you count microstates of black hole using these extended objects?
As far as I know the black holes in string theory are not "astrophysical" black holes with event horizons and so on. Instead they are so-called BPS states with interaction turned off. I would call them unphysical!
The idea is that nevertheless these BPS states they correspond in some sense to black holes (if you could turn interaction on). It is possible to "count" these BPS states and to relate the entropy to the number of BPS states.
You can get some insights at Wikipedia:
http://en.wikipedia.org/wiki/String_theory
including:
...String theory is a theory of gravity, an extension of General Relativity, and the classical interpretation of the strings and branes is that they are quantum mechanical vibrating extended charged black holes.
And at the same location in Wikipedia:
String theories are formulated on cold black holes, which are those which have as much charge as possible...a theory of a black hole horizon is a theory of everything. Finding even one consistent holographic description, a priori, seems like a long-shot, because it would be a disembodied nonlocal description of quantum gravity. In string theory, not only is there one such description, there are several different ones, each describing fluctuations of horizons with different charges and dimensions, and all of them logically fit together. So the same physical objects and interactions can be described by the fluctuations of one-dimensional black hole horizons, or by three-dimensional horizons, or by zero-dimensional horizons.
Related to Black hole microstates and string theory
1. What are black hole microstates?
Black hole microstates are the quantum states that describe the microscopic properties of a black hole, such as its mass, angular momentum, and charge. They are believed to hold the key to understanding the fundamental nature of black holes.
2. How does string theory relate to black hole microstates?
String theory is a theoretical framework that attempts to unify all the forces of nature, including gravity. It predicts the existence of tiny, one-dimensional strings that vibrate at different frequencies, which can correspond to the different microstates of a black hole.
3. Can string theory explain the information paradox of black holes?
The information paradox is a long-standing problem in physics that arises when considering the fate of information that falls into a black hole. String theory offers a potential solution to this paradox by providing a way for information to be preserved and encoded in the microstates of a black hole.
4. How do scientists study black hole microstates and string theory?
Scientists use a combination of theoretical calculations and mathematical models to study black hole microstates and string theory. They also use data from observations of black holes and experiments at particle accelerators to test and refine these theories.
5. What are the potential implications of understanding black hole microstates and string theory?
Understanding black hole microstates and string theory could have far-reaching implications for our understanding of the universe. It could help us better understand the behavior of black holes and the nature of gravity, and potentially lead to new technologies and insights into other fundamental physics questions.
  • Beyond the Standard Models
11K
