Black hole music thread in other forum
In summary, LPF suggests starting a thread on BH ringing modes and/or natural units. Other questions asked include if degrees can be used instead of radians, the discrepancy in sun's mass between A# and A440tun., and if you want to do the next step in calculating the frequency of a solar mass BH, angular or cyclic format. LPF suggests using the Planck units, and if someone is confused about the two formats, they suggest looking into angular or cyclic freq.
  • #36
Marcus,
I think that you suggested an idea to look at the visible spectrum in natural units. I will become more acquainted with radians (angular format) this way.
*Roughly*:
red(4.06e14) = 1.4616e+17 radians ??
*color is subject to perceptive interpretation*
LPF
Science news on Phys.org
  • #37
Originally posted by 8LPF16
Marcus,
If you give me three colors---telling me the cyclic wavelengths in nanometers:
like
"red, 600 nanometers per cycle"
----then I will translate them for you. And we do not have to use my translations. If you like thinking of nanometers per cycle you can keep on forever thinking in those terms, which is fine. But I will be glad to translate so you can see what the other format would be like
like
"600 nanometers to get thru one cycle" means (divide by 2 pi)
600/2pi nanometers to get thru one radian of phase
because a radian is just 1/2pi of a full cycle (it is a different measure of phase change than counting full cycles)
so whipping out the old calculator that is 95.5 nanometers per radian!
now I always remember that e28 is about one sixth of a micron
more exactly e28 is 0.1616 micron (see? about one sixth!)
or equivalently e28 is 161.6 nanometers.
But I want my red color to be 95.5 nanometers! so its wavelength is less than e28
some fraction 95.5/161.6 of e28
WOW it is 0.591 e28
that is the same as 591 e25
look what happened. I started with 600 nanometers per cycle
and I wound up with 591 of the e25 multiple of Planck length.
Since 600 is rather close to 591 I can in a crude sense trade
nanometers per cycle for e25zes ("e-twentyfivezes") of Planck lengths per radian.
whatever numbers you give me to translate, your three favorite colors or whatever, the translation will be roughly the same numbers (only a little less, as 591 is less than 600) and it will be in terms of
e25 Planck length units (angular format).
hmmmm
could be confusing
you might want to stick with nanometers I don't care
but that's my offer
three free translations, as long as they are pretty colors
  • #38
Marcus,
Yet more clarity.
OK 3 colors:
730nm red
547nm green
460nm blue
LPF
  • #39
Marcus,
Yet more clarity.
OK 3 colors:
730nm red
547nm green
460nm blue
LPF
fair enough, more accurate translation will have to wait till later this evening or tomorrow since I have a chorus rehearsal but
we can do a quick and dirty because
600 nm to get thru a cycle corresponds to 591 e25 Planck to get thru a radian
so I just have to multiply each number by 591/600
719
539
453
so the angular wavelengths, expressed as multiples of Planck length (the tiny natural length unit built into the world)
are
RED: 719 e25 Planck lengths
GREEN: 539 e25 Planck lengths
BLUE: 453 e25 Planck lengths
And if you want the frequencies of red, green blue
as a fraction of the One frequency
then you just do reciprocal (one over the number)
That is, the blue frequency is
1/(453e25)
I put 453e25 in my cackle-ator and press the "one over" key and
BLUE FREQUENCY: 2.2e-28
well more later
  • #40
Marcus,
What role does lambdabar x omega play in this view?
Natural unit of speed of light?
LPF
  • #41
Marcus,
LPF
you got it. since they are reciprocals
if you multiply them you get one
and that is the speed of light
i have to go to sing otherwise wd be fun to talk more
  • #42
Marcus,
I am getting .999845, .99941, .999774, .9966, etc. for Planck C. Is this ok? In the chart I made, the same sort of thing happens with specific frequencies' speed.
They also follow the same pattern for being 70 rows apart from the other values used in the chart. Is there a significance for 70 generations (x2 value)? (or 1/2 value in other direction)
How was singing?
LPF
  • #43
Marcus,
How was singing?
LPF
singing was great
have you listened to any of the socalled "major choral works"?
eg. Mozart Requiem
Mozart Great Mass in C minor
Haydn Lord Nelson Mass (D minor)
Bach Mass in B minor
Handel Messiah
Beethoven Mass in C major
Schubert Mass number 6.
my chorus, the community chorus I sing in,
is currently learning the Haydn Lord Nelson Mass
wonderful experience
shall I refine those translations of colors, or is
what I already did accurate enough?
  • #44
what I calculated from your "nanometers per cycle" figures was
I think those are accurate as far as they go but they seem
awfully finicky. I would be inclined to round them off
RED: 720 e25 Planck lengths
GREEN: 540 e25 Planck lengths
BLUE: 450 e25 Planck lengths
I don't think the human eye could distinguish between
the color 719 and the color 720 (e25 Planck lengths)
but something you said suggested that you may have some
use in mind for the numbers which requires very fine accuracy.
If so, tell me and I will transcribe more decimal places.
  • #45
Marcus,
No, I don't think more accuracy is necessary.
While we are near the subject of music, do you know an equation that describes what is happening in three notes of a chord?
ie - a G chord of
note 1 = 392 (G)
note 2 = 494 (B)
note 3 = 294 (D)
(can composite waveforms be described by a single #)?
LPF
  • #46
ie - a G chord of
note 1 = 392 (G)
note 2 = 494 (B)
note 3 = 294 (D)
not by a single number
or at least not very usefully by a single number
do you have a piano or electronic keyboard?
on an elec.kybd. you can play the same note, say middle G,
and select different "instruments" or voices for it
a different voice is a different mix of OVERTONES
which are higher freqs that the string also vibrates at
a sound is almost never just the fundamental freq
it always has a mix of overtones
like not just ω but also a blend of different amplitudes of
2ω
3ω
4ω
5ω
the mathematics of harmony are basically pretty simple namely
that notes in harmony share a lot of the same overtones
so "do" and "sol" are in ratio 3/2
so twice "sol" is the same as thrice "do"
so they share that overtone, and a lot more too
and "do" and "mi" are in ratio 5/4
therefore 4x "sol" is the same as 5x "do"
and consequently they share that overtone, and a lot more too
so the notes fit together comfortably in their overtone series
the thing that makes harmony is simple fractional ratios like
5/4 and 3/2 and 2/1
as everybody in the italian town of Crotona should know well
so did I not understand the question?
  • #47
Marcus,
OK.
The answer is "not by a single number or at least not very usefully by a single number", I agree. Even the single note values that I gave you could be reduced. Four more octaves of reduction if we stay in our range of hearing (by 1/2 value every octave). There is no scientific reason to stop there, and we know this goes further. In fact, it can be taken to its' Natural smallest unit, right?
"Is that a Planck in your pants, or are you just glad to be talking about RESONANCE?"
Yet, when one begins to approach mastery in making chords, this "single #" becomes second nature to us. Unmistakable. Automatic. Fundamental.
What is happening here? Certainly something as "predictable" as chord progression deserves its' own math. The Calculus of Gravity. Mere lack of "existance" didn't slow Newton down in communicating his vision, and he left us to ponder the results of this new vision.
When I drop into conversations between people who are studying the physical world, they seem to all be talking about this. Yet, they do not know how to derive this new math. So let us not wander from this topic without some experimentation.
By using RATIOs like 5/4, 4/3, 2/1, it allows the model to be folded up and taken with and communicated with other musicians. If we were using math instead of chords, we would use the decimal numbers that these ratios represent: 1.25, 1.33, 1.5, etc.
First, a word on the Root, or tonic note. This is the General Relativity of music scales. Simply put, the rule starts from where YOU start. All other particles will wait until there is a tonic note to allow themselves to be defined; until then they ALL have resonant potential. This note fixes the value in time (root), and creates the "perspective" needed to determine resonance.
Step One = f (to be determined by perspective of user)
Step Two = 1.125f
Step Three= 1.25f
Step Four = 1.33f
Step Five = 1.5f
Step Six = 1.66f
Step Seven= 1.875f
Step Eight= 2f
By the way, because in music, we call the values in 1f and 2f the same, it is intuitive to think of these values in angular format, so that you are returning to same start point:wink: . Also note that there are SEVEN major notes, the 8th is just 2x the 1st.
What two groups come immediately to mind when seeing the steps of the scale laid out in "math"? Five #'s are "fast terminating", and whole # fractions of EIGHT. (hence the name "octave") The other two are non-terminating, and whole # fractions of THREE (and do not resonate with the 1/8 values).
Because step Eight has special rules already (it is neutral in relativity to tonic...it is the same, AND it is different), you should be able to see a "hidden" value at step Eight. It is 3/3, to finish the sequence of double end value. In decimals, this is .9999
Step Eight then, is quite a chameleon. It can be 8/8, 3/3, .9999, 2f, and, for the NEXT scale, the next 1f.
How to make a Triad. (chord) Pick starting note (tonic), figure value at step Three (mediant), and step Five (dominant). From previous example: G392, B494, and D588. I used D294 (1 octave up @ 1/2 value) because my finger can reach it! This is not necessary on the piano, it was invented and perfected during the time that the "equidistant" scale was being cooked up around 1690. You have to study the waveform of these 3 notes to fully understand why they resonate. The first note can never be overcome be the others because of the natural speed limit of C. They can only add to its' value (amplitude/pitch) without fundamentally changing the tonic. So the "sort of answer" we both agreed on is something like "a G chord with a base 392 is 392.4597846(yadda yadda)" Only the value to the right of the decimal point would change.
Great! you say, but where does this go?
Let's look at the Triad of light values that we used earlier.
Red 719
Green 539
Blue 453
Now, we too shall jump ship from the Kepler Galley to the Frigate of Andre Werkmeister. The equidistant scale uses 12 equal half-steps of 1.05946 (12sqrt2). In this format, the # 13 (intervals) is used as the neutral value of 2f in 12 half-steps, instead of 8 intervals for 7 whole steps. We will also divide the 7 "whole" colors into 12 even steps.
We know that these 3 values create the Triad we call "white light". From understanding waveforms and resonance, we must assume then, that this triad starts with a value that is white light. It's too bad that Science does not have a value for this. With some logical extensions, we can go 13 half-steps smaller from Red, and end at 359 Planck lengths (365nm), which is the first resonant value of UV in the next octave past visible light. As said before, we can not just dis-allow the values of IR and UV in our search for better understanding. This is saying that the 1/2 value of red, while in proximity, is indistinguishable from red, yet because of Planck speed, can not be caught or changed by the other resonant values. We call this note red because we only perceive ONE octave of color, none are repeated in higher or lower form. If we saw one more color up into UV, we would have no red (as is the case for many other eye bearing life forms). A curved eye (all eyes share common evolution)will always have the same limitations because of the angular format of the wave. Isn't it fascinating that our totally dissimilar ears have the same limitation spread out over 10 octaves?
To shorcut the rest of the story, by taking the natural commonality of vibration, and simply extending the 13 interval scale from music up to the e-7 "row of values" of light, all known colors can be produced and explained by triads of notes (chords).
The commonality of vibration is what I call your system of natural values. Take the "/1sec" out of the equation to simplify, and your left with "planck" values. This is what the chart is made from. Not frequency, not wavelength, yet both are there, under a Planck.
Take a longer look at https://www.physicsforums.com/showthread.php?s=&threadid=13481
LPF
