Black Hole via charge compression
In summary, the charged black hole created by compressing a massless shell has a larger mass than the original mass of the shell. The event horizon is unaffected by the lack of an inward force on the system itself, and it is thought that a naked singularity cannot form.
  • #36
Right of course, there is a non-zero EM field within the shell. However, this can be made arbitrarily small by shrinking the shell. So without shrinking the shell to 0, you can still end up with negligible contributions to the effective mass AT the shell surface due to the EM field. So you would get something like:
[tex]
M_{shell} = M_∞-\dfrac{Q^2}{2R} - M_{EM}(R)
[/tex]
where [itex]M_{EM}(R) << M_∞[/itex] can be accomplished for any situation by shrinking the shell right? In fact, for most situations this would be the case, since the EM field outside a thin charged shell would have much more energy than the EM field within the shell.
The rest mass of the matter content would be [itex]M_{shell}[/itex], and should still remain >= 0 regardless of the details of the shell's internal interactions. Of course it is free to change as matter is turned into EM energy (or some other form of energy), but the matter content can't go below 0!
So my argument above should still hold. If [itex]M_{shell}\geq 0[/itex] always, that means [itex]M_∞-M_{EM}(R)\geq\dfrac{Q^2}{2R}[/itex] and the minimum radius the shell can be collapsed to can be solved analytically from that inequality. Assuming [itex]M_{EM}(R) << M_∞[/itex] we find the approximate solution:
[tex]
R_{min} = \dfrac{Q^2}{2M_∞}
[/tex]
Working this out without any approximations (shell has thickness a) gives:
[tex]
R_{min}-a = \dfrac{Q^2}{2M_∞}
[/tex]
I may have done something wrong, but the only assumption I made was that the mass of the matter content of the system had to remain non-negative. Once the mass of the matter hits 0, there is no method to obtain more energy out of it so the shell must stop shrinking! So while the RN metric is a solution to the EFE, it seems that the only way to CREATE an ideal one would be to compress an infinitely massive shell. If the mass is infinite you get [itex]R_{min}=a[/itex], so as long as it is possible to compress the thickness of the shell you can reach a singularity at R=0
<h2>1. What is a black hole?</h2><p>A black hole is a region in space with such a strong gravitational pull that nothing, including light, can escape from it. It is formed when a massive star dies and its core collapses, creating a singularity where the laws of physics as we know them break down.</p><h2>2. How does charge compression create a black hole?</h2><p>In charge compression, an object with a large amount of electric charge is compressed into a small volume. This creates a strong electric field that can cause the object to collapse under its own gravity, forming a black hole.</p><h2>3. Can black holes be created artificially through charge compression?</h2><p>Currently, there is no technology or known process that can artificially create a black hole through charge compression. The amount of energy and precision required is beyond our current capabilities.</p><h2>4. What happens to matter that enters a black hole via charge compression?</h2><p>Once matter enters a black hole, it is stretched and compressed by the extreme gravitational forces. Eventually, it reaches the singularity where it is crushed to an infinitely small point and its information is lost to the outside universe.</p><h2>5. Are there any potential applications of black holes created via charge compression?</h2><p>At this time, there are no known practical applications for black holes created through charge compression. However, studying black holes can help us better understand the laws of physics and the nature of the universe.</p>
Related to Black Hole via charge compression
