Black Holes: Observation of an astronaut falling
In summary, a new member of a forum is seeking clarification on the effects of falling into a black hole for a presentation. They ask for bullet points explaining what happens to an astronaut falling into a black hole, including questions about gravitational time dilation and redshifting of light. Other members suggest doing their own research and provide some bullet points, clarifying that light is redshifted due to the extreme gravity and that an infalling object will eventually disappear from view. The original poster also asks about the final photon emitted and the concept of the singularity, to which others provide further explanations. It is noted that from the perspective of someone falling into the black hole, the relativistic effects are largely irrelevant.
stelios28
Hey guys,
I'm a new guy in this forum. I've been visiting it for 1 year actually but never decided to register and so I did.
I am having a presentation on black holes at school and I want some clariffication of what's going on when falling into a black hole.
Well let's assume that an astronaut is falling into a black hole.
I read that he will seem to go slower and slower ( I think it said gravitational time dilation) and that the light will be also red shifted.
Can someone make me some bullet points showing clearly what's going on and explaining briefly what happens?
P.S English is not my native language so ignore any mistakes...
To an OUTSIDE observer, he appears to go slower. To himself there is no such effect.
It sounds as though you are asking people here to do your work for you. You need to do your own research and write your own bullet points. If you have questions, people here will be happy to answer them (just NOT the question "would you please do my work for me?")
No offense butI have devoted a lot of time and did a lot of research
I just want some clarification on why light closer to the Event Horizon takes more time to travel to the observer and whether the astronaut will become freaking "RED" due to the redshifting. I know the general idea of general relativity, and thought that it was due to the curvature that the light takes more time to travel to the observer. But as I am going to be presenting this to high school students it's not a good idea to tell them about GR as I don't know much either.
Light near the event horizon takes longer to reach a far-off observer because of the distortion of spacetime due to the extreme gravity of a black hole. The closer to the EH the longer it takes, until finally, AT the EH, it never escapes. So yes, to a remote observer, infalling stuff appears to slow down and get redshifted, but to the infalling stuff, nothing happens (except sphagettification, which isn't exactly "nothing" but that can happen inside or outside the EH, depending on the size of the BH)
If you've done so much research, why don't you post YOUR set of bullet points, and ask if anyone thinks you have any mistakes or serious omissions?
So, The project is in greek so I will have to translate it. That is why I need that extra help.
Observer=Ob, Astronaut=As, event horizon=EH
1) The Ob will watch the As getting closer to the EH without any problems
2) The closer the As gets to the EH the slower it seems to be moving In the eyes of the Ob
3) As he gets very close to the EH he seems to be stopping and finally he seems to be stationary after passing the EH (Though it will seem to the Ob that he hasn't passed it)
Then here comes they questions and not verified ones
4) Due to redshifting, the light will be extended to higher frequencies until it passes the Visible spectrum and becomes radiowaves and etc.
5) Will he emmit a final photon in a finitive/infinitive time and then disappear after becoming redder due to redshifting
redshifting causes LOWER frequencies, not higher. As something recedes from you the wavelength increases, which is to say, the frequency decreases. Strong gravity has the same effect as if the object were receding from you.
When the infalling object reaches the EH, there WILL be a "last photon" emitted which has any chance of ever being detected by a remote observed and all photons emitted thereafter will be trapped inside the EH.
Oops I said the frequency increases and then said that this light will become radio waves! Doesn't make sense. oh by the way is there any way that the light becomes radio waves due to redshifting
So after the last photon is received the As will be like invisible right?
Yes once the As passes the EH no more photons will be visible to the Ob and the As will cease to have any causal relationship to the rest of the Universe except for the effects of increase in mass of the BH.
The photons get redshifted to infinity due to the extreme gravitational driven curvature(essentially redshifting until their frequency would be too long to be detectable)
From the point of view of the As all world lines and possible futures point inexplicably towards the singularity, whatever that may be.
All the relativistic affects you are worried about are largely irrelevant from the perspective of an observer in free fall. A stationary external observer will think you slow down as you approach the event horizon. You will also think the stationary external observer slows down as you approach the event horizon. Photons struggle just as much to reach you as they do the stationary EO.
According to the following article the appearance of a person who is falling into a black hole remaining stationary at the event horizon is just an optical illusion caused by the light being trapped there. Nothing more.
Excerpt:
What happens to you if you fall into a black hole?
Original by Matt McIrvin.
A more physical sense in which it might be said that things take forever to fall in is provided by looking at the paths of emerging light rays. The event horizon is what, in relativity parlance, is called a "lightlike surface"; light rays can remain there.
For an ideal Schwarzschild hole (which I am considering in this paragraph) the horizon lasts forever, so the light can stay there without escaping. (If you wonder how this is reconciled with the fact that light has to travel at the constant speed c—well, the horizon is traveling at c! Relative speeds in GR are also only unambiguously defined locally, and if you're at the event horizon you are necessarily falling in; it comes at you at the speed of light.)
Light beams aimed directly outward from just outside the horizon don't escape to large distances until late values of t. For someone at a large distance from the black hole and approximately at rest with respect to it, the coordinate t does correspond well to proper time.
So if you, watching from a safe distance, attempt to witness my fall into the hole, you'll see me fall more and more slowly as the light delay increases. You'll never see me actually get to the event horizon. My watch, to you, will tick more and more slowly, but will never reach the time that I see as I fall into the black hole. Notice that this is really an optical effect caused by the paths of the light rays.
Steven Weinberg's Gravitation and Cosmology (New York: John Wiley and Sons, 1972) provided me with the historical dates. It discusses some properties of the Schwarzschild solution in chapter 8 and describes gravitational collapse in chapter 11.
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/fall_in.html
It is of little comfort that a glorious image of myself remains behind for all to see when in reality I have long since been unceremoniously spaghettified and devoured.
spaghettification
Related to Black Holes: Observation of an astronaut falling
Q: What is a black hole?
A black hole is a region in space with a gravitational pull so strong that nothing, not even light, can escape from it. It is created when a massive star dies and its core collapses under its own gravity.
Q: How is an astronaut affected when falling into a black hole?
The gravitational pull of a black hole increases with proximity, so an astronaut falling into a black hole would experience extreme tidal forces. This means that the astronaut would be stretched and compressed in different directions, resulting in a process called spaghettification. Eventually, the astronaut would reach the singularity at the center of the black hole, where the gravitational pull becomes infinite and the laws of physics break down.
Q: Can we observe an astronaut falling into a black hole?
Technically, no. Since light cannot escape from a black hole, we cannot directly see an astronaut falling into it. However, we can observe the effects of a black hole's gravitational pull on its surroundings, such as the distortion of light and the emission of high-energy radiation. These observations can provide valuable insights into the existence and behavior of black holes.
Q: How do scientists study black holes?
Scientists use a variety of methods to study black holes, including observations with telescopes and other instruments that can detect the effects of a black hole's gravity. They also use mathematical models and simulations to better understand the behavior of black holes and test different theories about their nature.
Q: Can anything escape from a black hole?
No, nothing can escape from a black hole's event horizon, the boundary beyond which the gravitational pull becomes too strong for anything to escape. However, some theories suggest that certain particles, such as Hawking radiation, can escape from a black hole, but this has not been observed yet and is still a subject of ongoing research.
  • Astronomy and Astrophysics
