Undergrad Black holes to explode due to evaporation?
Hawking radiation causes black holes to gradually evaporate, leading to a rapid increase in energy emission as they shrink, which can be perceived as an explosion. The singularity, a feature of spacetime within the black hole, does not disappear but becomes unreachable after evaporation. The concept of a black hole's mass reaching zero is debated, with some suggesting that the mathematical models used may not hold true as the mass approaches zero. Current theories, based on general relativity, may break down under extreme conditions, indicating that our understanding of black holes is incomplete. Ultimately, the nature of black holes and their singularities remains a complex and unresolved area of physics.
HansH
TL;DR
according to Hawking a black hole slowly evaporates and shrinks. as I understood there comes a moment when it explodes and the singularity disappears. is this true and if so, how is this triggered?
according to Hawking a black hole slowly evaporates and shrinks (when not feeded from outside with matter falling in). as I understood there comes a moment when it explodes and the singularity disappears. Is this true and if so, how is this triggered? and is there something such as a critical minimum mass?
HansH said:
as I understood
From where? Do you have a reference?
More precisely, the rate of Hawking radiation increases as the hole gets smaller; in the final stage of evaporation the rate gets extremely rapid, to the point where it looks like an explosion.
The singularity is a global feature of the spacetime (more precisely, of the region of spacetime inside the hole). It doesn't "disappear". It just is not reachable from any events after the evaporation is complete.
not sure about a reference. If you say 'in the final stage of evaporation the rate gets extremely rapid' then when does it stop? Do I understand you right that the singularity always remains after evaporation? is there a residual mass then after evaporation? or are we talking about a singularity with mass=0?
I just came this this one: https://www.space.com/black-holes-general-relativity-gravity: As black holes evaporate, they get smaller and smaller and their event horizons get uncomfortably close to the central singularities. In the final moments of black holes' lives, the gravity becomes too strong, and the black holes become too small, for us to properly describe them with our current knowledge.
When the hole has finally evaporated.
A term like "always" does not make sense with respect to the singularity. The singularity is not a thing in space. It is a moment of time. That moment of time is to the future of all moments inside the black hole. But from outside the hole, that moment of time is not reachable after the black hole has evaporated (because the region of spacetime inside the hole is not reachable).
Pop science sites are not good sources if you want to actually learn physics.
What they might be referring to here is that many physicists believe quantum gravity, when we actually have a good theory of it, will change our understanding of how black holes and black hole evaporation work. But until we have such a theory, all we have are the models that Hawking and others have constructed using our current theory of gravity, GR.
Likes topsquark
ok, but what does 'has finally evaporated.' mean. is the mass then 0?
To an observer who is to the future of the final burst of light that spreads outward from the final evaporation event, yes.
Likes topsquark
so To an observer who is to the future of the final burst of light then there is still a singularity but with mass=0? can this observer be someone standing beside this black hole final stage and observing its mass from outside?
No. Go read my previous posts again.
It could be, provided the observer was capable of withstanding radiation of arbitrary intensity and had a rocket capable of providing an arbitrary amount of thrust indefinitely. Such an observer could, for example, "hover" at a constant altitude above the hole, and would see the rocket thrust required to maintain altitude continually decrease, until, after the final burst of light passed him, the thrust would be zero--he could turn off his rocket and just float in place in free fall.
Likes topsquark
HansH said:
as I understood there comes a moment when it explodes...
Not quite. The rate at which energy is emitted is inversely proportional to the mass of the black hole, so as the black hole shrinks it evaporates away ever more quickly. Eventually the evaporation is fast enough that we describe the energy release as an "explosion".
...and the singularity disappears.
Well maybe, but we don't really know. The problem is that the math we use to calculate the rate of energy release makes some assumptions that probably do not hold as the mass of the hole goes all the way to zero. It's a safe bet that something interesting happens, but it may not be the interesting thing that we get from just carrying Hawking's equations all the way down to zero.
Likes Fra and topsquark
then I would assume the mass of the residue of the black hole =0 as there is floating in free space so then I do not understand what you mean with 'No. Go read my previous posts again.'
Not all models of evaporating black holes include singularities. For those that do "past" and "future" is too simplistic a model of causality to describe where/when the singularity is. In the simplest model I'm aware of, if you don't enter the black hole then less and less of the singularity is reachable, until there comes a point where none of it is in your future lightcone. Some time after that you see the final Hawking radiation, but the singularity never enters your past lightcone, so is never unambiguously in your past. To the extent that there was ever "a place where the black hole was", there's nothing left there at that point.
Likes topsquark
ok so that I interpret as that that is the edge of what we currently know.
There is no "residue of the black hole". The black hole is a region of spacetime. It is not a "thing" that "appears" or "disappears". It is a region of spacetime that is only accessible from certain other regions of spacetime. The black hole region of spacetime is not accessible from the region of spacetime to the future of the last light that gets emitted outward from the final evaporation.
I mean that I've already described the correct way to look at the singularity--and when you look at it that way, the questions you are asking don't even make sense. In particular, please read my post #5 (and most of all my second response in that post).
The spacetime diagram in this Wikipedia article might help:
https://en.wikipedia.org/wiki/Black_hole_information_paradox#Black_hole_evaporation
The black hole is the region at the upper left, bounded by the singularity (jagged line) at the top (note that the singularity is horizontal, meaning it's spacelike--i.e., it's a moment of time, to the future of all events inside the black hole) and the event horizon (the 45 degree line going up and to the right, that meets the singularity at its right edge).
If you continue the 45 degree line of the event horizon further up past where it meets the singularity, that is the worldline of the last light emitted from the final evaporation of the black hole. The region of spacetime above (i.e., to the future of) that is flat--no black hole, no gravity, no "residue", no nothing: it's flat like the Minkowski spacetime of SR.
I think there is a discrepancy between answering "what is really happening" and "what is experienced by an observer."
Unless I am wrong, an external observer - who need know nothing about past or future light cones - sees a black hole shrink as it sheds Hawking radiation, even as its mass shrinks toward zero, flattening the local spacetime curvature, until at the last moment, it just poofs out, and all that is left is flat space and an expanding shell of radiation. Yes?
Likes russ_watters
So if I understand that well you say that you cannot have influence on that because it always remains a moment in future. but on the other hand nothing is left as seen from outside.
how does that relate to what is said in #10:
'The problem is that the math we use to calculate the rate of energy release makes some assumptions that probably do not hold as the mass of the hole goes all the way to zero.'
All predictions made about black holes depend on GR, and even Hawking radiation is based on a semi-classical analysis. It all has to be wrong somewhere.
Likes Fra
timmdeeg said:
Its an interesting discussion about something which doesn't exist, because the theory breaks down.
Well - may not exist. We know GR has to be wrong somewhere, but we also know it's a very good predictor in many places. Exactly where it goes wrong and what actually would happen where it does is not known. At the fairly qualitative level of this discussion we might be right...
Likes timmdeeg and phinds
One can ask what an observer (say a particle lab), would hypothetical infer if from statistics if we could produce/prepare and make repeated experiments on small (subatomic) microscopic black holes? For example, how would they be distingiushed or classified in the overall phenomenology? It seems to me this can't be solved isolated from the other forces (as a quantum gravity only), as going up that energy level we need get pass and cross the domain where new physics may appear anyway.
From the perspective of high energy phenomenology, how would say a perphaps stable ot quasi-stable(as we don't know what QG will say, if there is a stable remnant or not), subatomic black hole "look like" from the outside? How is it different from a hypothetical elementary particle?
The assymmetry in the observing context (a human macro lab) and a subatomic blackhole, or a cosmological black hole are so huge, that I have not real faith in extrapolating the the mathematics of cosmological objects, to the subatomic domain. From the perspective of inference and empirics this is twisted in so many ways.
/Fredrik
Is there still a loophole that the singularity of a black hole could "exist"?
Wouldn't that mean that the theory breaks down at r = 0 but the singularity somehow "survives" though.
Likes Ibix
No, that's not what I said. It's only a moment of time in your future if you are inside the hole. If you remain forever outside the hole, it's not. It's in a region of spacetime that becomes unreachable for you after a particular point on your worldline: the point at which your future light cone no longer includes any events inside the hole--or, in more ordinary language, the point after which you could no longer make yourself fall into the hole before it evaporated away even if you fell radially inward at the speed of light.
If we don't make those assumptions, we can't say anything about what happens because we don't have any other model of black hole evaporation to use. Everything I have said is using the model whose spacetime diagram I linked to, which is a model that is made using those assumptions.
Note, however, that there are other "black hole" models, such as the Bardeen "black hole" (a forum search on that term should turn up some previous threads on the topic), which aren't actually black holes at all (hence the scare quotes), because they don't have actual event horizons, only apparent horizons, and they don't have singularities. The objects in these models, however, look like black holes from the outside, and also evaporate in a way similar to the way Hawking envisioned.
It is quite possible that, as our understanding of physics in this area improves, we will find that some model like that is actually the correct description for the objects that we now refer to as "black holes". That would be nice because it would remove all the issues associated with the presence of an event horizon and singularity in the model whose spacetime diagram I linked to above.
Likes jbriggs444
timmdeeg said:
The "Bardeen black hole" type models I referred to in post #23 just now are an example of this kind of model. The missing piece is that we don't know at a microphysical level how the kind of stress-energy tensor that is required in the deep interior of such models gets produced.
Likes timmdeeg
More or less. See the last part of my post #9.
No, I agree the singularity is implausible. I was only thinking of "black holes radiate away leaving nothing behind", which is true for Hawking radiation and might turn out to be true for a full quantum gravity model.
Likes timmdeeg
I don't think we know that. QM could be wrong somewhere.
It does, but not like explosions we are familiar with, especially on astronomicall scales.
It's brighter than the sun = but only for 40 nanoseconds. The energy in that 40 ns is large by terrestrial scales - kilotons - but small on astronical scales. If we had an evaporation in our galaxy, I doubt it would be visible to the naked eye.
QM could be - probably is - wrong somewhere but that doesn't get to us to "GR is not wrong somewhere". The two theories work very well in their own domains but those domains have so little overlap that there's no reason to trust either at the intersection of strong spacetime curvature and small distances,
Likes Ibix and Fra
  • · Replies 51 ·
  • · Replies 40 ·
  • · Replies 73 ·
  • · Replies 35 ·
  • · Replies 31 ·
