Blackhole and Anti-Blackhole Annihilation
In summary: Matter and anti-matter don't interact because they have opposite charges. Matter and anti-matter both have energy and momentum, they just have different types of energy and momentum.
Pyce
Ok I am wondering what would happen if an anti-black hole collided with a black hole of the same mass. Would they annihilate and release energy or would it become a more massive or less massive black hole?
What do you mean with "anti-black hole"?
The theoretic solution of white holes? They would need a negative mass, and repel masses, so I doubt that they could merge with a black hole.
A black hole, made from antimatter? This does not matter (;)), only the energy content is relevant. They would behave like regular black holes, and if they hit another black hole they merge to one bigger black hole.
There is no standard meaning of your term "anti-black hole."
In particle physics, "anti-" means something having the opposite charge, but that doesn't sound like what you mean.
It's conceivable that you might mean an analogy of the form (compression wave of sound):(rarefaction wave of sound)::(black hole):(anti-black hole). In this case, the anti-black hole isn't a solution to the Einstein field equations, which are nonlinear.
There is the theoretical possibility of a white hole, but a white hole is not a physical object like the one you seem to have in mind. It can't be formed by gravitational collapse.
This is a little subtle. I originally posted that it was not true that they had negative mass. Actually I think it's more complex than that. On the Penrose diagram for a maximally extended Schwarzschild metric, you have a whole separate universe in which the definition of energy is negated. It's not obvious to me how to apply that to a universe in which both a black hole and a white hole are accessible from the same external space.
[EDIT] Having studied up on this a little more, I think the answer is that white holes do not have negative mass, and they attract rather than repel test particles.
The Schwarzschild metric with negative mass is nothing like a black hole or white hole. It's an unstable naked singularity: http://arxiv.org/abs/gr-qc/0604021
The WP article http://en.wikipedia.org/wiki/White_hole states that a white hole attracts matter rather than repelling it. This makes sense, e.g., because we expect the ADM mass to be conserved in the maximally extended Schwarzschild spacetime, which consists of a white hole followed by a black hole at later times.
I'm sorry I meant a anti-matter black hole. I was using the anti term like used in anti-matter or anti-galaxy.
Then if it's electrically neutral, the anti-black hole is the same object as the black hole.
A black hole is believed to possesses only 3 fundamental properties - mass, charge and spin. None of these properties appear to have a matter - anti matter bias. Keep in mind that matter is utterly disassembled by a black hole, not just atoms, but, all of their constitues particles. The type of matter that enters the event horizon does not appear to be of any consequence.
And these properties reside at or outside the event horizon?
I don't think this is the kind of question that makes sense in GR. Answering it would require saying the location "now" of whatever stuff went into forming the black hole by gravitational collapse. GR doesn't give an unambiguous definition of simultaneity as measured by a distant observer. For example, if a charged particle is released near a black hole, a distant observer can say that the particle approached the event horizon asymptotically but never got through (because of infinite time dilation), or he can say that it reached the singularity a long time ago. Neither of these is right or wrong. Therefore we can't say where the charge resides. I'm giving an example that involves the formation of the black hole by gravitational collapse, but I don't think the answer is changed if you consider an eternal black hole; quantities like mass and charge are still not localizable according to a distant observer.
A black hole is an object that has enough mass to bend space infinitely (quantum mechanics theory of what space is). So, an anti black hole would straighten space infinitely therefore, would have no effect.
Related to Blackhole and Anti-Blackhole Annihilation
1. What is a blackhole and anti-blackhole annihilation?
A blackhole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. Anti-blackhole annihilation is a theoretical phenomenon where a blackhole and an anti-blackhole (a blackhole with opposite charge) collide and release a burst of energy.
2. How do blackholes and anti-blackholes form?
Blackholes are formed when a massive star collapses under its own gravity at the end of its life. Anti-blackholes are hypothetical objects that are predicted by some theories, but have not yet been observed.
3. Can blackholes and anti-blackholes annihilate each other in nature?
Currently, there is no evidence that blackholes and anti-blackholes exist in nature, so we cannot say for sure whether they can annihilate each other. This phenomenon is only predicted by some theories, and has not been observed.
4. What would happen if a blackhole and anti-blackhole annihilated each other?
If a blackhole and anti-blackhole were to collide and annihilate each other, they would release a tremendous amount of energy in the form of gamma rays, which are the most energetic form of electromagnetic radiation. This process would also create new particles and antiparticles.
5. Can anti-blackhole annihilation be harnessed for energy production?
While it is theoretically possible for anti-blackhole annihilation to release a large amount of energy, it is currently not feasible to harness this energy for practical use. The amount of energy released would be difficult to control and contain, and the technology to do so does not currently exist. Additionally, the existence of anti-blackholes is still a subject of debate in the scientific community.
