Block falling on spring/max compression
In summary, the 700 g block is released from rest at height h0 above a vertical spring with spring constant k = 445 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 20.5 cm. The block does work on the spring- 9.35 N-m. The value of h0 is 1.158 m. If the block were released from height 2.00h0 above the spring, what would be the value of h0?
wilcofan3
27
A 700 g block is released from rest at height h0 above a vertical spring with spring constant k = 445 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 20.5 cm.
(a) How much work is done by the block on the spring?
(b) How much work is done by the spring on the block?
(c) What is the value of h0?
(d) If the block were released from height 2.00h0 above the spring, what would be the
I got parts a, b, and c right, and have tried a few different things with d and have gotten it wrong.
For a and b, I got 9.35 (b was -9.35), and for c, I got 1.158 m. I went back to my equation for the spring, where [tex]mgh = .5kx^2[/tex], and solved for x but keep getting the wrong answer. I used my answer in c as the new height in mgh, is there something wrong with doing that? I ended up getting the equation...
[tex]x^2= 2mgh/k[/tex]
Obviously I then just took the square root of that.
I have some things in mind:
yes your final equation is wrong. The 2ho is above the spring but the spring is compressed by an amount x. This amount also contributes as Potential energy ( its under the point of zero of Potential Gravitational Energy).
look at your energy changes. You have an initial Gravitational Potential Energy, That energy is then transformed into kinetic energy.. But not completely. At the exact point before the object hits the spring the object has both potential and kinetic energy. And that total energy is converted into Elastic Potential Energy. Because energy is constant, you can say Gravitational Potential Energy before = Elastic Potential Energy After, but is your point of reference where your saying that your Grav. Potential Energy at the top of the spring? or the bottom of the spring? The point where Ep is zero isn't the ground because the spring could be on an airplane or x amount of height above the ground.
FAQ: Block falling on spring/max compression
What is a block falling on a spring/max compression experiment?
A block falling on a spring/max compression experiment is a physics experiment that involves dropping a block onto a spring and observing the maximum compression of the spring. This experiment is used to study the relationship between the mass of the block, the height at which it is dropped, and the maximum compression of the spring.
What is the purpose of a block falling on a spring/max compression experiment?
The purpose of this experiment is to demonstrate the principles of energy conservation and Hooke's law. It also allows for the calculation of the spring constant of the spring, which is a measure of its stiffness.
What factors affect the maximum compression of the spring in this experiment?
The maximum compression of the spring is affected by the mass of the block, the height at which it is dropped, and the properties of the spring such as its spring constant and length.
How is the spring constant of the spring calculated in this experiment?
The spring constant can be calculated by using the equation F = kx, where F is the force applied to the spring, k is the spring constant, and x is the displacement of the spring from its equilibrium position. In this experiment, the force can be calculated by using the mass and acceleration due to gravity of the block, and the displacement can be measured by observing the maximum compression of the spring.
What are some real-life applications of the block falling on a spring/max compression experiment?
This experiment is used in various industries, such as automotive and aerospace, to study the behavior of materials under compression. It is also used in the design and testing of shock absorbers, springs, and other mechanical components. Additionally, it is used in educational settings to teach students about energy conservation and Hooke's law.
