Block Sliding Down a Ramp that is Free to Slide
In summary, the conversation discusses a scenario where a block slides down a smooth, frictionless ramp onto a horizontal surface. The objective is to find the speed of the block after it has left the ramp and is moving on the flat surface. The conversation includes a request for a clear and complete free body diagram, a table to determine various values such as average net force and work done, and a question about how this scenario can be treated similarly to collision problems. The solution involves using equations such as Wc + Wnc = delta K and Wnc = delta Emech to find the final speed of the block and discussing the conservation of mechanical energy and momentum in this scenario.
PokemonMaster
A block with mass m rests on a smooth, frictionless ramp with mass M and height h. The ramp itself sits on a frictionless horizontal surface in which it is free to slide. The block slides smoothly down the ramp from rest. We want to find the speed of the block after it has left the ramp as it is moving horizontally on the flat surface.
a. Draw a clear and complete free body diagram for the block AND the ramp at an instant when it is sliding at an arbitrary location on the ramp.
b. SEE TABLE - Determine the 1: Average Net Force (Direction Arrow), 2: Net Work Done By All Forces (+,-, 0), 3: Work done by Non-Conservative Forces (+,-, 0), 4. Kinetic Energy Conserved? (C, NC), 5. Mechanical Energy Conserved? (C, NC), and 6: Momentum (x,y) Conserved (C, NC)? for EACH of the 3 systems: A. Block, B. Ramp, and C. Block-Ramp. Assuming that the total mechanical energy of the Block-Ramp system is conserved.
c. Find the final speed of the block once it has reached the horizontal surface.
d. How can we treat this situation the same way we treat collision problems?
There are many, including:
Wc + Wnc = delta K
Wnc = delta Emech
a. the block: "mg" down, "n1" perpendicular to ramp, and "mg cos theta" parallel to ramp
the ramp**: "Mg" down, "n1" going into the ramp, and a large "n2" coming up perpendicular to the ground
I am less sure about the ramp diagram.
b. I attached a photo including my table.
c.
Ui = Kf
mgh = 1/2 mv^2
2gh = v^2
v = sqrt (2gh)
d. This situation is similar to a collision problem because mechanical energy of the block-ramp system is conserved and therefore the momentum of the block-ramp system is conserved. The normal force that the ramp exerts on the block causes the block to move to the right and the reactive force that the block exerts on the ramp causes the ramp to move to the left, so the normal force can be equated to a collision force where the two objects move in opposite directions with different velocities depending on their masses like in an elastic collision.
I believe that the conservative work on both the block and the ramp is done by gravity while the nonconservative work on both is by the normal force. I have updated the filled in chart I posted for part b and now think that the column for the block is: down and to the right arrow, +, + , NC, C, x: NC and y: NC. Then for the ramp: right arrow, +, +, NC, NC, x: NC, y: C. Lastly, for the block-ramp system I believe that there are no external forces acting on the system so the values would be: 0, 0, 0, C, C (given), x: C and y: C.
Do you know how the terminal velocity of the block on this ramp compares to a fixed ramp?
Mechanical energy is typically not conserved in a collision. What is conserved?
Also, consider the transition from sliding down the ramp to sliding on the horizontal surface. Will mechanical energy be conserved then?
Sashimoo the necromancer strikes again!
PokémonMaster has not been online in about 6 months it would appear.
Related to Block Sliding Down a Ramp that is Free to Slide
1. How does the angle of the ramp affect the speed of the block?
The angle of the ramp affects the speed of the block because it determines the force of gravity acting on the block. The steeper the angle, the greater the force of gravity and the faster the block will slide down the ramp.
2. What factors affect the friction between the block and the ramp?
The factors that affect friction between the block and the ramp include the surface materials of the block and the ramp, the weight of the block, and any external forces acting on the block.
3. Is the acceleration of the block constant as it slides down the ramp?
The acceleration of the block is not constant as it slides down the ramp. It will initially accelerate due to the force of gravity, but as it slides, the friction between the block and the ramp will increase, causing the acceleration to decrease until the block reaches a constant speed.
4. How does the mass of the block affect its motion down the ramp?
The mass of the block does not affect its motion down the ramp. As long as the surface materials and angle of the ramp remain constant, the mass of the block will not change its acceleration or speed.
5. Can the block slide up the ramp if the angle is steep enough?
No, the block cannot slide up the ramp if the angle is steep enough. The force of gravity will always pull the block down the ramp, and the friction between the block and the ramp will prevent it from sliding up the ramp.
