Bluetooth speaker connects to Raspberry Pi 4 but plays no sound
  • Thread starter Thread starter Swamp Thing
    Bluetooth Speaker
Bluetooth speakers can be successfully paired with a Raspberry Pi 4, and users can select them as audio output through the desktop interface. The speaker's profile typically appears as "High Fidelity Audio (A2DP Sink)." However, issues may arise where the speaker remains silent during media playback, with only brief sound when adjusting the volume. Troubleshooting steps include ensuring the proper Bluetooth driver is installed on the Raspberry Pi. While some users may successfully use Bluetooth earphones, specific modules may still be required for speaker functionality. A recommended solution involves adding the user to the Bluetooth group with the command "sudo usermod -a -G bluetooth pi," which can resolve audio output issues after a reboot.
Swamp Thing
Insights Author
  • I am able to pair my Bluetooth speaker to my Raspberry Pi 4.
  • I am able to select it as the current audio output by right clicking on the "speaker" icon, top left of desktop.
  • Under "device profiles" the speaker's profile is shown as "High Fidelity Audio (A2DP Sink)".
  • But when I play any media, the speaker is silent.
  • Each time I press the volume up (+) key on the speaker, it plays the media for a short time (a fraction of a second).
Anything I can do to troubleshoot and fix this?
Computer science news on Phys.org
I haven't done anything like this before but the first thing that I would do is check to see if you have a proper driver installed on the Pi.
At least some of the driver stack is installed and working properly, because I am able to use Bluetooth earphones (2 or 3 different makes) without any problem.
I could still be missing some specific module that is needed for the speaker, though. I am googling this problem. The suggestions I found so far haven't helped.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
9K
