Boat slowing down with variable acceleration
In summary: In this case you would find c by plugging in the values for v and t at the time the engine is shut down.In summary, the motor boat of mass m will gradually slow down and stop after a certain time interval, with its speed decaying according to the function v=ce^-kt, where c is a constant determined by the initial speed at the moment the engine is shut down, and k is a constant determined by the resistance of water and the mass of the boat.
ionitacodrut
A motor boat of mass m moves on the surface of a lake at a speed0v. At the moment 0t= the engine is shut down. Assuming the resistance of water to be proportional to the speed of the boat, F=−rv, find
a) the time interval after which the boat stops;
b) the speed of the boat as a function of the distance covered with the shutdown engine.
I have tried using the kinetic variation law but can' exactly figure out the work done by F
There appears to be a typo in your post. The zero in "0v" is extraneous.
I would work on part a) first. Can you characterize the speed of the boat as a function of time?
If you know how to solve differential equations, there is a fairly simple one here. If not then you can notice that as the velocity of the boat is reduced the acceleration is reduced proportionally. So the fraction of the speed that bleeds off over a fixed time interval will be constant. That means that the speed must decay geometrically. So it can be modeled by a function like v = ce-kt for some constants c and k. You solve the equation by finding values of c and k that fit the givens of the problem (and that is essentially how you solve the differential equation).
Related to Boat slowing down with variable acceleration
1. How does variable acceleration affect a boat's speed?
Variable acceleration refers to a situation where the boat's acceleration is constantly changing. This can either be increasing or decreasing. As a result, the boat's speed will also change, either becoming faster or slower depending on the direction of the acceleration.
2. What factors can cause a boat to slow down with variable acceleration?
Several factors can cause a boat to slow down with variable acceleration. These include changes in wind or water currents, changes in the boat's weight or load, and changes in the boat's direction or angle of movement. Any external force that acts upon the boat can also affect its acceleration and ultimately its speed.
3. How can the boat's acceleration be controlled to maintain a constant speed?
To maintain a constant speed, the boat's acceleration needs to be controlled. This can be achieved by using a combination of the boat's engines, rudder, and sails. Adjusting these components can help to counteract any changes in external forces and maintain a steady acceleration, thus keeping the boat's speed constant.
4. What are the potential dangers of a boat slowing down with variable acceleration?
A boat slowing down with variable acceleration can be dangerous, especially in rough waters. It can make the boat more susceptible to capsizing or being thrown off course. It can also increase the risk of collisions with other boats or objects in the water. Additionally, it can cause discomfort and seasickness for passengers on board.
5. How can the effects of variable acceleration on a boat be minimized?
To minimize the effects of variable acceleration on a boat, it is important to maintain good control over the boat's speed and direction. This can be achieved by regularly adjusting the boat's components, such as the engines, sails, and rudder, to counteract any external forces. It is also important to monitor weather conditions and avoid rough waters if possible.
