MHB Bob's question at Yahoo Answers regarding an indefinite integral
The integral of tan^3(1/z)/z^2 dz can be solved using the substitution u = 1/z, which transforms the integral into -∫tan^3(u) du. By applying the Pythagorean identity, the integral is rewritten and split into two parts: -∫tan(u) sec^2(u) du and ∫sin(u)/cos(u) du. After further substitutions, the final result is expressed as ln|sec(1/z)| - (1/2)tan^2(1/z) + C. This solution provides a clear method for integrating the given function.
MarkFL
MHB
Here is the question:
I need help integrating a Calculus 2 problem?
How do I integrate tan^3(1/z)/z^2 dz
Please show all work and thanks for the help
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Bob,
We are given to integrate:
$$\int\frac{\tan^3\left(\frac{1}{z} \right)}{z^2}\,dz$$
Let's use the substitution:
$$u=\frac{1}{z}\,\therefore\,du=-\frac{1}{z^2}\,dz$$
and the integral becomes:
$$-\int\tan^3(u)\,du$$
Next, let's employ the Pythagorean identity $$\tan^2(x)+1=\sec^2(x)$$, and rewrite the integral as:
$$-\int\tan(u)\cdot\tan^2(u)\,du=-\int\tan(u)\left(\sec^2(u)-1 \right)\,du=-\int\tan(u)\sec^2(u)-\tan(u)\,du=$$
$$\int\frac{\sin(u)}{\cos(u)}\,du-\int\tan(u)\sec^2(u)\,du$$
On the first integral, use the substitution:
$$v=\cos(u)\,\therefore\,dv=-\sin(u)\,du$$
On the second integral, use the substitution:
$$w=\tan(u)\,\therefore\,dw=\sec^2(u)\,du$$
And now we have:
$$-\int\frac{1}{v}\,dv-\int w\,dw=-\ln|v|-\frac{w^2}{2}+C$$
Back-substituting for $v$ and $w$, we have:
$$\ln|\sec(u)|-\frac{1}{2}\tan^2(u)+C$$
Back-substituting for $u$, we have:
$$\ln\left|\sec\left(\frac{1}{z} \right) \right|-\frac{1}{2}\tan^2\left(\frac{1}{z} \right)+C$$
Hence, we may state:
$$\int\frac{\tan^3\left(\frac{1}{z} \right)}{z^2}\,dz=\ln\left|\sec\left(\frac{1}{z} \right) \right|-\frac{1}{2}\tan^2\left(\frac{1}{z} \right)+C$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
