Bodies of mass near the Schwarzschild Radius
In summary, bodies of mass that approach and get near a certain value, such as in neutron stars or black holes, experience intense pressures that cause protons and electrons to condense into neutrons. Further collapse is prevented by degeneracy pressure, and if the remnant mass is more than 3 Solar masses, a black hole may form. These super dense bodies are not very useful for storing energy as the pressure cannot be recovered, but rotational energy can be obtained from them. As for compressing a small amount of matter, it is unlikely to result in useful energy generation as the physics begin to change at the radius where atoms start fusing.
Locke H
What happens to bodies of mass as they approach and get near this value?
If they don't actually reach the criteria, will their properties be vastly different from bodies that do reach the criteria? Will it expand instead of maintain it's radius?
I'm also wondering how much energy it takes to compress a body down to this radius. I would imagine that at some point during the compression, the body loses all of it's material properties and needs to be treated more like a soup of atoms, so the actual material used doesn't really matter.
I noticed this thread was moved to special and general relativity, but I was actually particularly interested in what the condensed matter guys would have to say about extreme compression of matter.
I'm working on elements for a novel and was looking to make an educated representation of what would happen should we use compressed matter as a form of storing massive amounts of mechanical energy (like compressed air, but using other states of matter compressed down to a soup of extremely high density).
The only local things that someone approaching the event horizon notices are tidal forces. So, the way the question is worded, there isn't anything for the condensed matter people to answer.
Possibly you meant what happens when you approach the central sigularity, or possibly you are confused about the nature of the event horizon. It's hard to tell at this point.
When a star runs out of fuel it collapses in a supernova explosion often leaving a dense central body. If the remnant body has insufficient mass to form a black hole (less than 2 or 3 Solar masses) one of the types of bodies formed is a neutron star. Normal atoms are made up of neutrons, protons and electrons and the ratios of these particles determine the identity and properties of the atoms. With the intense pressures (16×10^34 Pa) in a neutron star protons and electrons condense into neutrons and it is impossible to identify the constituent atoms that collapsed to form the neutron star. Further collapse is prevented by degeneracy pressure that in loose terms prevents individual neutrons occupying the same place. The density of these stars are tremendous but they are not necessarily the most dense objects in the universe. It is thought that slightly more massive stars may form more exotic bodies such as quark stars or strange stars but observational evidence for these are sketchy. See http://en.wikipedia.org/wiki/Neutron_star If the remnant mass is more than about 3 Solar masses it is thought that degeneracy pressure is insufficient to prevent total collapse and a black hole forms.
Normally pressure is a good way to store energy and the energy can be recovered by releasing the pressure. The pressure in massive bodies such as neutron stars is not so useful as a store, because we cannot recover the pressure by switching gravity off. A huge amount of energy is however released during the collapse. If you had sufficient matter to make a neutron star you would be better off making a normal star which will kindly produce nuclear fusion energy for you for a long time. If the massive body has angular momentum that can be used to store energy and rotational energy can in principle be recovered. A certain amount of energy can be obtained from these super dense bodies by dropping waste material onto them as the falling matter releases large quantities of electromagnetic radiation as it falls.
Ah, I see. My picture of what happens near the event horizon wasn't very complete to begin with so I wasn't quite aware of how to approach the question. But you're right, at these pressures, since only the constituent atoms have any relevance to the body's behavior, I would imagine it to be very difficult to think of it as condensed matter.
The pressure in massive bodies such as neutron stars is not so useful as a store because we cannot recover the pressure by switching gravity of.
This points me in the right direction, thanks. I was originally imagining what would happen if you took a relatively minuscule amount of matter (say several cubic meters of water, so long the compressed radius is greater than a Planck length), and compressed it down to it's Schwarzschild radius. I would imagine micro black holes to not be of much use towards energy generation, even in a sci-fi setting.
But here's the part I figured the compressed matter guys could answer, where I didn't properly present the question: What if a cubic meter of water were compressed to something extremely small (around 99% of it's original size), nowhere near the radius where atoms start fusing and the physics begin to change.
Sorry if I come off as a bit uninformed, I'm still reading through the material and really appreciate your help pointing me in the right direction :)
As a Mech E, some of this material isn't very native to our coursework.
Related to Bodies of mass near the Schwarzschild Radius
1. What is the Schwarzschild Radius?
The Schwarzschild Radius is a measure of the size of the event horizon of a black hole. It is the distance from the center of the black hole at which the escape velocity exceeds the speed of light. Beyond this radius, no object can escape the gravitational pull of the black hole.
2. How is the Schwarzschild Radius related to the mass of a black hole?
The Schwarzschild Radius is directly proportional to the mass of a black hole. The more massive the black hole, the larger its event horizon and therefore, the larger its Schwarzschild Radius.
3. Can objects near the Schwarzschild Radius escape the black hole's gravitational pull?
No, objects near the Schwarzschild Radius cannot escape the black hole's gravitational pull. The escape velocity at this radius is equal to the speed of light, making it impossible for any object, including light, to escape.
4. What happens to time and space near the Schwarzschild Radius?
Time and space near the Schwarzschild Radius are heavily distorted by the immense gravitational pull of the black hole. Time appears to slow down, and space appears to be compressed. This phenomenon is known as gravitational time dilation.
5. How is the Schwarzschild Radius calculated?
The Schwarzschild Radius can be calculated using the formula Rs = 2GM/c^2, where G is the gravitational constant, M is the mass of the black hole, and c is the speed of light. This formula was derived by German physicist Karl Schwarzschild in 1916.
17K
17K
