How Do You Calculate the Bohr Radius for a Helium Ion?
In summary, the atomic radius for a singly ionized He+ atom in the n = 1 (ground) state and the n = 2 (first excited) state is r = 1.11 Å. The emitted photon when an electron transitions from the n = 2 to the n = 1 state has a wavelength of 687.1 nm.
leroyjenkens
616
49
Using the Bohr model, find the atomic radius for a singly ionized He+ atom in the n =
1 (ground) state and the n = 2 (first excited) state. Then find the wavelength of the
emitted photon when an electron transitions from the n = 2 to the n = 1 state.
[tex]a_0 = \frac{4∏e_0h^2}{me^2}[/tex]
m = mass of the electron
h = h bar. Reduced Planck's constant
e = elementary charge
I need some way of adding a proton and a neutron to the equation, but there's no such variable. I can't find any equation relating to the Bohr radius that isn't just constants. The Borh model can supposedly give you the radius of a helium cation, but that's the only equation I can find and it's all constants.
The Bohr model proceeds in two steps. First, you solve for the velocity as a function of the radius assuming the Coulomb force provides the radial acceleration. Second, you impose that the angular momentum be quantized. This then determines a discrete set of allowed radii and energies.
Among these physical ingredients, how does single ionized Helium differ from Hydrogen? For example, the mass of the hydrogen atom plays no role in Bohr's model (which assumes the nucleus is infinitely anyway), so the presence of a neutron which doesn't interact electrostatically should be irrelevant. What other differences are there?
Don't mix LaTeX with [noparse] and [/noparse] tags. Use _ and ^. Corrected that for you.
Helium has a greater positive charge, so the nucleus going to pull on the lone electron stronger than the hydrogen nucleus would, which will make the radius smaller.
I'm looking through the equations in this book and I have...
[tex]v=\frac{nh}{mr}[/tex]
h = h bar
[tex]r = n^{2}a_0[/tex]
a0 = Bohr radius
[tex]v = \frac{nh}{mn^{2}a_{0}}[/tex]
The book doesn't say what r stands for, but it's part of the angular momentum equation L = mrv, so it must be radius of the electron orbit, which is just the radius of the atom.
So the radius of the atom is r, but isn't that what the Bohr radius is supposed to be?
The formula for a0 is...
[tex]a_{0}=\frac{4∏ε_{0}h^{2}}{me^{2}}[/tex]
So I'm guessing the key has to do with the e2 in the denominator, since the charges of the hydrogen and helium are different.
Don't mix LaTeX with and tags. Use _ and ^. Corrected that for you.
Thanks, was wondering why it wasn't working.
Do what Physics Monkey suggested. Start with F=ma and ##mvr=n\hbar## to find what you need.
Related to How Do You Calculate the Bohr Radius for a Helium Ion?
1. What is the Bohr radius of a helium ion?
The Bohr radius of a helium ion is a physical constant that represents the average distance between the nucleus and the electron in a helium ion in its ground state. It is approximately 0.529 Å (angstroms) or 5.29 x 10^-11 meters.
2. How is the Bohr radius of a helium ion calculated?
The Bohr radius of a helium ion is calculated using the Bohr model of the atom, which takes into account the mass, charge, and energy of the particles involved. The formula for calculating the Bohr radius is: a0 = (4πε0ħ^2)/(mze^2), where a0 is the Bohr radius, ε0 is the permittivity of free space, ħ is the reduced Planck's constant, m is the mass of the electron, z is the atomic number, and e is the elementary charge.
3. What is the significance of the Bohr radius of a helium ion?
The Bohr radius of a helium ion is significant because it helps us understand the structure and behavior of atoms. It is also used in various calculations related to atomic systems, such as the energy levels and wavelengths of spectral lines.
4. Can the Bohr radius of a helium ion change?
No, the Bohr radius of a helium ion is a physical constant and does not change. However, the distance between the nucleus and the electron can change depending on the energy level of the electron.
5. How does the Bohr radius of a helium ion compare to other atomic radii?
The Bohr radius of a helium ion is relatively small compared to other atomic radii. For example, the Bohr radius of a hydrogen atom is twice as large as the Bohr radius of a helium ion. The Bohr radius also decreases as the atomic number increases, reflecting the increasing attraction between the nucleus and the electrons in heavier atoms.
