Boiling a glass of water in a bowl of water - tricky question?
In summary, an insulating glass with a double-shell will prevent the water in the bowl from cooling down, leading to two boiling points.
Physics Slayer
A glass of water is placed in a bowl of water, each are filled till the brim, the glass of water floats in the bowl. The bowl is heated, when will the water in the glass boil? before/after/same time as the water in the the bowl.
no equations
I think the water in the bowl of water will boil first because the glass won't conduct the heat instantaneously, and hence the water in the glass will boil after the water in the bowl. Is this correct?
I am guessing this is a trick question and the water in both boil at the same time, but I don't see how that would be possible.
(I don't know the correct answer)
or is it that both will boil at the same time because change of state happens at a constant temp. and as long as the water in the glass is not at 100deg C, the water in the bowl will keep cooling down by loosing heat to the water in the glass and hence only when they are both at the same temp. the water will be able to boil from the bowl and along with that from the glass as well. does this reasoning make sense?
That's a good trick right there considering that the density of glass is higher than that of water.
Likes berkeman and Steve4Physics
So clearly the glass is one of those insulating glasses with a double shell and an air space in between. (I have two.) That should settle the question.
  • Haha
Likes Physics Slayer and Steve4Physics
Uh huh. You really think that's what the OP had in mind? :smile:
@haruspex’s (amusing) reply in Post #4 highlights a useful general 'trick' for some problems.
Imagine what would happen in an extreme case. So here, imagine the ‘glass’ is not simply a poor thermal conductor, but is an extremely poor conductor.
Likes PeroK
Like a vacuum. And then we could put areflective coating on the glass!
The point here is (I think) that temperature is really only well defined for a system at equilibrium. The system defined is being heated and might be in steady state but it is not in equilibrium. Perhaps subsections of it can rou8ghly equilibrate
A pal of mine went ahead and actually did the experiment and found out that they infact do not boil at the same time. He actually put a small bowl(made of steel) in a larger bowl(again made of steel)
Whenever I face questions like this where you can't really apply equations(can you?) I don't see a straightforward method of solving the problem do I just rely on Intuition?(which really just feels like guess work with extra steps)
Likes hutchphd
Fluids heat by convection and conduction. An internal boundary will interfere with convection. The internal boundary will take a finite amount of time to reach the bath temperature, so the fluid inside of it will also see a time lag. So the fluid in the inner area will boil later.
I am guessing that convection is the larger effect, so it would be an interesting experiment if the small steel bowl was replaced by foil.
If one cleans the inner surface of the outer bowl and the outer surface of the inner glass well and uses distilled water in the outer bowl but ordinary tap water in the inner bowl then it ought to be possible to get the inner glass to boil first. That would be a mildly amusing parlor trick.
But back to the situation at hand.
How does the rate of heat transfer change as the inner reservoir heats up toward the boiling point? Can two reservoirs in thermal contact ever equilibriate in finite time?
or maybe the other way round? In any case the difference in boiling points is so small it would be very difficult to achieve in practice.
Where we must assume that the boiling point of the water inside the glass is identical to that of the water outside the glass.
In this case you only need to consider this:
to know the answer, although there is another reason that is more important in practice.
Impurities raise the temp a couple of degrees. You could cheat and dissolve salt/sugar. I do not know which is better.
Homework Statement:: A glass of water is placed in a bowl of water, each are filled till the brim, the glass of water floats in the bowl. The bowl is heated, when will the water in the glass boil? before/after/same time as the water in the the bowl.
Relevant Equations:: no equations
Both they will boil in the same Temperature but different Time.
There is an equation (related to thermal conductivity) that can be used. But using it would be an unnecessarily complicated way to solve a simple problem like this
One of my first physics lessons at school (aged 11, many years ago) involved a demo’ showing us that conduction of heat takes time. Something like this (turn the sound down and skip through it).:
Knowing this, and that water must be heated to 100ºC to boil (at atmospheric pressure), you can answer the question with only simple logic.
You will get the right answer by looking at conduction, but for the wrong reason. Convection is much more significant than conduction when boiling a liquid in an open pan.
Likes Steve4Physics
Good point. So the glass acts as a barrier to limit convection (as well as its less significant conduction effect).
Would that mean even some sort of 'ideal' perfectly conducting glass will reduce the overall rate of heat transfer to the water in the glass? I guess so.
No matter what, it's the same answer whether the section you're studying concerns heat transfer, specific/latent heats, or sous vide cooking.
Could you link the wiki page for the equation you talk about, even though I might not have the math background yet, I would absolutely love to have a curious glance at it!
Lack of nucleation points raises the temperature a fair bit more.
The fluid furthest away from the heat source is coolest, boils last.
Do you have a number? I cannot seem to find one.
I would think the boundary would put an upper limit to the value. I believe that superheating occurs in a microwave because the container acts as a heat sink while the bulk is heated. For the geometry of this thread, the hottest part is the bottom of the bowl (which is why you suggested cleaning it).
I’m no expert so I can only give a few pointers on the maths (and only considering conduction, not convection).
Heat transfer by conduction is governed by Fourier’s Law (also referred to by other names such as Fourier’s Heat Equation). E,g, see: https://en.wikipedia.org/wiki/Thermal_conduction#Fourier's_law
This is simply a starting point. In your problem, the temperatures are changing; we say we are not in a ‘steady state’. The process of heat-transfer while temperatures change is called ‘transient heat transfer’ and makes applying Fourier’s law much harder.
For a general (non-mathematical) description of transient heat conduction try this: https://en.wikipedia.org/wiki/Thermal_conduction#Transient_conduction
For some mathematics (with one of the temperatures kept constant - a much simpler situation than your glass problem) try this (a pdf file):
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwj6t7nCj9_1AhWPY8AKHbeeBjMQFnoECDEQAQ&url=https://www.sfu.ca/~mbahrami/ENSC%20388/Notes/Transient%20Heat%20Conduction.pdf&usg=AOvVaw3_Zc-t9iwQqQM8ZaUdWSBE
FAQ: Boiling a glass of water in a bowl of water - tricky question?
Can you really boil a glass of water in a bowl of water?
Yes, it is possible to boil a glass of water in a bowl of water. This is because the boiling point of water remains the same regardless of the container it is in.
How does the glass not break when boiling in water?
The glass does not break because the water surrounding it helps to distribute the heat evenly, preventing any one spot from getting too hot and causing the glass to break.
Is it safe to boil a glass of water in a bowl of water?
As long as the glass is heat-resistant and there are no cracks or chips in the glass, it is safe to boil a glass of water in a bowl of water. However, it is important to handle the hot glass with caution to avoid burns.
Will the water in the bowl boil faster with the glass inside?
No, the presence of the glass will not affect the boiling time of the water in the bowl. The boiling time is determined by the amount of water and the heat source, not by the presence of the glass.
Can I use any type of glass to boil in water?
No, it is important to use a heat-resistant glass, such as borosilicate glass, when boiling in water. Other types of glass may not be able to withstand the high temperatures and could break or shatter.
