What Happens to dU, dQ, and dW During Boiling?
In summary, during boiling, dU is positive as the particles gain more energy and dQ is also positive as heat flows into the system. The value of dW depends on the conditions of boiling, but it can be positive if the steam does work against the surrounding air. In a closed volume, dW would be 0, but dU and dQ would still be positive. The difference between the internal energy of water and steam is known as the "latent heat."
prasannaworld
Boiling Internal Energy - URGENT
A quick question:
dU = dQ - dW
What are dU, dQ and dW during Boiling?
I thought:
-the particles do work, hence dW is +
-dU increases as particles gain more energy
so dQ = dU + dW - showing that heat flows in. Which made sense to me.
Or is Boiling Isothermal?
It is difficult to say, because you didn't specify the way things boil. First of all, you shouldn't look at *microscopic* work ("the particles do work"). The whole idea of thermodynamics is that we can take abstraction from any microscopic model. So if you boil water in an open kettle, then yes, the steam does work: it pushes away the air that was there, at 1 atmosphere. You can picture this by considering the boiling water in a cylinder with a piston. The steam will push the piston out, doing work against the pressure of the air.
However, there's another change too. The internal energy of steam is larger than the internal energy of liquid water at the same temperature. So dU is positive (liquid water (lower U) changes into steam (higher U)). dW is positive (the system DOES work on the air), and of course, dQ is positive (heat is given to the system).
If the water is in a closed volume, then the steam doesn't do any work. So now, dW is 0. But dU is still positive (the change in internal energy between water and steam). And dQ remains positive (we're heating the water).
The difference between the U of water and the U of steam is called the "latent heat".
Hi there,
Thank you for reaching out with your question about boiling internal energy. Let me try to provide some clarification for you.
First, let's define dU, dQ, and dW. dU represents the change in internal energy of a system, dQ represents the heat added or removed from the system, and dW represents the work done by or on the system.
During boiling, the particles are gaining energy as they are heated, so dU will increase. The heat added to the system, dQ, will also be positive since heat is flowing into the system. However, the work done, dW, can be either positive or negative depending on the specific conditions.
If the system is in a closed container, the work done will be negative as the particles are doing work on the container's walls as they expand. This can also be seen in the equation dU = dQ - dW, where dW is subtracted from dQ.
If the system is in an open container, the work done will be positive as the particles are expanding and pushing against the atmosphere. In this case, the equation would be dU = dQ + dW, where dW is added to dQ.
In terms of whether boiling is isothermal or not, it depends on the specific conditions. In an isothermal process, the temperature of the system remains constant. In boiling, the temperature of the liquid remains constant until all of the liquid has turned into vapor. However, the temperature of the vapor may change depending on the pressure and other factors.
I hope this helps clarify things for you. If you have any further questions, please don't hesitate to ask. Best of luck with your studies.
Related to What Happens to dU, dQ, and dW During Boiling?
1. What is boiling internal energy?
Boiling internal energy refers to the energy that a substance possesses when it is at its boiling point, the temperature at which it changes from a liquid to a gas. This energy is necessary to overcome the intermolecular forces between the molecules of the substance and allow it to change phase.
2. How is boiling internal energy related to temperature?
Boiling internal energy is directly related to temperature. As the temperature of a substance increases, so does its internal energy. This is because at higher temperatures, the molecules of the substance have more kinetic energy and can overcome the intermolecular forces more easily, resulting in a phase change.
3. What factors affect the boiling internal energy of a substance?
The boiling internal energy of a substance is affected by its mass, specific heat capacity, and latent heat of vaporization. The mass and specific heat capacity determine how much energy is needed to raise the temperature of the substance, while the latent heat of vaporization is the amount of energy required for the substance to change from a liquid to a gas.
4. How is boiling internal energy measured?
Boiling internal energy can be measured using various devices, such as a calorimeter or a bomb calorimeter, which measure the heat absorbed or released during a phase change. It can also be calculated using the specific heat capacity and latent heat of vaporization of the substance.
5. Why is understanding boiling internal energy important?
Understanding boiling internal energy is important in various industries, such as cooking, chemical processes, and energy production. It also plays a crucial role in weather phenomena, such as evaporation and condensation, and is essential for understanding the behavior of substances in different environments.
  • Thermodynamics
  • Materials and Chemical Engineering
