Boiling Water Sounds: Exploring What's Going On
In summary, when boiling water, there are pinging sounds that grow louder until there is some sort of phase transition and they quiet down. That's about when the tea kettle starts to whistle.
Hornbein
2,654
2,221
I boil water in a tea kettle. When it's starting to boil there are pinging sounds. These grow louder until there is some sort of phase transition and they quiet down. That's about when the tea kettle starts to whistle. What's going on?
Chemistry news on Phys.org
Yes, that's how it goes. I don't have a real answer, only a guess: it is related to the water degassing (solubility of gases goes down with the temperature) and size/presence of the bubbles in water (which change the way sound propagates in water).
Likes sophiecentaur
As far as I know it's about small, local bubbles of steam popping up and then collapsing when cooling down due their expansion and rise. Kind of like (mechanical) cavitation, just different reason.
When the energy available is finally enough to keep the bubbles going it quiets down (and start boiling).
To make coffee I pour a cup of water into the tea kettle and boil that. In this case the boiling doesn't quiet down, instead it gets louder. I (infer?deduce?) that the pinging sound comes from bubbles detaching from the metal surface of the kettle. If the water is deep enough then most of the later bubbles form away from the surface. If the water is shallow then most of the bubbles continue to detach from the metal.
It seems to me that there are at least two factors here. De-gassing takes place at relatively low temperatures (singing kettle due to many small bubbles) and actual boiling will happen at around 100C. The rate of boiling, after 100C, will depend on the power supplied and the noise will depend on the specific surface and even details of thermal contact between element and water. 'Bumping' is the descriptive term for what you can get under some conditions. Also, the size of a typical kettle can give resonances to the sound inside it and sound louder for some kettles than others
Your small mass of water probably goes quickly through the stages. A kettle full of water (or even an urn) can produce the different effects at noticeably different times. I notice our kettle starts of (a few seconds after switch on) with distinct 'cracking' sounds for a short time, particularly with freshly drawn water.
You should take care, here. You could get addicted to the sounds plus the taste of coffee/.
  • Haha
Likes Tom.G
FAQ: Boiling Water Sounds: Exploring What's Going On
What causes the sound when water boils?
The sound produced when water boils is primarily due to the formation and collapse of bubbles. As water heats up, bubbles of steam form at the bottom of the pot and rise to the surface. These bubbles collapse when they reach cooler water, creating noise. Additionally, the movement of water and bubbles contributes to the overall sound.
Why does the sound change as water gets hotter?
The sound changes as water gets hotter because the size, frequency, and behavior of the bubbles change. Initially, small bubbles form and collapse quickly, making a higher-pitched sound. As the water temperature increases, larger bubbles form and rise more rapidly, creating a lower-pitched, more consistent sound until it reaches a rolling boil.
Can the type of pot affect the boiling water sound?
Yes, the type of pot can affect the sound of boiling water. Factors such as the material of the pot, its thickness, and shape can influence how sound waves are produced and transmitted. For instance, a thin metal pot may produce a sharper, louder sound compared to a thick, heavy-bottomed pot which might muffle the sound.
Is the sound of boiling water a reliable indicator that it's ready for cooking?
The sound of boiling water can be a useful indicator, but it is not always precise. While the change in sound can signal that water is reaching a boil, it is better to visually confirm that the water is at a rolling boil, especially for tasks that require precise temperatures, such as cooking pasta or sterilizing equipment.
Why does boiling water sound louder just before it starts to boil vigorously?
Boiling water sounds louder just before it starts to boil vigorously because of the increased activity of bubble formation and collapse. As the water temperature approaches its boiling point, bubbles form more rapidly and in greater numbers. The collapse of these bubbles creates more noise, making the sound louder until it reaches a steady rolling boil.
