Bolt screw shear strength calculations
In summary, the conversation discusses the proper way to calculate if given screws and nuts can withstand the load of an electric motor and the momentum it creates. It is important to ensure that the bolts only act in tension and create enough frictional force to carry the loads. The suggested method includes finding out the strength of the screws and the friction coefficient between the mounting flanges to determine the frictional force. If this force is greater than the weight and torque of the motor, as well as other factors and a safety factor, then there should be no issues.
dislect
166
Hi guys,
I have an electric motor that comes with a flange to be bolted on a plate horizontally so that the 4 screws carry the weight of the motor and the momentum it creates on them.
Could you direct me to how to calculate if the given screws and nuts stand up to the load?
Perhaps an example of a solution to such problem to learn from?
Thank you,
Sharon
The bolts should act only in tension. They should create sufficient frictional force between the flanges, and this frictional force should fully carry the actual loads. If the loads are enough to overcome this frictional force, then there will be relative movement between the flanges, and the bolts will loosen and the whole thing will fail.
I would first find out how strong the screws are and how much force they can exert when fully tightened. This is a google search away. Also, I would find out the friction coefficient between the mounting flanges. From this you can figure the frictional force between flanges.
If this frictional force is greater than the weight of the motor, plus the torque of the motor, plus other effects (such as the fact that the motor appears to be cantilevered), and a safety factor, then there should be no problems.
Related to Bolt screw shear strength calculations
What is bolt screw shear strength?
Bolt screw shear strength is the maximum amount of force that a bolt or screw can withstand before it breaks or shears. It is an important factor to consider when designing and constructing structures, as it ensures the safety and stability of the building.
How is bolt screw shear strength calculated?
The calculation of bolt screw shear strength involves several factors such as the material properties of the bolt and the joint, the diameter and length of the bolt, and the applied load. It is typically determined using engineering equations and standards such as the American Institute of Steel Construction (AISC) Manual.
What are the most common materials used for bolts and screws?
The most common materials used for bolts and screws are steel, stainless steel, and titanium. These materials offer high strength and durability, making them suitable for various applications. The specific grade and composition of the material also play a role in determining its shear strength.
How does the length of a bolt affect its shear strength?
The length of a bolt can significantly impact its shear strength. Longer bolts have a higher shear strength compared to shorter bolts because they have a larger cross-sectional area. This means they can withstand more force before breaking or shearing.
Are there any factors that can affect the accuracy of bolt screw shear strength calculations?
Yes, there are several factors that can affect the accuracy of bolt screw shear strength calculations. These include the quality and consistency of the materials used, the precision of the measurement tools, and any external factors such as temperature and corrosion. It is important to consider all these factors in order to obtain accurate shear strength calculations.
  • Mechanical Engineering
