Boltzmann Distribution and microstate probabilities
In summary, the canonical ensemble considers a system of interest placed in a larger "heat bath" with which it can exchange energy. This results in some microstates of the system being more probable than others. By defining the entropy and using the approximation that most of the energy will be found in the heat bath, we can calculate the probability of a specific microstate in the small system, which is proportional to the number of states of the composite system with the same total energy and subsystem energy.
I_laff
41
For a canonical ensemble the probability of occupying a certain microstate varies depending on the energy, however I thought that every microstate has an equal chance of being occupied. So what part of the canonical ensemble have I misunderstood?
If you were to consider the system plus the environment, you would find that all microstates of the total are still equally probable. But when you focus on the system only, you finds that some of its microstates are more probable than others.
Likes I_laff
One common way to motivate the canonical ensemble is to consider the system of interest to be placed into a much larger system, the "heat bath", with which it is allowed to exchange energy. Then if we let ##W(E)## be the number of microstates for the composite system with total energy ##E##, we can calculate it this way:
##W_{total}(E) = \sum_{\varepsilon} W_{hb}(E-\varepsilon) W_{s}(\varepsilon)##
where ##W_{hb}(E-\varepsilon)## is the number of microstates of the heat bath with energy ##E-\varepsilon## and ##W_s(\varepsilon)## is the number of microstates of the system of interest with energy ##\varepsilon##, and where ##W_{total}(E)## is the number of states of the composite system. Letting the entropy ##S## be defined via: ##S = k \ln W##, we have:
##e^{S_{total}/k} = \sum_{\varepsilon} e^{(S_{hb}(E - \varepsilon) + S_{s}(\varepsilon))/k}##
At this point, we assume that since the heat bath is much larger than the system of interest, most of the energy will be found in the heat bath. Then we can make the approximation:
##S_{hb}(E - \varepsilon) \approx S_{hb}(E) - \dfrac{\partial S_{hb}}{\partial E} \varepsilon##
Thermodynamically, ##\dfrac{\partial S_{hb}}{\partial E} \equiv \dfrac{1}{T_{hb}}## where ##T_{hb}## is the temperature of the heat bath. So we can write:
##e^{S_{total}/k} = e^{S_{hb}/k} \sum_{\varepsilon} e^{- \varepsilon/(kT)+ S_{s}(\varepsilon))/k}##
The probability of the small system having energy ##\varepsilon## (given that the total energy is ##E##) is proportional to the number of states of the composite system with total energy ##E## and subsystem energy ##\varepsilon##:
##P(E,\varepsilon) \propto e^{- \varepsilon/(kT)+ S_{s}(\varepsilon))/k} = e^{- (\varepsilon - S_{s} T)/(kT))}##
Likes vanhees71 and anorlunda
Related to Boltzmann Distribution and microstate probabilities
1. What is the Boltzmann Distribution?
The Boltzmann Distribution is a statistical concept in physics that describes the distribution of particles in a system at a given temperature. It is based on the idea that particles will be distributed among different energy levels according to the laws of thermodynamics.
2. How is the Boltzmann Distribution related to microstate probabilities?
The Boltzmann Distribution is closely related to microstate probabilities because it describes the probability of a particle occupying a specific energy level in a system. This probability is determined by the number of microstates (or possible arrangements of particles) that correspond to that energy level.
3. What factors influence the Boltzmann Distribution?
The Boltzmann Distribution is influenced by two main factors: temperature and energy levels. As temperature increases, the distribution shifts towards higher energy levels, and as energy levels increase, the distribution becomes more spread out.
4. How is the Boltzmann Distribution used in practical applications?
The Boltzmann Distribution is used in many practical applications, such as in thermodynamics, statistical mechanics, and quantum mechanics. It is also used in fields such as chemistry, biology, and engineering to understand and predict the behavior of systems at the microscopic level.
5. Can the Boltzmann Distribution be applied to all types of systems?
The Boltzmann Distribution can be applied to a wide range of systems, including gases, liquids, solids, and even complex biological systems. However, it may not be applicable to systems that do not obey the laws of thermodynamics, such as systems with non-equilibrium conditions or systems with strong quantum effects.
  • Classical Physics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
