Uniquebum
- 55
- 1
Solve the Boltzmann equation for a homogeneous plasma with not external forces present when the collision term is
[itex]\frac{\partial f(v,t)}{\partial t} = -\nu (f(v,t) - f_0(v))[/itex],
where [itex]\nu[/itex] and [itex]f_0[/itex] are constants.
Boltzmann equation
[itex]\frac{\partial f}{\partial t} + v\cdot \nabla f + a \cdot \nabla_v f = -\nu (f(v,t) - f_0(v))[/itex]
where [itex]\nabla_v f[/itex] is the gradient of f in respect to vx, vy and vz.
Right, first off, I'm assuming that [itex]v \cdot \nabla f = 0[/itex] since in the collision term it claims that the function f(v,t) doesn't depend on x. This follows that
[itex]\frac{\partial f}{\partial t} + a \cdot \nabla_v f = -\nu (f(v,t) - f_0(v))[/itex]
After this i'd assume that the function can be represented as [itex]f(v,t)=g(v)h(t)[/itex]
Now with a little algebra we can get the equation in the form of
[itex]\frac{1}{h(t)}\frac{\partial h(t)}{\partial t} + \nu = \nu \frac{f_0(v)}{g(v)} - \frac{1}{g(v)}a \cdot \nabla_v g(v) = constant = \lambda[/itex]
Now i have a pair of equations and calculating h(t) is fairly simple
[itex]\frac{1}{h(t)}\frac{\partial h(t)}{\partial t} + \nu = \lambda[/itex]
which by integrating leads to
[itex]h(t) = Ce^{(\lambda - \nu)t}[/itex] where C is the integration constant.
However, solving the other equation (below) is a bit harder
[itex]\nu \frac{f_0(v)}{g(v)} - \frac{1}{g(v)}a \cdot \nabla_v g(v) = \lambda[/itex]
I can guess the solution to this would be
[itex]g(v) = e^{(\lambda/a)v}+\nu \frac{f_0(v)}{a}+D[/itex] where D is again some constant.
And as stated before, connecting the two solutions like [itex]f(v,t)=g(v)h(t)[/itex], would give the answer... maybe.
Now the problem is, i have no clue if this correct or even close to the solution. Could anyone check if I'm correct and if not (which is very likely), where have i messed up and how could i do the calculation right?
