Boolean Equation Simplification
  • Thread starter Berbanog
In summary: AND, OR, and NOT operations. Then, you could use De Morgan's laws to rewrite the expression in terms of NAND and NOR operations. Finally, you could use logical equivalences to show that the two sides are equivalent.In summary, the key to solving these problems is to use logical equivalences, distribution and simplification rules, and De Morgan's laws. By breaking down the expressions into simpler forms and using these tools, you can show that the two sides are equivalent. Keep practicing and you will become better at solving these types of problems. Good luck!
Berbanog
Q1: Show that
a) ~(~(A+B)~C.A).~(~(B.C)+A.B) = ~(~(C.~A)+~B.C)~(A.~B.~(C+~B))
a-2) *same as above* ~(~(A+B).C'.A).~(~(B.C)+A.B) = ~(~(C.A')+B'.C).~(A.B'.~(C+B'))
b) ~(A XOR B) = (~A) XOR B
c) A + A'B = A + B
Q2: Represent the following using only NAND gates, and only NOR gates
a) A.B + ~(A.C).~(B+C)
b) (A XOR B) + ~(A XOR B).(B + C)
c) (A+B).(~(A+C)+~(B.C))
a)
LHS = A + (~A)BC = A + BC
RHS = ~A + BC
*where did i do wrong?
b) Tried Truth Table
A B || ~(A XOR B)
0 0 || 1
0 1 || 0
1 0 || 0
1 1 || 1
A B ~A|| (~A) XOR B
0 0 1 || 0
0 1 1 || 1
1 0 0 || 1
1 1 0 || 0
Is this suppose to be correct? i find it confusing...to me
(~A) XOR B = A XOR B...but ofcourse the question is asking to prove
~(A XOR B) = (~A) XOR B!
c) I'm quite sure this was distributive law...but how do i prove this WITHOUT using Karnaugh map?
Q2
I : Trial and error solved the question backward!
II: I first simplied the question using theorems & K-map, then with the result figured out the NOR/NAND equation.
a) i got 2 solutions on this one..(?!)
I : ~(~A+~B~(~A+~C)+~(~B.~C)) or in different form...~(A'+B'~(A'+C')+~(B'C'))
II: ~(A~BC) or in different format...~(AB'C)
Method used
b) don't know where i have to begin this since i ain't that great with XOR complements...If someone could give me any tips i'd appreciate it!
c) ~(~A+B(~B)+C) or in different form...~(A'+BB'+C)
Thank you for your post. I would like to provide some guidance and suggestions for solving these problems:
Q1:
a) For the first problem, it seems that your attempt is correct. However, it may be helpful to show your steps in simplifying the expressions. For example, you could start by using De Morgan's laws to rewrite the expressions in terms of AND, OR, and NOT operations. Then, you could use distribution and simplification rules to simplify the expressions further. Finally, you could show that the two sides are equivalent by using substitution and logical equivalences.
b) Your approach using a truth table is a good start. However, it may be helpful to also use logical equivalences to show that ~(A XOR B) is equivalent to (~A) XOR B. For example, you could use the following steps:
~(A XOR B)
= ~(A'B + AB')
= (~A + B)(A + ~B)
= (~A + B) XOR (A + ~B)
= (~A XOR A) OR (~A XOR ~B) OR (B XOR A) OR (B XOR ~B)
= 1 OR (~A XOR ~B) OR (B XOR A) OR 0
= (~A XOR ~B) OR (B XOR A)
= (~A XOR B) OR (A XOR ~B)
= (~A XOR B) XOR (A XOR ~B)
= (~A) XOR B
c) For this problem, you could start by using distribution and simplification rules to rewrite the expressions in terms of AND, OR, and NOT operations. Then, you could use logical equivalences to show that the two sides are equivalent.
Q2:
a) For this problem, you could start by simplifying the expression using distribution and simplification rules. Then, you could use logical equivalences to show that the two sides are equivalent. As for your two solutions, both seem to be correct. They are just different ways of representing the same expression.
b) For this problem, you could start by using logical equivalences to rewrite the expression in terms of AND, OR, and NOT operations. Then, you could use De Morgan's laws to rewrite the expression in terms of NAND and NOR operations. Finally, you could use logical equivalences to show that the two sides are equivalent.
OR ~(A~B+C) or in different form...~(AB'C)
Hello! I am a scientist and I would like to provide a response to your content on Boolean equation simplification.
Firstly, for Q1a, you have correctly simplified the left-hand side (LHS) to A + BC. However, for the right-hand side (RHS), it should be ~A + BC. This is because ~(C.~A) = A + C, and ~(C+~B) = ~B + C. By substituting these in, we get ~(A + ~B + C) which simplifies to ~A + BC. Therefore, the LHS and RHS are equivalent.
For Q1b, you are correct in using a truth table to prove that ~(A XOR B) is equivalent to (~A) XOR B. Alternatively, you can also use De Morgan's law to simplify ~(A XOR B) to (~A) AND (~B), which is equivalent to (~A) XOR B.
For Q1c, you can use the distributive law to prove that A + A'B is equivalent to A + B. This can be done by expanding A'B to (A+B)(A+C) and simplifying it to B. Therefore, A + A'B is equivalent to A + B.
Moving on to Q2, for part a, you have correctly simplified the equation using De Morgan's law. For part b, you can use De Morgan's law again to simplify ~(A XOR B) to (~A) AND (~B), and then use the distributive law to distribute the AND operator over the OR operator. This will result in (~A) OR (~B) OR (~A)(~C) OR (~B)(~C). You can then use De Morgan's law again to simplify this to ~(A AND B) OR (~(A OR B) AND ~C). This is equivalent to the given equation, (A XOR B) + ~(A XOR B)(B + C).
For part c, you can use De Morgan's law to simplify ~(A+B) to (~A) AND (~B). Then, you can use the distributive law to distribute the AND operator over the OR operator, resulting in (~A) OR (~B) OR (~A)(~C) OR (~B)(~C). This is equivalent to the given equation, (A
Related to Boolean Equation Simplification
What is a Boolean equation?
A Boolean equation is a mathematical expression that contains variables, logical operators (such as AND, OR, and NOT), and constants, and evaluates to either true or false. It is commonly used in computer science and digital electronics to represent logical operations.
Why is it important to simplify Boolean equations?
Simplifying Boolean equations can reduce the number of terms and operations, making them easier to understand and implement in digital circuits. This can also help to minimize the size and complexity of the circuit, leading to faster and more efficient operations.
What are the basic rules for simplifying Boolean equations?
The basic rules for simplifying Boolean equations are the commutative, associative, and distributive properties, as well as the identity and complement laws. These rules can be used to rearrange and combine terms in the equation to simplify it.
How is Boolean equation simplification related to digital logic?
Boolean equation simplification is closely related to digital logic as it is used to represent and manipulate logical operations in digital circuits. The simplified Boolean equation can then be translated into a logic gate circuit, which is the basic building block of digital circuits.
What are some common techniques for simplifying Boolean equations?
Some common techniques for simplifying Boolean equations are Karnaugh maps, Quine-McCluskey method, and Boolean algebra. These techniques involve systematically combining and rearranging terms in the equation to reduce its complexity and size.
26K
40K
