Boolean polynomial and logical statement
  • Thread starter zzmanzz
  • Tags
    Polynomial
Your Name]In summary, the given problem involves converting a logical statement into a Boolean polynomial and then simplifying it using Boolean algebraic identities and properties. The extra terms in step 2 are necessary to fully represent the original statement, as the logical operator "if/then" appears twice in the statement. By combining the two "if/then" statements, the correct Boolean formula is obtained.
zzmanzz
54
So my professor wanted us to convert the statement:
[ (p -> q) & (q -> r) ] -> (p -> r)
1. (p -> q) & (q -> r)
= (1 + p + pq)(1 + q + qr)
= (1 + p + q + pq + qr)
2. [ (p -> q) & (q -> r) ] -> (p -> r)
1 + (1 + p + q + pq + qr) + (1 + p + q + pq + qr)(1 + p + pr)
Apparently the last formula is the correct boolean formula ( although it can be simplified.) However, I do not understand why the terms
are added to
My answer in the HW was (1 + p + q + pq + qr)(1 + p + pr) but it was missing the extra terms. Can anyone help me understand why step 1 is the product for the if/then but in step two, also an if then, we have 1 + (1 + p + q + pq + qr) in addition to the if/then product.
Dear student,
Thank you for your post. It is important to understand the reasoning behind the steps in order to fully understand the solution. Let's break down the problem and explain each step.
Step 1:
In this step, you are converting the statement into a Boolean polynomial. This means that you are representing the logical operators using Boolean algebraic expressions. The logical operator "and" is represented by the multiplication symbol in Boolean algebra. So, the statement (p -> q) & (q -> r) becomes (1 + p + pq)(1 + q + qr) because we are multiplying the Boolean expressions (1 + p + pq) and (1 + q + qr) to represent the logical "and" operator.
Step 2:
In this step, you are converting the statement into a Boolean formula. This means that you are simplifying the expression using Boolean algebraic identities and properties. The Boolean expression (1 + p + pq)(1 + q + qr) can be simplified using the distributive law of Boolean algebra, which states that a(b + c) = ab + ac. Applying this law, we get (1 + p + pq + qr) + (q + pq + pqr).
Now, let's look at the original statement, [ (p -> q) & (q -> r) ] -> (p -> r). We can see that the logical operator "if/then" is represented twice in this statement. Once between (p -> q) and (q -> r), and then again between [ (p -> q) & (q -> r) ] and (p -> r). In order to represent the entire statement using Boolean algebra, we need to combine these two "if/then" statements. This is where the extra term 1 + (1 + p + q + pq + qr) comes in. We can rewrite the original statement as (1 + p + q + pq + qr)(1 + p + pr), which is the same as the last formula in your attempt at a solution.
In conclusion, the extra terms in step 2 are necessary to fully represent the original statement using Boolean algebra. I hope this helps to clarify the reasoning behind the steps. Keep up the good work in your studies!
Related to Boolean polynomial and logical statement
1. What is a boolean polynomial?
A boolean polynomial is an algebraic expression that is composed of boolean variables and the operations of AND, OR, and NOT. It can also include constants, such as 0 and 1.
2. How is a boolean polynomial different from a regular polynomial?
Unlike regular polynomials, which have variables that can take on any real number, boolean polynomials have variables that can only take on the values of true or false. Additionally, boolean polynomials use boolean operations instead of traditional arithmetic operations.
3. What is a logical statement?
A logical statement is a statement that can be either true or false. It is composed of one or more boolean variables, and can also include logical operators, such as AND, OR, and NOT.
4. Can a boolean polynomial be used to represent a logical statement?
Yes, a boolean polynomial can be used to represent a logical statement. The variables in the polynomial can represent the boolean variables in the statement, and the operations in the polynomial can represent the logical operators in the statement.
5. How are boolean polynomials and logical statements used in computer science?
Boolean polynomials and logical statements are used in computer science to represent and manipulate boolean values and logical operations. They are especially useful in programming and circuit design, where boolean values are commonly used to represent true and false conditions to control the flow of a program or circuit.
