Boost converter inductor discharging question
In summary, the boost converter uses the inductor as a source, along with the supply voltage, to boost the output voltage. The output reservoir capacitor receives a flow of charge through the inductor each time the switch opens. If the load does not draw sufficient current, the regulator will prevent another switching cycle until it does. This can result in the inductor current falling to zero while waiting. This can also occur when charging a battery from a low voltage supply. By switching the coil to ground at specific intervals, the coil generates a boosted voltage across the load. In operation, with a fixed load, the inductor current will be approximately constant. The load voltage will be delivered as a pulsed voltage, with drops to zero volts in
TheRedDevil18
408
I'm reading up on boost converters and so far I understand that it basically uses the inductor as a source together with the actual supply voltage to boost the voltage. During the discharging period, why would the current (if allowed to) drop to zero ?, wouldn't the supply or battery still be supplying current to the load ?
Source
https://en.wikipedia.org/wiki/Boost_converter
The output reservoir capacitor receives a flow of charge through the inductor each time the switch opens. If the load does not draw sufficient current to pull the output voltage back down below the regulated voltage, then the regulator will prevent another switching cycle until it does. The current through the inductor may then fall to zero while waiting.
The situation can also occur when charging a battery from a low voltage supply.
Were you to keep the switch OPEN for a long time, then inductor current would reach a fixed value. With steady current the voltage across the inductor will be zero, meaning the voltage across the load would be equal to the voltage output by the supply: hence, no voltage boost!
By switching the coil to ground at judiciously-chosen intervals, the coil generates a boosted voltage across the load. In the arrangement shown, with no capacitor, the load voltage will be delivered as a pulsed voltage, the pulses separated by drops to zero volts.
In operation, with a fixed load, the inductor current will be found to be approximately constant, only.
So when the inductor is discharging the total input current is inductor current + source current ?
NascentOxygen said:
In the arrangement shown, the load voltage will be delivered as a pulsed voltage, the pulses separated by drops to zero volts
Why would the load voltage drop to zero ?, when the switch is closed the capacitor will try to maintain a constant voltage to the load as long as it is large enough and charges when the switch is open which creates the ripple ?
Inductor current is 'equal to' source current. They are in series after the switch is opened.
Output voltage=inductor voltage+source voltage, which is more than the source voltage. Hence the name 'boost' converter.
NO is referring to the circuit diagram in the wiki article which doesn't have a capacitor.
In the circuit you linked to, the load current is the inductor current while ever the diode is conducting.
There is no reservoir capacitor shown in the schematic you referenced.
Thanks for the replies. From what I understand now is that when the load is connected (switch open), the current in the circuit drops (more resistance) but because of the inductor it prevents the instantaneous drop in current but if it where allowed to fully discharge then it would reach steady state current and because there is no di/dt then the inductor voltage is zero, correct ?
That would happen, yes.
Ok thanks
Related to Boost converter inductor discharging question
1. What is a boost converter inductor?
A boost converter inductor is a type of electronic component used in power supply circuits to convert a lower voltage input to a higher voltage output. It works by storing energy in the form of a magnetic field when current flows through it, and then releasing that energy when the current is interrupted, resulting in a higher output voltage.
2. How does a boost converter inductor work?
A boost converter inductor works by using the principles of electromagnetic induction. When current flows through the inductor, it creates a magnetic field. This magnetic field stores energy, which is then released when the current is interrupted. This results in a higher output voltage compared to the input voltage.
3. What is the purpose of discharging an inductor in a boost converter?
The purpose of discharging an inductor in a boost converter is to release the stored energy in the magnetic field, which then increases the output voltage. This discharge is controlled by the circuit's switching device, which interrupts the current flow through the inductor.
4. How does the discharging process affect the output voltage in a boost converter?
The discharging process in a boost converter affects the output voltage by increasing it to a higher level. This is because when the inductor is discharged, the stored energy in the magnetic field is released, resulting in a higher output voltage compared to the input voltage. The amount of energy released depends on the inductor's characteristics, such as its inductance and current rating.
5. What are some factors that can affect the discharging process in a boost converter inductor?
Some factors that can affect the discharging process in a boost converter inductor include the inductor's characteristics, such as inductance and current rating, the switching frequency of the circuit, and the load connected to the output. These factors can impact the amount of energy released from the inductor and, therefore, affect the output voltage of the boost converter.
  • Electrical Engineering
