Bosonic Field operator in this exponential
In summary, taking the exponential of a bosonic field ##\phi(x)## with a parameter ##f## results in an operator ##W=e^{\imath f \phi(x)}## that acts on the vacuum state ##|0\rangle## to produce a "coherent" state with uncertain particle number. This is analogous to the space translation operator and can be understood by expanding the exponential in a Taylor series and using creation and destruction operators. However, a physical cutoff is needed to give meaning to the series.
QFT1995
30
If i had a bosonic field ##\phi(x)## and I took the exponential in the following way to get the operator $$W=e^{\imath f \phi(x)}$$ where ##f## is a parameter what effect would this have when acting on the vacuum ##|0\rangle##? Is it analogous to the space translation operator? Will it transform the vacuum into some state?
Taking the exponential of a distribution is ill-defined and needs a regularization to give it a meaning. The result is a state not described by the original Fock basis.
You get a "coherent" state in which the number of particles is uncertain. To see that, expand the exponential in the Taylor series and split the field into creation and destruction operators.
As @A. Neumaier alluded, the Taylor series does not really converge, but this mathematical nuisance can be fixed by introducing a physical cutoff. See e.g. the book by Itzykson and Zuber, Sec. 4-1-2.
Likes vanhees71
Related to Bosonic Field operator in this exponential
1. What is a Bosonic Field operator?
A Bosonic Field operator is a mathematical operator used in quantum field theory to describe the behavior of bosons, which are particles with integer spin. It represents the creation and annihilation of bosonic particles in a specific location in space and time.
2. What does the exponential in the Bosonic Field operator represent?
The exponential in the Bosonic Field operator represents the energy of the bosonic particles. It is used to calculate the probability of finding a certain number of bosons in a particular state.
3. How is the Bosonic Field operator different from the Fermionic Field operator?
The Bosonic Field operator describes the behavior of bosons, while the Fermionic Field operator describes the behavior of fermions, which are particles with half-integer spin. The main difference between the two is that bosons can occupy the same quantum state, while fermions cannot.
4. What is the significance of the commutation relation in the Bosonic Field operator?
The commutation relation in the Bosonic Field operator is a fundamental property of bosons. It states that the order in which the operators are applied does not affect the result. This allows for the creation and annihilation of bosons without changing the overall state of the system.
5. How is the Bosonic Field operator used in practical applications?
The Bosonic Field operator is used in many practical applications, such as in the study of superconductivity, superfluidity, and Bose-Einstein condensates. It is also used in the development of quantum technologies, such as quantum computing and quantum communication.
  • Quantum Physics
  • Quantum Physics
