Bosons and Fermions in a rigorous QFT
In summary, there is still a sharp distinction between Bosons and Fermions in a rigorous QFT, if exists.
kof9595995
679
I'm wondering, is there still a sharp distinction between Bosons and Fermions in a rigorous QFT, if exsits?
My question is motivated by the following, consider one of the equations of motion of QED:
[tex]\partial_\nu F^{\nu \mu} = e \bar{\psi} \gamma^\mu \psi[/tex]
In our familiar perturbative QED (Here I'm not 100% sure if I use the word "perturbative" correctly. I simply mean fields are quantized as free fields, and we introduce an interaction built from free fields operators, like an iteration method), LHS is made of Bosonic operators and RHS is made of Fermionic operators, and since the Bosonic sector and Fermionic sector are independent in the total Fock space, perturbative QED fails to satisfy this equation of motion.
I suppose if a rigourous QED exists, this equation of motion should be satisfied, but this in turn means the fermion operator and bosonic operator must act on a Hilbert space they share together, then is there still a sharp distinction between Bosons and Fermions?
One of the greater successes of axiomatic QFT was the proof that at least in some quantum field theories bosonic and fermionic behaviour results quite naturally for localized charges.
See e.g. the book by R. Haag, Local quantum physics.
The above mentioned field equation cannot be quantized directly b/c it has to be gauge fixed. In A°=0 at least for the time-indep. constraint (the Gauss law) this equaton is implemented on the physical Hilbert space. This does not require any "free field approach".
kof9595995 said:
[...] LHS is made of Bosonic operators and RHS is made of Fermionic operators, and since the Bosonic sector and Fermionic sector are independent in the total Fock space, perturbative QED fails to satisfy this equation of motion.
The product of two spin-1/2 operators is bosonic (being a superposition of spin-0 and spin-1 in general). (You might want to review Clebsch-Gordan coefficients and associated angular momentum decomposition theory in ordinary QM if you're not already familiar with it.)
[...] then is there still a sharp distinction between Bosons and Fermions?
Yes, in the sense that there's a superselection rule between them. But when you start forming products, things get more complicated.
Perhaps it makes sense to consider a simple qm example; the problem for the two-dim. harmonic oscillator as a toy model would be
[tex]H_i = \frac{1}{2}p_i^2 + \frac{1}{2}x_i^2 = a_i^\dagger a_i + \frac{1}{2}[/tex]
[tex]H = H_1 + H_2[/tex]
Now we can easily solve equations like
[tex](H - N)|N\rangle = 0[/tex]
for some eigenvalues N, but structurally the equation "bosonic operator = fermionic operator" would be something like
[tex](H - N) = 0[/tex]
and this is obviously not allowed as an operator equation b/c
[tex](H - N) = 0 \;\Rightarrow\; (H - N)|m,n\rangle = 0 \;\forall m,n \;\Rightarrow\; (m+n+1-N) = 0\;\forall m,n [/tex]
Gauge fixing introduces some additional structures like resolving "unphysical bosonic operators" in terms of fermionic operators via Gauss law, but I still don't see how this is sufficient to resolve the problems for the remaining operator equations. Neverthelesse there should be some solution e.g. for QE´D and QCD where these problems have been treated w/o using perturbation theory.
Is there anybody who believes that a rigorous QED exists?
I don't believe in a rigorous QED ...
... but this problem seems to be trivial and there must be a solution in "standard textbook QED with canonical quantization using Fockspace".
I think the subtlety is the regularization of the operator product on the r.h.s. which requires e.g. point splitting with gauge-field insertion (in order not to destroy gauge invariance); this would introduce a gauge field dependency on the r.h.s. whereas the fermionic contribution on the l.h.s. comes from the solution of the Gauss law constraint i.e. A° expressed in terms of fermionic charge density.
That means that quantization, gauge fixing and regularization translates the equation
into something like
"bosonic + fermionic operator = fermionic + bosonic operator"
which has a chance to hold as operator equation in terms of standard Fock space creation and annihilation operators.
This is of course no rigorous proof but is indispensable already for standard textbook QED.
That sounds quite a long way to go, is there a layman explanation of it?
Then what's the underlying theory that makes perturbative QED plausible?
Can you give a concrete example? Better a QED example since I'm not familiar with QCD.
My example is described in #7
We must not mix two issues
- perturbative QED
- Fock space with creation and annihilation operators
The latter does not imply perturbation theory
- perturbative QED
Could you elaborate? I have always thought a Fock space only makes sense for perturbation theory, since I would imagine an interaction should destroy the simple direct product structure of different sectors.
It was formulated about 1969 but there are still people working on it. Its an extremely mathematical approach.
See the article by Roberts:
http://kolxo3.tiera.ru/M_Mathematics/MA_Algebra/MAg_Algebraic%20geometry/Connes%20A.,%20Cuntz%20J.,%20et%20al.%20Noncommutative%20geometry%20(CIME%20lectures,%202000,%20LNM1831,%20Springer%202004)(359s)_MAg_.pdf#page=274
A useful perspective on this question is provided by lattice gauge theory. For example, Gauss' law, which is the 0th component of the equation you wrote, is satisfied as an identity on the physical hilbert space. In other words, in the true hilbert space electric field lines can only end where charges are located. Nevertheless, there are many ways to distinguish bosons and fermions. In this model the fermions carry charge while the gauge bosons do not. There are composite operators made of fermions that are bosonic and carry charge, but there is still a fermion number that remains sensible.
Of course, this is not to say that there is no blurring of the lines. Bosonization in one dimension is a procedure for exchanging bosons and fermions (and is even relatively rigorous). In higher dimensions one can have solitons built from gauge and bosonic matter degrees of freedom that can carry weird charges and even be fermions.
Of course going beyond perturbation theory is still difficult, but neither impossible nor excluded in principle
Think about a Hamiltonian
[tex]H = \frac{p^2}{2} + V(x)[/tex]
You can rewrite this as
[tex]H = \frac{p^2}{2} + \frac{x^2}{2} + \left[V(x) - \frac{x^2}{2}\right] = \frac{p^2}{2} + \frac{x^2}{2} + \tilde{v}(x) = a^\dagger a + \frac{1}{2} + \tilde{u}[/tex]
Now it's up to you to solve this problem exactly or to use perturbation theory in u.
I think it's possible to rewrite a QFT in terms of creation and annihilation operators acting on Fock spaces, but I don't see why a perturbative treatment is mandatory.
Think about a Hamiltonian ...
I don't consider this problem as too representative for the situation in QFT. The main problem in field theory is that the perturbed and free fields live in different Hilbert spaces -- a problem usually absent in ordinary QM.
Superconductivity can be taken as a toy model on how to solve this problem:
The BCS Hamiltonian can be diagonalized introducing new field operators by the Bogoliubov Valatin transformation. The new field operators are also fermionic but describe the interacting particles.
They cannot be obtained perturbationally from the free electron gas.
DrDu said:
The main problem in field theory is that the perturbed and free fields live in different Hilbert spaces ...
... Superconductivity can be taken as a toy model on how to solve this problem:
I never said that.
What I am saying is that one may start with Fock space operators and then use some non-perturbative techniques. Bogoljubov transformation, bosonization, ... are examples. That is more than just a solution, it's a kind of formal re-definition of the theory.
There is no need to use perturbation theory only b/c of Fock space states, neither before nor after Bogoljubov transformation.
But here if you creat the Hilbert space using creation operators, it might not be the same with the true Hilbert space, then the best you can get is a perturbation theory.
I'd like the ask the question again, if a rigorous QED doesn't exist, what would be underlying theory of perturbative QED?
At least in QM tis is not true.
Which states do I miss?
I can construct nearly arbitrary operators from the creation and annihilation operators; look at the method of coherent states, for example.
And please not that up to now we haven't defined the Hilbert space, neither for x and p, nor for the creation and annihilation operators! So if we need to change the entire Hilbert space for some reason we are not forced to do this by introducing creation and annihilation which are nothing else but linear combinations of x and p. There is physics behind it so far.
I kinda get what you mean, but I think in QFT the situation is quite different, and I'm more curious about QFT senario.
In QM, before we define any operator, we set the full Hilbert space as all square-integrable functions, and we define how x and p (so are a and a+) act on this full Hilbert space, then according to the specific Hamiltonian we have, we can construct the subspace using a and a+, though the construction may not be as simple as harmonic oscillator case. I guess this is what you mean.
However in an interacting QFT, the true structure of the full Hilbert space is not clear yet, let alone defining how a and a+ act on the space. The normal treatment is to use the Hilbert space from free theory (a Fock space) and then do things perturbatively. And my point is, if the interaction actually destroys any existence of direct-product structure of the true Hilbert space, then whatever kind of Fock space you use will be just an approximation at best, and if this is the case, I think Fock space does necessarily imply a perturbative approach.
Lattice gauge theory or an asymptotically free gauge theory in a partial higgs phase can provide a UV completion of low energy QED.
Googling "Grassmann Osterwalder-Schrader" produced these papers which may be relevant.
Jaffe, Constructive Quantum Field Theory
"The Euclidean methods also apply to theories with fermions, at least for examples with interactions that are quadratic in the fermions. This is the case for free and for “Yukawa type” interactions, used extensively in physics."
Benfatto, Falco, Mastropietro, Functional Integral Construction of the Thirring model
"Proposed by Thirring half a century ago, the Thirring model is a Quantum Field Theory of a spinor field in a two dimensional space-time, with a self interaction ..."
In modern QM, that's become kinda backwards. We start with an algebra of observable quantities which characterize the (class of) system being modeled, and then (try to) construct a unitary representation (i.e., construct a Hilbert space) in which those quantities are represented as operators on the Hilbert space. For many interesting case (like x,p) above, it turns out that a rigged Hilbert space is more convenient than an ordinary Hilbert space. See the early chapters of Ballentine for a more detailed exposition of all this.
That's essentially what renormalization tries to fix. At each order of perturbation, we adjust the space we're working with, either by adjusting the Hamiltonian, or applying a Bogoliubov-like transformation to the basic c/a operators (cf. Shirokov's approach: http://arxiv.org/abs/nucl-th/0102037[/url]).
BTW, the presence of interaction doesn't necessarily "destroy" direct-product structure. It simply means that the Hamiltonian can now mix stuff from different sectors.
strangerep said:
That's essentially what renormalization tries to fix. At each order of perturbation, we adjust the space we're working with, either by adjusting the Hamiltonian, or applying a Bogoliubov-like transformation to the basic c/a operators (cf. Shirokov's approach: http://arxiv.org/abs/nucl-th/0102037[/url]).[/QUOTE]
How does this tie in with the view that renormalization, say in QED, just preserves the important low energy terms, and that at high energies non-renormalizable terms or even new degrees of freedom should enter?
But even the perturbative Hamiltonian can "mix stuff from different sectors". Let me elaborate my original point: my starting point is that in a mathematically rigorous QED, the equation of motion in my original post must be satisfied. However the perturbative approach definitely fails to satisfy it, because LHS and RHS are defined on independent sectors, so for example, if I sandwich (i.e. taking rayleigh quotient) both sides using photon states, then LHS is mostly nonzero but RHS is always 0. So to satisfy the equation, the true Hilbert space must somehow take Bosonic and Fermionic sector as one, but I can't proceed with the reasoning because I haven't acquired enough maths.
But as far as I know, an constant issue of Lattice theory is about how to get to the continuum limit, and this isn't very well-established yet. And what I'm trying to argue is, QED is probably some limit of underlying bigger theory, but within this limit we should have a mathematically rigorous framework. Just like classical mechanics and quantum mechanics, the former is a limit of the latter, but still classical mechanics is a mathematically rigorous theory.
I took a look at Haag's "Local Quantum Physics". He describes both views of renormalization, but doesn't give any link between them. The view you describe is related to the "Algebriac QFT" formalism, while the latter Wilsonian view is related to the "Constructive QFT" formalism, which typically constructs a statistical field theory, and checks that it satisfies the Osterwalder-Schrader conditions in order to make it a Minkowski spacetime QFT.
Which sections of Haag? There's some stuff in the early sections, but also in the later ch VIII.
(I should probably refresh my memory of Haag a bit more thoroughly, else I risk talking out of my rear... :-)
kof9595995 said:
[...] Let me elaborate my original point: my starting point is that in a mathematically rigorous QED, the equation of motion in my original post must be satisfied. However the perturbative approach definitely fails to satisfy it, because LHS and RHS are defined on independent sectors, so for example, if I sandwich (i.e. taking rayleigh quotient) both sides using photon states, then LHS is mostly nonzero but RHS is always 0. So to satisfy the equation, the true Hilbert space must somehow take Bosonic and Fermionic sector as one, [...]
This is an example of how the space of states in the free theory does not satisfactorily span the space of physical states in the full physical (interacting) theory.
The field operators in the exact form of Gauss' law correspond to the physical fields, not the free fields. Some approaches to QFT try to construct physical field operators perturbatively in terms of (increasingly-complicated) products of the free field operators. Among other things, this procedure must ensure that the new field operators still correspond to suitable Poincare unirreps with the physically correct spin, etc.
Do you recall the earlier thread where I talked about dressing the asymptotic electron states using coherent photon operators? After such dressing has been applied, the commutation relations are a bit different. E.g., the commutator between an electron operator and the electric field operator is no longer zero. Instead, it gives the usual Coulomb field of a charged electron. (This is all at low momenta, since the main task there was to deal with IR divergences.) A similar construction (of Dirac) also shows how to banish some parts of the unphysical EM gauge freedom.
At least one of the rigorous QFT results that I know proceeds via a related process of dressing transformations applied to the basic operators:
J. Glimm,
"Boson Fields with the [itex]:Φ^4[/itex]: Interaction in Three Dimensions",
http://projecteuclid.org/DPubS?service=UI&version=1.0&verb=Display&handle=euclid.cmp/1103840981
Warning: very few people can safely read that on an empty stomach...
  • #31
In the second edition, the first sort of renormalization is in section 2.4, while the second type is in the section starting p323 "Algebraic Approach versus Euclidean Quantum Field Theory". I think that in his language "renormalization" always means the first type, because when discussing the second type he says something like it does away with renormalization (can't remember the exact words, I read it in the library, and am getting the section references from a search on Amazon).
  • #32
Do you recall the earlier thread where I talked about dressing the asymptotic electron states using coherent photon operators? After such dressing has been applied, the commutation relations are a bit different. ...
This is exactly what I had in mind in #3
It is interesting that in the very end the physical fields can be decomposed using physical creation and annihilation operators spanning a physical Fock space. Now I understand where the confusion comes from; people seem to confuse Fock space with free particle Fock space plus perturbation theory. This (implicit) assumption is wrong of course.
A Fock space is nothing else but a direct sum of tensor products of copies of a single-particle Hilbert space H.
But it is not necessary that the Hilbert space H is spanned by free fields; any single particle Hilbert space with the correct creation and annihilation operator algebra is sufficient. So if it's possible to construct a suitable transformation from free to 'physical' or 'dressed' fields and a physical Hilbert space then the latter one can be decomposed into physical Fock states. This has been done in QCD in orer to study confinement in the canonical formulation (the problem with the construction of the physical Hilbert space is of course always the same: complete gauge fixing, taming Gribov ambiguities etc.; anyway - these problems do by no means spoil the Fock space approach using physical fields)
  • #33
I would disagree about the continuum limit. We understand very well that the lattice theory flows to the continuum theory plus irrelevant operators. The essential properties of the low energy theory are there. For example, the heat capacity in lattice qed at low temperatures in the deconfined phase is proportional to [itex] T^3 [/itex] just as you would get for free photons. Similarly, the long distance decay of gauge invariant correlation functions is exactly what you would expect for free photons. Lattice theories of qcd are also quite advanced, including fairly good numbers for hadron masses, although treating fermions dynamically is always troublesome because of the sign problem.
I also think it is interesting to note that classical electromagnetism is also not a rigorous theory, at least when thinking about point charges. Indeed, classical fluid dynamics and general relativity are also not known to be free of singularities.
  • #34
...except that they might not satisfy exactly the same CCRs/CARs as in the free case.
DarMM once mentioned something about this, but we never got to hear the full story.
Yes, yes, and yes.
It's still not clear to me what the "correct" c/a operator algebra should be. E.g., physical electron operators probably shouldn't commute with physical photon operators like they do in the free theory. Not sure about this, though. I recall a theorem (in Barut?) about how a very large class of algebras can be expressed in terms of operators from a Heisenberg algebra.
  • #35
I remember the 'dressing' and the 'gauge fixing by unitary transformations'; both approaches seem to be similar b/c they partially 'solve' some field equations.
The first approach (dressing) changes the operator algebra; it can be solved explicitly in some 1+1 dim. field theories like the Schwinger model (here one formally solves the Dirac equation by exponentiation using a gauge field string with a path ordered product).
The second approach does not change the operator algebra; the Gauss law is solved but b/c a unitary trf. is used, all operator algebras remain unchanged. This may be spoiled by regularization which requires gauge-invariant point splitting (I can only remember the two-dim. case).
In the first case the interaction is "hidden" in the dressed fields; they create the physical Coulomb interaction, but the interaction term itself looks trivial algebraically. In the second case the interaction terms are constructed explicitly and in principle they can be expressed using physical Fock space operators.
In the second case the (A°=0 & Coulomb gauge) Hamiltonian contains one piece which shows directly the color-electric Coulomb potential:
[tex]H_C = g^2 \int d^3x \int d^3y \,\text{tr}\,J^{-1}(x)\,\rho(x)\,(-D\partial)^{-1}\,(-\partial^2)\,(-D\partial)^{-1}\,J(y)\,\rho(y)[/tex]
with D = ∂ + gA, A being the gauge-fixed gluon field, J being the Fadeev-Popov determinant J = det(-D∂), ρ = ρ[q] + ρ[A] being the total color charge with quark and gluon contribution (w/o J, D and ρ[A] in HC the usual Coulomb gauge interaction in QED is recovered)
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
