Bounce light back and forth between mirrors forever?
In summary: If the container is perfectly elastic, the walls will bounce back and forth forever without any net movement. But if the container is not perfectly elastic, the walls will slowly move towards the incoming particle.
hxtasy
112
[Mentors' note - this post was forked off from this thread because it's an interesting question in its own right]
I would also like clarification on this. if you throw a rubber ball at concrete, it will "bounce off". if you throw the rubber ball at mud, the mud will absorb it and it will stay there.
however both the mud and the concrete have absorbed some of the rubber balls energy, just different amounts. is this the same with photons? could you reflect light indefinitely..
Science news on Phys.org
No. No matter how perfect the reflection, some small amount of energy has to be transferred to the mirror - this is required by conservation of momentum as the reflected light is reversing direction with each bounce. Thus the bouncing light loses a bit of energy with each bounce, just as does the bouncing ball. The big difference is that when the ball loses energy it slows down and eventually stops; light must always travel at ##c## so it doesn't slow down. Instead it's redshifted down to thermal wavelengths which are absorbed and turned into waste heat instead of being reflected - so as with the bouncing ball it all ends up as waste heat eventually.
It's a good exercise to calculate how long each "bounce" takes for a light signal moving between two mirrors a few meters apart. "Eventually" happens very quickly indeed.
Are you sure that's true? Seems to me that conservation of energy and momentum should just produce a container that shakes back and forth in place, whether it is a photon or a hypothetical perfectly elastic rubber ball bouncing back and forth in it.
Your description also suggests the light gradually redshifts out of existence.
My understanding was that imperfect reflection just means a certain fraction of photons are absorbed instead of reflected.
If it's in a box, the second wall will move towards the incoming particle for the second bouncing. So the particle will gain some energy after this second collision.
You're both right.
Related to Bounce light back and forth between mirrors forever?
1. How does bounce light back and forth between mirrors forever work?
Bounce light back and forth between mirrors forever, also known as the "infinity mirror effect," works by placing two mirrors facing each other with a small gap in between. When a source of light is placed in the gap, it reflects back and forth between the two mirrors, creating an illusion of infinite reflections.
2. What is the scientific explanation behind bounce light back and forth between mirrors forever?
According to the law of reflection, when light hits a mirror, it bounces back at an equal angle to the angle at which it hit the mirror. In the case of two mirrors facing each other, the light continues to bounce back and forth, creating multiple reflections due to the reflective surfaces.
3. Can bounce light back and forth between mirrors forever be observed in nature?
While the infinity mirror effect cannot be observed in nature exactly as it is created using man-made mirrors, similar effects can be seen in nature. For example, when light reflects off a body of water or off a series of mountains, it can create a similar illusion of infinite reflections.
4. Is there a limit to the number of reflections in bounce light back and forth between mirrors forever?
In theory, there is no limit to the number of reflections that can occur in the infinity mirror effect. However, in practical applications, the reflections become increasingly dimmer with each bounce due to some light being absorbed or escaping through the edges of the mirrors.
5. What are some real-life applications of bounce light back and forth between mirrors forever?
The infinity mirror effect is often used in artistic installations and exhibits to create visually stunning illusions. It is also commonly used in laser shows and in the design of fiber optic cables for telecommunication purposes.
  • Other Physics Topics
  • Quantum Physics
