-Dragoon-
- 309
- 7
A certain coaxial cable consists of copper wire, radius a, surrounded by a concentric copper wire of outer radius b. The space between is filled with a dielectric with a relative permittivity of [tex]\epsilon_{r} = \frac{s}{a}, a \leq s \leq b[/tex] Find the bound charges by using two different methods.
First I'll find the electric displacement, the field, and the potential:
[tex]\oint D\cdot da = Q_{f_{enc.}} => D(2\pi sl) = Q =>D = \frac{Q}{2\pi sl}[/tex]
Then I find the field from the displacement:
[tex]E = \frac{D}{\epsilon} = \frac{D}{\epsilon_{0} \epsilon_{r}} = \frac{a}{s^{2}}\frac{Q}{2\pi \epsilon_0 l}[/tex]
Then, finally, the potential:
[tex] -\int_s^a E\cdot dI = \frac{Qa}{2\pi \epsilon_0 l}\int_a^s \frac{ds}{s^{2}} = \frac{Qa}{2\pi \epsilon_{0} l}(\frac{1}{a} - \frac{1}{s})[/tex]
Now for the bound charges:
[tex]P = D - \epsilon_{0}E = \frac{Q}{2\pi sl}\hat{r} - \frac{a}{s^{2}}\frac{Q}{2\pi l}\hat{r} = \frac{Q}{2\pi l} = \frac{Q}{2\pi l}(\frac{1}{s} - \frac{a}{s^{2}})\hat{r} [/tex]
The surface bound charge is:
[tex]\sigma_{b} = P\cdot\hat{n} = \frac{Q}{2\pi l}(\frac{1}{s} - \frac{a}{s^{2}})[/tex]
Now, when I calculate it using a different method which involves the potential:
[tex]\sigma_{b} = -\epsilon_{0}( \frac{\partial V_{out}}{\partial s} - \frac{\partial V_{in}}{\partial s}) = -\epsilon_{0}(\frac{Q}{2\pi \epsilon_{0} l}\frac{a}{s^{2}} - 0) = -\frac{Q}{2\pi l}\frac{a}{s^{2}}[/tex]
Which gives one of the terms correctly, but the other term is clearly missing from here. Any hints on where I'm going wrong in this? Thanks in advance.
