Bound charges - are they real or mathematical?
In summary, the conversation discusses the concept of bound charges in a dielectric material, which are physical charges that result from the polarization of atoms when an electric field is applied. This is contrary to some illustrations that show charges being smeared over the surface of the material. The summary clarifies that this is not accurate, as the charges are actually separated into positive and negative charges on opposite surfaces.
aaaa202
1,169
In my chapter about electric fields in matter my book derives and expression for the potential due to the polarization of a dielectric material. For that you find that the polarization is equal to the potential of a collection of negative charges on the surface and positive charges inside the volume.
I want to know: Do these charges represent genuine, physical charges or are the expression merely a mathematical tool? My book (Griffiths) certainly seems to believe that bound charges are indeed something physical. On the other hand I keep seeing pictures like the one attached, which wants to explain why putting a dielectric between two conductors gives a different capacitance for the capacitor they make. AND... Here both plus and minus charges are smeared over the surface of the material.
Bound charges are very much real. They are the valence electrons and nuclei of atoms in a material. When an electric field is applied, the atoms tend to "elongate", and the charges separate somewhat, but they can only move slightly, hence being "bound".
The statement in bold is not accurate, you'd find one surface is more negatively charged, and the opposite surface more positively charged, where as in the bulk, assuming the material is uniform, there is zero charge density. Polarization of a uniform material creates a surface charge, not any volume charge.
FAQ: Bound charges - are they real or mathematical?
What are bound charges?
Bound charges refer to the charges that are present on the surface or interface of a material, such as an insulator or dielectric, when it is placed in an external electric field. These charges are induced by the external field and are not free to move within the material.
Are bound charges real or just a mathematical concept?
Bound charges are a mathematical concept used to explain the behavior of materials in an electric field. They are not physical charges that can be measured or observed directly, but they play an important role in understanding the properties of dielectrics.
How do bound charges differ from free charges?
Bound charges are different from free charges in that they are not able to move freely within the material. Free charges, on the other hand, are able to move within the material and contribute to the flow of electric current.
How are bound charges related to polarization?
Bound charges are closely related to polarization, which is the separation of positive and negative charges within a material when it is placed in an electric field. The presence of bound charges on the surface or interface of a material is a result of this polarization process.
Can bound charges be removed from a material?
Bound charges cannot be completely removed from a material, as they are a consequence of the material's molecular structure and its response to an external electric field. However, they can be neutralized by applying an equal and opposite external electric field, resulting in a net zero charge on the material's surface.
