Bound State Problem: How can it be addressed?
In summary, the conversation was focused on solving a bound state problem involving two micro black holes in orbit around each other, while disregarding Hawking evaporation. The usual approach is to use the Schrodinger equation, but other methods such as string theory and general relativity can also be employed. The potential energy can be described using a classical Newtonian gravitational potential, and the energy levels can be determined by using the Planck mass. However, due to the strong quantum effect of gravity, the ground state cannot be solved with a classical approach. Other methods such as numeric simulations can also be used. Overall, it seems that quantum mechanics is the most suitable approach for solving this problem.
nightbat
Greetings.
Let's say we have a bound state problem: two micro black holes in orbit around one other. Let us disregard Hawking evaporation, and solve this problem.
The usual way of solving this problem is to do so quantum-mechanically by employing the Schrodinger equation, deducting the eigenvalues, etc.
My question is: What other methods can be employed?
How does string theory treat this bound state problem? How does general relativity address it? What other approaches can be used?
Thank you.
I don't have an answer for your question, but I’m curious (because I don’t know anything about black holes): what kind of potential are you using in Schrodinger equation for system of two micro black holes?
Since we don't have a viable theory of quantum gravity, I'm using a straightforward classical (Newtonian) gravitational potential.
All I'm interested in is ballpark values, accurate to an order of magnitude, and I do get that.
Anybody care to weigh in on this?
Let's take two black holes of mass 2m each. The two-body system can be reduced to a one-body system with a reduced mass of m.
Neglecting GR effects, the potential energy is then given by V(r)=-Gm^2/r.
This is similar to the hydrogen atom with [itex]V(r)=-\frac{1}{4\pi \epsilon_0} \frac{e^2}{r} = \frac{f}{r}[/itex] with some constant f. There, the energy levels are given by [itex]E_n = -\frac{f^2*m_e}{2\hbar^2 n^2}[/itex].
Using this for the black holes, the energy levels are given by [tex]E_n = - \frac{G^2m^5}{2\hbar^2 n^2}[/tex]
What happens if we use the Planck mass [itex]m_p=\sqrt{\frac{\hbar c}{G}}[/itex]? Well, we get [itex]E_n=1/2 m_p c^2[/itex], which means that the binding energy is of the same size as the black hole masses - and their distance is comparable to their Schwarzschild radius.
This is not so unexpected: The Planck mass is the mass where gravity becomes strong in a quantum mechanical sense, therefore the ground state cannot be solved with a "classical" approach.
Conclusion: If two black holes orbit each other, you cannot see quantum mechanical effects without effects of quantum gravity.
I believe the OP specified micro black holes, which are nonclassical to begin with. They only exist in the realm where gravity is strong quantum mechanically.
Thank you for weighing in. The gist of what you're saying is: this is a gravitational analogue of the hydrogen atom problem.
It is. It can be solved in exactly the same way, quantum-mechanically. I have done it.
My question is: In what other ways can this problem be addressed?
1. How can this problem be solved using string theory?
2. How can this problem be solved using general relativity?
3. Is there any other way of solving this problem?
That's what I'm interested in knowing. I am looking for a deeper insight.
Thank you.
Derive mechanics of quantum gravity using string theory, get a nobel prize, use this (not the prize) to evaluate the problem.
For distances which are larger than the Schwarzschild radius or masses which are larger than the Planck mass, consider it as a Kepler problem with relativistic corrections, or try to find analytic solutions for special cases.
Use numeric simulations.
Fantastic. So basically quantum mechanics is the sensible way to go.
Thanks.
FAQ: Bound State Problem: How can it be addressed?
What is a bound state problem?
A bound state problem refers to a situation in quantum mechanics where a particle is confined to a specific region by a potential energy barrier. This can occur in various physical systems such as atoms, nuclei, and molecules.
Why is the bound state problem important?
The bound state problem is important because it helps us understand the behavior of particles in confined systems and provides insights into the fundamental laws of nature. It also has practical applications in fields such as materials science, chemistry, and engineering.
What are the challenges in addressing the bound state problem?
One of the main challenges in addressing the bound state problem is the complexity of the mathematical equations involved. These equations can be difficult to solve analytically, requiring the use of numerical methods. Another challenge is the incorporation of relativistic effects, which are necessary for accurately describing high-energy systems.
How can the bound state problem be addressed?
The bound state problem can be addressed through various methods such as perturbation theory, variational methods, and numerical simulations using computers. Each of these approaches has its own advantages and limitations, and the choice of method depends on the specific system being studied.
What are the potential implications of solving the bound state problem?
Solving the bound state problem can have significant implications in various fields of science and technology. It can lead to a better understanding of the properties of matter and the behavior of particles in confined systems. It can also help in the development of new materials and technologies, such as more efficient solar cells and better drug delivery systems.
