Boundary condition at junction of heated rods
In summary, the problem at hand involves two rods of different lengths, cross-sectional areas, and heat conductivities joined at one end. The goal is to determine the boundary condition at the juncture of the two rods. The relevant equations for this problem include the heat conduction equation, which relates temperature, time, and thermal conductivity, and the general form of the boundary condition at a non-insulated rod end, which involves a constant h. To determine the value of h, the units of thermal conductivity, specific heat, mass density, and cross-sectional area are considered, but no solution has been found yet. The boundary conditions for the joined-rods problem are not explicitly stated, but it is assumed that the heat emitted from one rod
musemonkey
25
1. 1D heat conduction problem: Two rods, the first of length [tex] a [/tex], the second of length [tex] L-a [/tex] with respective cross sectional areas [tex] A_1 [/tex],[tex] A_2 [/tex] and heat conductivities [tex] k_1 [/tex], [tex] k_2 [/tex], are joined at one end. There are some boundary conditions on the other ends of the rods, but my question is only: how to write the boundary condition at the juncture?
Heat conduction eqn:
[tex] \alpha^2 u_{xx} = u_t [/tex]
where [tex] \alpha^2 = \frac{k}{s \rho} [/tex], in which [tex] \rho [/tex] is the density and [tex] s [/tex] is the specific heat with units: energy / (mass degrees).
More fundamentally, heat flux through a cross-section per unit time is
[tex] H = - k A u_x [/tex].
General form of boundary condition at non-insulated rod end is given in the text as
[tex] u_{x} = h u [/tex]
where [tex] h [/tex] is some constant (presumably with units inverse length).
The idea of the [tex] u_{x} = h u [/tex] is intuitive enough: the heat flux from a surface is proportional to its temperature, but I can't figure out what [tex] h [/tex] is in terms of thermal conductivity k, specific heat s, cross-sectional area A, and mass density [tex] \rho [/tex]. In other words, I can't even figure out how to set-up the simpler problem of a non-insulated rod end not connected to anything, much less two rods joined together, but my common sense tells me that the joined-rods problem reduces to the one rod end case because the effective conductivity and area at the junction should be [tex] min(k_1, k_2) [/tex] and [tex] min(A_1, A_2) [/tex] because what ever flows out of one rod has to be absorbed into the other. Actually I doubt this is right just from the way the problem is worded but it's the only thing that makes sense to me... To figure out [tex] h [/tex] I've tried playing with units:
Letting E = energy, L = length, T = temp, t = time, M = mass, I tried to combine
thermal conductivity [tex] k = \frac{E}{L\cdot T\cdot t} [/tex],
specific heat [tex] s = \frac{E}{M\cdot T} [/tex],
mass density [tex] \rho = \frac{M}{L^3} [/tex],
and cross-sectional area [tex] A = L^2 [/tex]
into units of inverse length. No success. Would much appreciate any guidance on how to write and think about the boundary conditions are for the two cases: one rod end and two joined rod ends with different material properties.
Just to be clear, the one rod end case is the one for which the text gives the form of the boundary condition. I'm puzzled as to how to think about it: Whatever heat is emitted has to be absorbed by something else, and how well that something can absorb one would think must be taken into account. So when we talk about one non-insulated rod end, does it mean, for examples, implicitly in a vacuum, in a medium with the same material properties, or in some ideal medium with perfect absorption? Lots of questions. Thank you for reading!
Would still much appreciate any help with this question.
-Musemonkey
Related to Boundary condition at junction of heated rods
1. What are boundary conditions at a junction of heated rods?
Boundary conditions at a junction of heated rods refer to the conditions that must be satisfied at the interface between two or more heated rods. These conditions typically include temperature and heat flux continuity, as well as mechanical equilibrium.
2. Why are boundary conditions important at a junction of heated rods?
Boundary conditions are important because they ensure that the solutions to heat transfer problems at a junction of heated rods are physically realistic. They also help to accurately predict the temperature and heat flux distribution within the system.
3. How are boundary conditions determined at a junction of heated rods?
Boundary conditions are determined by considering the physics of the problem, as well as any known information about the system. This may include information about the materials, geometry, and boundary conditions at other interfaces.
4. What happens if boundary conditions are not satisfied at a junction of heated rods?
If boundary conditions are not satisfied, the solutions to the heat transfer problem will be inaccurate and may not reflect the actual behavior of the system. This could lead to incorrect predictions and potentially dangerous situations in real-world applications.
5. Are there any assumptions made when determining boundary conditions at a junction of heated rods?
Yes, there are typically some assumptions made when determining boundary conditions at a junction of heated rods. These may include assuming steady-state conditions, neglecting certain heat transfer mechanisms, and assuming uniform properties within the material.
  • Differential Equations
