Boundary Conditions for an infinite rectangular pipe
The discussion centers on the appropriate boundary conditions and axis assignments for modeling an infinite rectangular pipe. Participants clarify their axis definitions, agreeing that the pipe is infinite along the X-axis, with the Y-axis representing width and Z-axis being vertical. There is consensus that the problem can be treated as a 2-D Laplace equation, as the infinite length along the Z-axis makes it independent of that dimension. The voltage conditions are specified, with V on the Y-axis faces and 0 on the Z-axis faces. Overall, the focus is on ensuring correct boundary conditions and axis orientation before proceeding with the solution.
guyvsdcsniper
An infinite rectangular pipe with sides a, has two opposite sides at voltage V
(front and back) and at voltage V=0 (top and bottom).
Find the potential inside the pipe.
Fourier Sine Trick
Does setting up the problem symmetrically on this axis and the boundary conditions applied make sense? I don't believe I will have a problem solving for the potential inside, but i just want to make sure I have my B.C and axis correct before proceeding.
EDIT:
Or should this be a 2-D lapace equation since the pipe is infinitely long, making this independent of the z axis?
I'm a bit confused about how you are assigning the axes.
I'll call the left right axis X, the vertical axis Z and the lower left/ upper right axis in the picture Y. From that and the text description, I would say the pipe is infinite in the X axis and width a in the other two. The voltage is V on the faces normal to the Y axis and 0 on those normal to the Z axis.
Sorry I missed that. y is the vertical axis.z is the axis coming out of the page. X is horizontal.
But I think it should be independent of Z since it is infinitely long. It mirrors an example straight out my textbook.
Looking at the diagram, the infinitely long direction is horizontal.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
