Boundary Conditions for an inviscid fluid at a fixed boundary
In summary, the boundary conditions for an inviscid fluid at an impermeable fixed boundary are: x_3-h(x_1,x_3)=0. Normal velocity is zero, so the velocity at the wall is also stationary.
Type1civ
This is my first post so I hope this in the right place. I am fairly sure this is quite a straight forward question but I having trouble working out the details of it.
"State the boundary conditions for an inviscid fluid at an impermeable fixed boundary
[tex] x_3-h(x_1,x_3)=0 [/tex]
where we do not permit normal velocity but permit non-zero tangential velocity"
So my attempt is quite limited as I feel if I could get started I'd be able to make some progress. But I believe that since the wall is stationary then the velocity of the fluid at the wall must also be stationary. And since it says that normal velocity is zero i guess this means that in the [itex] x_3 [/itex] direction the velocity is always zero.
so:
[tex] \mathbf{u}\cdot \mathbf{\hat x}_3 =0[/tex]
Then the velocity of the fluid only has components in the other two directions...
I was then also thinking that the [itex] \hat x_1 [/itex] component of velocity wouldn't change with [itex] x_1 [/itex] but I am not really sure why I think that. I am just getting a bit confused as you might be able to tell, any help would be really appreciated!
Edit: I am also not sure why my tex commands aren't working so if somebody could point out what I am doing wrong that would also be great...
That boundary seems an unnecessary complicated way to write [itex]g(x_1,x_3) = 0[/itex]. Does the question actually say
[tex]
x_3 - h(x_1, x_2) = 0
[/tex]
which would make sense as the upper boundary of a fluid layer of variable depth?
For an inviscid fluid only the normal component must be stationary relative to the wall.
And since it says that normal velocity is zero i guess this means that in the [tex] x_3 [/tex] direction the velocity is always zero.
so:
If the normal to the boundary were in the [itex]x_3[/itex] direction this would be correct, but that's not necessarily the case.
Following the question as written, the first thing is to define
[tex]
g(x_1,x_3) = x_3 - h(x_1,x_3)
[/tex]
so that the boundary is at [itex]g(x_1,x_3) = 0[/itex]. The boundary is then a contour of [itex]g[/itex], so the direction normal to the boundary is given by
[tex]
\nabla g = \frac{\partial g}{\partial x_1} \hat{\mathbf{x}}_1 + \frac{\partial g}{\partial x_3} \hat{\mathbf{x}}_3.
[/tex]
The closing tag is [/tex] not [\tex].
Yeah, sorry! It is:
[tex] x_3-h(x_1,x_2)=0[/tex]
So then in this case my direction normal would be:
[tex]\nabla_h=\hat x_3 -\frac{\partial h}{\partial x_1} \hat x_1 -\frac{\partial h}{\partial x_2} \hat x_2 [/tex]
and I can dot this with the velocity of the fluid to get zero. So that:
[tex]\mathbf{u}\cdot\nabla_h= \mathbf{u}\cdot\hat x_3 -\mathbf{u}\cdot \frac{\partial h}{\partial x_1} \hat x_1 - \mathbf{u}\cdot\frac{\partial h}{\partial x_2} \hat x_2=0 [/tex]
This surely isn't the whole whole answer though is it?
Thanks for the reply.
Hello, i know this is old but i would also really love to have some help with this question.
Thank you so much.
FAQ: Boundary Conditions for an inviscid fluid at a fixed boundary
What are boundary conditions for an inviscid fluid at a fixed boundary?
Boundary conditions for an inviscid fluid at a fixed boundary refer to the set of conditions that must be satisfied at the interface between the fluid and the boundary surface. These conditions dictate the behavior of the fluid at the boundary and are used to solve fluid dynamics equations.
Why are boundary conditions important in fluid dynamics?
Boundary conditions are important in fluid dynamics because they help determine the behavior of a fluid at the boundary. They also help in solving fluid dynamics equations, as they provide information about the flow and velocity of the fluid at the boundary.
What are the types of boundary conditions for an inviscid fluid at a fixed boundary?
The types of boundary conditions for an inviscid fluid at a fixed boundary include the no-slip condition, the no-penetration condition, the free-slip condition, and the symmetry condition. Each condition specifies the behavior of the fluid at the boundary surface.
How do boundary conditions affect the flow of an inviscid fluid?
Boundary conditions have a significant impact on the flow of an inviscid fluid. They determine the velocity and pressure distribution at the boundary, which in turn affects the flow and behavior of the fluid in the entire system. Different boundary conditions can result in different flow patterns and behaviors.
What is the difference between boundary conditions for an inviscid fluid and a viscous fluid?
The main difference between boundary conditions for an inviscid fluid and a viscous fluid is that the former assumes zero viscosity, while the latter takes into account the effects of viscosity on the fluid flow. This means that boundary conditions for an inviscid fluid do not consider shear stresses at the boundary, while those for a viscous fluid do.
