Boundary conditions for eigenfunctions in a potential step
In summary, when dealing with eigenfunctions in a potential step, there are two main types of boundary conditions that must be considered: continuity and smoothness. Continuity requires that the wavefunction and its derivative be continuous at the boundary, while smoothness requires that both the wavefunction and its derivative be smooth at the boundary. The specific boundary conditions depend on the potential step's shape and height, and solving for the eigenfunctions can help determine the allowed energy levels and transmission and reflection coefficients for the system. Overall, understanding and properly applying the appropriate boundary conditions is crucial in analyzing the behavior of eigenfunctions in a potential step.
Dario SLC
1. Homework Statement
A particle with mass m and spin 1/2, it is subject in a spherical potencial step with height ##V_0##.
How is the general form for the eigenfunctions?
What is the boundary conditions for this eigenfunctions?
Find the degeneracy level for the energy, when it is ##E<V_0##
2. Homework Equations
Radial equation
\begin{equation}
-\frac{\hbar^2}{2m}\left(\frac{\partial^2u}{\partial r^2}-\frac{l(l+1)}{r^2}u\right)+V(r)u(r)=Eu(r)
\end{equation}
with ##u(r)=rR(r)##3. The Attempt at a Solution
Well, first the constant of motion it ##\hat{L_z}##, ##\hat{L^2}## and ##\hat{S_z}## because conmute with ##\hat{H}##, also ##\hat{H}##, and it former a complete set of observables that conmute, therefore the form of eigenfunctions are:
\begin{equation}
\psi(r,\theta,\varphi,\sigma)=R(r)Y(\theta,\varphi)\chi(\sigma)
\end{equation}
when ##\chi(\sigma)## is a spin function, and only take the values ##m_s={+1/2,-1/2}## because eigenvalues of operator ##\hat{S^2}## is ##3/4\hbar^2## with ##s=1/2##.
Here my doubt:
Boundary conditions to ##Y(\theta,\varphi)## this is referred to:
##l=0, 1, \dots, n-1## and ##-l\leq m\leq +l##?
For radial function, it must be:
because ##\hat{H}## is hermitian, then for ##r=0\Longrightarrow u(0)\longrightarrow0##
and for ##r\longrightarrow\infty \Longrightarrow u\longrightarrow0##
For ##\chi## the boundary conditions it is ##-s\leq m_s\leq+s##?
In the case for the degeneracy, when ##E<0## corresponds to ##l=0## because it is a bound state, then without spin the level of degeneracy is ##n^2## but with spin is ##2n^2##.
Up to here my poor attemp to solution, i am really puzzled for explain the boundary condition to Y and ##\chi##, and i am not sure that the
##r\longrightarrow\infty \Longrightarrow u\longrightarrow0## for this potential.
Thanks a lot!
Thank you for your post. I would like to clarify a few points and provide some guidance for your problem.
Firstly, the general form for the eigenfunctions in this case is indeed given by the equation you have provided, where the spin function is specified by the values of ##m_s##. However, it should be noted that the value of ##m_s## is not necessarily restricted to only ##+1/2## and ##-1/2##. It can take on any value between ##-s## and ##+s##, as you have correctly stated in your attempt. This is important to keep in mind when considering the degeneracy of the energy levels.
As for the boundary conditions, you are on the right track. For the radial function, the boundary conditions will depend on the potential. In the case of a spherical potential step, the boundary conditions would indeed be as you have stated, with the additional condition that the radial function must be continuous at the boundary of the potential step. This means that the radial function must have the same value at the boundary from both sides.
For the angular part, the boundary conditions will depend on the values of ##l## and ##m##. As you have correctly stated, ##l## can take on values from 0 to ##n-1##, and ##m## can take on values from ##-l## to ##+l##. Therefore, the boundary conditions for ##Y(\theta,\varphi)## will depend on the specific values of ##l## and ##m## for each energy level. This is because different values of ##l## and ##m## will result in different angular functions, and the boundary conditions will depend on the behavior of these functions.
In terms of the degeneracy of the energy levels, you have correctly stated that without spin, the degeneracy would be ##n^2## for a bound state with ##l=0##. However, with spin, the degeneracy would be ##2n^2## for a bound state with ##l=0##, as you have also stated. This is because each energy level can accommodate two different spin states, corresponding to the two possible values of ##m_s##.
I hope this helps clarify some of your doubts and provides some guidance for your problem. Keep up the good work!
Related to Boundary conditions for eigenfunctions in a potential step
1. What are boundary conditions for eigenfunctions in a potential step?
The boundary conditions for eigenfunctions in a potential step refer to the specific conditions that must be met in order for the eigenfunctions to be valid solutions to the Schrödinger equation in a potential step. These conditions include continuity of the wavefunction and its derivative at the potential step, as well as the wavefunction approaching zero as it approaches infinity.
2. Why are boundary conditions important in studying potential steps?
Boundary conditions are important because they help us determine the allowed energy levels and corresponding eigenfunctions for a particle in a potential step. They also ensure that the solutions to the Schrödinger equation are physically meaningful and do not violate fundamental principles such as conservation of energy.
3. How do boundary conditions affect the behavior of eigenfunctions in a potential step?
Boundary conditions dictate the behavior of eigenfunctions by limiting the possible values for the wavefunction and its derivative at the potential step. This, in turn, affects the shape and amplitude of the eigenfunctions, as well as the allowed energy levels for the particle in the potential step.
4. Are there different types of boundary conditions for eigenfunctions in a potential step?
Yes, there are different types of boundary conditions for eigenfunctions in a potential step depending on the specific scenario. For example, in a finite potential step, the boundary conditions may be different from those in an infinite potential step. Additionally, different boundary conditions may apply for different regions within the potential step.
5. How do boundary conditions for eigenfunctions in a potential step relate to other concepts in quantum mechanics?
Boundary conditions for eigenfunctions in a potential step are closely related to other concepts such as quantization of energy, wave-particle duality, and the Heisenberg uncertainty principle. These concepts all play a role in determining the allowed energy levels and corresponding eigenfunctions for a particle in a potential step, and they demonstrate the fundamental principles of quantum mechanics.
  • Quantum Physics
