Boundary value problem-find the coefficients
In summary: Thinking)In summary, the boundary value problem given is solved using the method of separation of variables. The solution is of the form $u(x,y)=X(x)Y(y)$ and after substitution, two separate problems are obtained. The eigenvalues and eigenfunctions for each problem are found, and by combining them, the solution for the initial problem is obtained. The solution satisfies the given partial differential equation and boundary conditions, except for $u(x,0)=x$ which needs to be verified further.
mathmari
MHB
5,049
Hey! :eek:
I have to solve the following boundary value problem:
$$u_{xx}+=u_{yy}=0, 0<x<a, 0<y<b$$
$$u_x(0,y)=u_x(a,y)=0, 0<y<b$$
$$u(x,0)=x, u_y(x,b)=0, 0<x<a$$
By using the method of separation of variables, the solution is of the form $u(x,y)=X(x)Y(y)$.
By substituting this it the problem we get the following problems:
$$\left.\begin{matrix}
X''+\lambda X=0, 0<x<a\\
X'(0)=X'(a)=0
\end{matrix}\right\}(1)$$
and
Y''-\lambda Y=0, 0<y<b\\
Y'(b)=0
\end{matrix}\right\}(2)$$
$$u(x,0)=X(x)Y(0)=x$$
Solving the problem $(1)$, the eigenvalues are:
  • $\lambda =0$, with the corresponding eigenfunction $X_0(x)=1$
  • $\lambda =(\frac{n \pi }{a})^2$, with the corresponding eigenfunctions $X_n(x)=\cos{(\frac{n \pi x}{a})}$
So
$$X_n(x)=\left\{\begin{matrix}
1 & ,n=0\\
\cos{(\frac{n \pi x}{a})} & , n=1,2,3, \dots
\end{matrix}\right.$$
By solving the problem $(2)$ we get:
$$Y_n(x)=\left\{\begin{matrix}
A_0 y +B_0 & ,n=0\\
A_n \sinh{(\frac{n \pi y}{a})}+B_n \cosh{(\frac{n \pi y}{a})} & , n=1,2,3, \dots
Then $$Y_n '(x)=\left\{\begin{matrix}
A_0 & ,n=0\\
\frac{n \pi}{a}A_n \cosh{(\frac{n \pi y}{a})}+\frac{n \pi }{a} B_n \sinh{(\frac{n \pi y}{a})} & , n=1,2,3, \dots
$Y'(b)=0 \Rightarrow$
$$A_0 \text{ and } \frac{n \pi}{a}A_n \cosh{(\frac{n \pi b}{a})}+\frac{n \pi }{a} B_n \sinh{(\frac{n \pi b}{a})}=0 \Rightarrow A_n=B_n \tanh{(\frac{n \pi b}{a})}$$
So $$Y_n(x)=\left\{\begin{matrix}
B_0 & ,n=0\\
B_n \tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y}{a})}+B_n \cosh{(\frac{n \pi y}{a})} & , n=1,2,3, \dots
So the solution solution of the initial problem is of the form:
$$u(x,y)=B_0+ \sum_{n=1}^{\infty}{B_n[ \tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y}{a})}+ \cosh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$
$$u(x,0)=x \Rightarrow B_0+ \sum_{n=1}^{\infty}{B_n \cos{(\frac{n \pi x}{a})}}=x$$
To find the coefficients $B_0$ and $B_n$, can I use the expansion of $x$ to the eigenfunctions of the problem, although $x$ does not satisfy the boundary conditions of the problem? (Wondering)
Hey! :eek:
Yes.
Actually, $x$ does satisfy the boundary conditions, namely for $y=0$, which is what this condition is about.
I meant that $x$ does not satisfy the boundary conditions of the problem $(1)$ and at the expansion of $x$ to the eigenfunctions of the problem, the eigenfunctions are from the problem $(1)$.
So, do I have to do the following? (Wondering)
$$B_0=\frac{2}{a} \int_0^a{x}dx= 2a$$
$$B_n=\frac{2}{a} \int_0^a{x \cos{(\frac{n \pi x}{a})}}dx= \dots =\frac{2a}{n^2 \pi^2} [ (-1)^n-1]$$
But we're not looking at the solution for X from (1) anymore. :confused:
We're looking at the combined solution for the original problem, and then zooming in at $y=0$ to ensure the corresponding boundary condition is satisfied.
How about verifying if this gives you a solution of the original problem? (Mmm)
I found that
$$u(x,y)=2a +\sum_{n=1}^{\infty}{\frac{2a}{n^2 \pi^2}[(-1)^n-1] [\tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y }{a})}+\cosh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$
So the partial derivatives are:
$$u_x(x,y)=-\sum_{n=1}^{\infty}{\frac{2}{n \pi}[(-1)^n-1] [\tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y }{a})}+\cosh{(\frac{n \pi y}{a})}] \sin{(\frac{n \pi x}{a})}}$$
$$u_{xx}(x,y)=-\sum_{n=1}^{\infty}{\frac{2}{a}[(-1)^n-1] [\tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y }{a})}+\cosh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$
$$u_y(x,y)=\sum_{n=1}^{\infty}{\frac{2}{n \pi}[(-1)^n-1] [\tanh{(\frac{n \pi b}{a})} \cosh{(\frac{n \pi y }{a})}+\sinh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$
$$u_{yy}(x,y)=\sum_{n=1}^{\infty}{\frac{2}{n \pi}[(-1)^n-1] [\tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y }{a})}+\cosh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$$$u_{xx}+u_{yy}=0 \checkmark$$
$$u_x(0,y)=u_x(a,y)=0 \checkmark$$
But are the conditions $u(x,0)=x$ and $u_y(x,b)=0$ satisfied? (Wondering)
$u(x,0)=2a+\sum_{n=1}^{\infty}{\frac{2a}{n^2 \pi^2}[(-1)^n-1] \cos{(\frac{n \pi x}{a})}} \overset{?}{=} x$ (Wondering)
mathmari said:
I found that
Nice! $\checkmark$ (Sun)
Hmm...
Let's see...
Suppose we pick $a=3$ and we expand 3 terms...
Then W|A gives us this graph.
Hmm... I think it is not quite right yet... (Doh)
But I do think it is possible!
(Yes)
I like Serena said:
Hmm...
Let's see...
So is the solution that I have found wrong? (Wondering)
I think so.
Your general solution is correct, but your values for $B_n$ appear to be wrong.
How did you come up with the formulas that you have? (Wondering)
I like Serena said:
I think so.
Is the following form of the solution right?
Then by the boundary condition we have that:
So $$B_0=\frac{2}{a} \int_0^a{x}dx=2a$$
$$B_n=\frac{2}{a} \int_0^a{x \cos{(\frac{n \pi x}{a})}}dx= \dots = \frac{2a}{n^2 \pi^2}[(-1)^n-1]$$
Have I done something wrong at the calculation of the coefficients? (Wondering)
Or do we not calculate the coefficients in this way??
All good! (Nod)
The formulas for these coefficients are indeed wrong.
I know 2 ways to calculate them.
The Fourier cosine series or the dot products with the base functions.It seems you have attempted to do the latter, so let's recap that method. (Nerd)
If you have an orthogonal basis $\{ \vec u_i \}$ and you want to represent a vector $\vec a$ in it, the representation is given by:
$$\vec a = \sum \frac {(\vec a, \vec u_i)}{(\vec u_i, \vec u_i)} \vec u_i$$
Note that it is easier if the basis vectors have norm 1, since in that case the denominators disappear. However, your eigenfunctions do not have norm 1.Now let's apply that to your problem:
$$B_0 = \frac{(x, 1)}{(1, 1)}
= \frac{\int_0^a x\cdot 1 \ dx}{\int_0^a 1\cdot 1 \ dx}
= \frac {\frac{a^2}{2}} {a}
= \frac a 2$$
Hey! That is different from what you have! (Crying)
I like Serena said:
All good! (Nod)
Great! (Smile)
= \frac a 2$$
You're right! (Blush)
I had also an error at the integral of $B_0$. (Tmi)
Actually, I calculated them using the Fourier cosine series.
We expand $f(x)=x$ in an even way at $[-a,a]$.
So we can write $f(x)$ as a Fourier series $$f(x)=\frac{a_0}{2}+ \sum_{n=1}^{\infty}{a_n \cos{(\frac{2 n \pi x}{2a})}}, a_n=\frac{2}{2a} \int_{-a}^a{f(x) \cos{(\frac{2 n \pi x}{2a})}}dx= \frac{2}{a} \int_0^a{f(x) \cos{(\frac{n \pi x}{a})}}dx$$
$$a_0=\frac{2}{a} \int_0^a{x}dx=a \Rightarrow B_0=\frac{a_0}{2}=\frac{a}{2}$$
And what's about $B_n$?? (Wondering)
mathmari said:
Great! (Smile)
$u(x,0)=x$ is satisfied since by this relation we have found the coefficients $B_0$ and $B_n$, right?
$$u_y(x,b)=0 \Rightarrow \sum_{n=1}^{\infty}{\frac{2}{n \pi} \cdot [(-1)^n-1] \cdot 2 \sinh{(\frac{ n \pi b}{a})} \cdot \cos{(\frac{n \pi x}{a})}}=0$$
But does this relation stand?? (Wondering)
The $B_n$ are correct. (Smile)
We can see the verification in this W|A graph.
Well... uhm... I don't know yet...
At first sight, it seems it does not stand... (Doh)
I found the mistake...
The solution is:
$$u(x,y)=\frac{a}{2} +\sum_{n=1}^{\infty}{\frac{2a}{n^2 \pi^2}[(-1)^n-1] [-\tanh{(\frac{n \pi b}{a})} \sinh{(\frac{n \pi y }{a})}+\cosh{(\frac{n \pi y}{a})}] \cos{(\frac{n \pi x}{a})}}$$
I forgot the sign $'-'$.. (Lipssealed)
Now the condition $u_y(x,b)=0$ is satisfied.. (Sun)
So since the conditions are satisfied the solution is correct, isn't it ?? (Wondering)
The solution is:
It looks that way! (Party)
Ok! Thanks a lot! (Handshake)
FAQ: Boundary value problem-find the coefficients
What is a boundary value problem?
A boundary value problem is a type of mathematical problem that involves finding a solution to a differential equation subject to certain conditions at the boundaries of the domain. These conditions are known as boundary conditions and are typically given as values or relationships that the solution must satisfy at specific points.
How do you find the coefficients in a boundary value problem?
To find the coefficients in a boundary value problem, you first need to identify the differential equation and boundary conditions involved. Then, you can use various techniques such as separation of variables, variation of parameters, or the method of undetermined coefficients to solve the equation and determine the values of the coefficients.
What is the significance of finding the coefficients in a boundary value problem?
The coefficients in a boundary value problem represent the characteristics of the solution to the differential equation. They can provide important information about the behavior and properties of the solution, such as its stability, convergence, and uniqueness. Finding the coefficients is crucial in understanding and solving many real-world problems in fields such as physics, engineering, and economics.
What are some common techniques for solving boundary value problems?
Some common techniques for solving boundary value problems include the shooting method, finite difference method, finite element method, and Laplace transform method. Each method has its own advantages and is suitable for different types of problems. It is important to choose the appropriate method based on the problem at hand.
Can boundary value problems have more than one solution?
Yes, boundary value problems can have more than one solution. This is known as the existence of multiple solutions. The number of solutions can depend on the boundary conditions, the type of differential equation, and the domain of the problem. It is important to carefully analyze the problem and its conditions to determine the existence and uniqueness of the solution.
