Bounded Monotonic Sequence Theorem
In summary: So, in summary, to use the Bounded Monotonic Sequence Theorem, the sequence must be bounded and monotonic. In this case, the sequence is bounded by a lower bound of 0 and is monotonic increasing, therefore it is convergent.
Euler2718
90
[/B]
Use the Bounded Monotonic Sequence Theorem to prove that the sequence:
[tex] \{a_{i} \} = \Big\{ i - \sqrt{i^{2}+1} \Big\} [/tex]
Is convergent.
[/B]
I've shown that it has an upper bound and is monotonic increasing, however it is to my understanding that for me to use this theorem the sequence must be bounded (and of course have monotonicity) - i.e. have an upper and lower bound. I can't seem to show that this has a lower bound; even graphically, it just blows off to negative infinity. How should I proceed?
Morgan Chafe said:
[/B]
Is convergent.
[/B]
Why do you think this? You didn't say anything about the possible values of i, but I assume they are positive integers {1, 2, 3, ...}.
Consider ##f(x) = x - \sqrt{x^2 + 1}##. All of the values of this function are negative, since ##x < \sqrt{x^2 + 1}## for all x > 0. As x gets larger, the difference is smaller, and approaches zero. The largest difference comes when x is smallest (i.e., closest to zero).
Likes Euler2718
Morgan Chafe said:
[/B]
Is convergent.
[/B]
If ##f(i) = i -\sqrt{i^2+1}## is monotonically increasing, then ##f(1) < f(2) < f(3) < \cdot##, so if ##f(1)## is a finite number, it is a lower bound!
Likes Euler2718
Thank you, I think I got it now.
Related to Bounded Monotonic Sequence Theorem
What is the Bounded Monotonic Sequence Theorem?
The Bounded Monotonic Sequence Theorem, also known as the Monotone Convergence Theorem, states that a bounded monotonic sequence, meaning a sequence that is either increasing or decreasing and has an upper and lower bound, will converge to a limit.
How is the Bounded Monotonic Sequence Theorem used in mathematics?
The Bounded Monotonic Sequence Theorem is an important tool in mathematical analysis and is used to prove the convergence of sequences in various mathematical concepts, such as calculus and real analysis.
Can you provide an example of a bounded monotonic sequence?
Sure, one example of a bounded monotonic sequence is an = 1/n. This sequence is bounded between 0 and 1, and is also monotonically decreasing as each term is smaller than the previous one. This sequence converges to a limit of 0.
What is the significance of the Bounded Monotonic Sequence Theorem?
The Bounded Monotonic Sequence Theorem is significant because it provides a powerful tool for mathematicians to prove the convergence of sequences, which is crucial in many mathematical proofs and applications.
Is the Bounded Monotonic Sequence Theorem always true?
Yes, the Bounded Monotonic Sequence Theorem is always true for any bounded monotonic sequence. However, it is important to note that the theorem only applies to sequences in real analysis and may not hold true in other mathematical contexts.
