ELESSAR TELKONT
- 44
Let [tex]1\leq r<\infty[/tex] and [tex]x\in\ell_{r}=\left\{ x \text{ is a sequence with } \sum_{n=1}^{\infty}\left\vert x_{n}\right\vert^{r} \text{ converges.}\right\}[/tex], then
[tex]\left\vert\left\vert x\right\vert\right\vert_{\infty}=\lim_{r\rightarrow\infty}\left\vert\left\vert x\right\vert\right\vert_{r}[/tex]
I have already proven that for [tex]1\leq s\leq r\leq\infty[/tex] I can bound below by [tex]\left\vert\left\vert x\right\vert\right\vert_{\infty}\leq \left\vert\left\vert x\right\vert\right\vert_{r}[/tex]. The other part wher I'm stuck is to bound above the r-norm. I haven't found something to do it. Obviously, the case for [tex]\mathbb{R}^{n}[/tex] (the finite case if you considere the sequences case as "infinituples") is solved because you have something to do a bounding almost immediatly since
[tex]\sum_{i=1}^{n}\left\vert x_{n}\right\vert^{r}=\left\vert\left\vert x\right\vert\right\vert_{r}^{r}\leq\sum_{i=1}^{n}\left\vert x_{m}\right\vert^{r}=n\left\vert x_{m}\right\vert^{r}=n\left\vert\left\vert x\right\vert\right\vert_{\infty}^{r}[/tex]
Obviously in sequences case [tex]n[/tex] makes not sense, and approximation like i have done above is not possible because a series of a constant sequence don't converge.
Proving what I can't prove the result of the problem follows immediatly because of the "Sandwich theorem" since if I have some quantity bounded above and below like this
[tex]\left\vert\left\vert x\right\vert\right\vert_{\infty}\leq\left\vert\left\vert x\right\vert\right\vert_{r}\leq c^{\frac{1}{r}}\left\vert\left\vert x\right\vert\right\vert_{\infty}[/tex] with [tex]c>0[/tex] and [tex]c\in\mathbb{R}[/tex]
and if I take the limit when [tex]r\rightarrow\infty[/tex] then
[tex]\left\vert\left\vert x\right\vert\right\vert_{\infty}\leq\lim_{r\rightarrow\infty}\left\vert\left\vert x\right\vert\right\vert_{r}\leq \left\vert\left\vert x\right\vert\right\vert_{\infty}[/tex]
Then I would like you to say some ideas to do bounding above.
