B Box being pulled up a slope with friction
The discussion focuses on analyzing the forces acting on a box being pulled up a slope with friction. It emphasizes that the direction of the friction force is always opposite to the movement, which complicates the scenario when an external force is applied. To determine the box's motion, one must calculate the net force and consider conditions for static and kinetic friction. A universal equation can be formulated by treating the friction force as an unknown variable, allowing for a systematic approach to solving the problem. This method involves static analysis to find the friction force required to prevent motion and comparing it to the maximum static friction available.
alikim
If I solve a problem of a box sliding down a slope or standing still on the slope, the force of friction is directed up along the slope.
What happens if there is a force F pulling the box up along the slope, but it's unknown if it overcomes gravity and box is moving up or it only slows the box down and it is still sliding down.
Since the force of friction is directed opposite the movement, is it directed up or down?
If the box is moving down:
ma = mg sinθ - F - μmg cosθ, a >= 0
If the box is moving up:
ma = mg sinθ - F + μmg cosθ, a < 0
Is there a way to write one "universal" equation to solve? Or do I check a conditions first, and then choose which equation to use?
You have to calculate the net force to determine the direction in which motion is possible, before including the forces that resist motion.
You have to solve the problem in two stages. Note that there is the intermediate case where the net force is insufficient to overcome friction, in which case the box remains at rest; and, the friction force is not the maximum.
Moreover, it's often the case that the coefficient of static friction is greater than the coefficient of kinetic friction, which adds another layer of complexity - and another step in the solution.
Initially assume the box has zero acceleration and the friction is an unknown quantity. Solve for the friction force using the equations of statics. This is the friction force needed to prevent slip. Its sign will tell you which way the friction force has to point. if the magnitude of this force is greater than the max friction available then do a sliding analysis with the max friction available but pointing in the direction you just found.
Write the general equation with the friction force input as unknown variable eg F_f. It does not matter which way F_f points as it is an algebraic variable that can have a + or - value. Perform a static analysis with all derivatives =0. Solve this equation for F_f. The answer will be the friction force needed to prevent motion. If the answer is positive you drew it in the correct direction on your FBD. If negative it points the other way. Take the absolute value of F_f and compare with mu R. If less than mu_static R the block sticks of greater, set F_f to +- mu_static R and solve the time dependent problem. This methodology applies to all friction problems.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
