Box resting on an inclined plane
In summary, the question asks for the smallest force that can be applied to keep a 22kg box at rest on a 45 degree inclined ramp with a coefficient of static friction of 0.78. The relevant equations are F=ma and Fs=(mu static)(Fn). The solution involves finding Fgy and using it to calculate F n , which is equal to Fgx divided by the coefficient of static friction.
JamesW
A box with a mass of 22kg is at rest on a ramp inclined at 45 degrees to the horizontal. The coefficient of static friction is 0.78
determine the magnitude of the smallest force that can be applied onto the top of the box, perpendicular to the ramp if the box is to remain at rest?
F=ma
F f (static friction) + Fgx = 0
F n = Fgy + F a
Fa = F n - Fgy
I have viewed a thread and to calculate F n (normal force) they divided Fgx/mu static. I was wondering why this was?
WHY IS Fn = Fgx/ mu static ?
because Fs=(mu static)(Fn)
which is valid if friction _exactly_ cancels "g sin theta" ...
I would like to clarify that the equations and approach used in the attempt at a solution are correct. The normal force (F n) is equal to the weight of the box (Fgy) plus any additional forces acting on the box (Fa). In this case, the only additional force is the force applied perpendicular to the ramp, which is what we are trying to find.
The reason for dividing by the coefficient of static friction (mu static) is to account for the friction force that is present on the ramp. The normal force is the perpendicular force exerted by the ramp on the box to counteract the weight of the box and any other forces acting on it. The coefficient of static friction represents the maximum amount of friction that can be present before the box starts to slide down the ramp. By dividing by this coefficient, we can ensure that the normal force is enough to counteract the weight and the friction force, thus keeping the box at rest.
In summary, dividing by the coefficient of static friction is necessary to accurately calculate the normal force and determine the smallest force that can be applied to the box to keep it at rest on the inclined plane.
Related to Box resting on an inclined plane
1. What is an inclined plane?
An inclined plane is a flat surface that is at an angle or slope. It is commonly used to make it easier to move objects up or down by reducing the amount of force needed.
2. How does the position of a box on an inclined plane affect its motion?
The position of a box on an inclined plane affects its motion by changing the direction and speed of its movement. The steeper the incline, the faster the box will accelerate downwards, and the slower it will move upwards.
3. What forces act on a box resting on an inclined plane?
The forces acting on a box resting on an inclined plane are the weight of the box, the normal force from the surface of the inclined plane, and the force of friction. The weight of the box acts downwards, while the normal force and friction act perpendicular and parallel to the incline, respectively.
4. How do the forces on a box change as the angle of the inclined plane changes?
As the angle of the inclined plane changes, the forces acting on the box also change. The weight of the box will remain constant, but the normal force will decrease as the angle decreases, and the force of friction will increase as the angle increases.
5. What is the relationship between the angle of the inclined plane and the force required to move the box?
The force required to move a box on an inclined plane is directly proportional to the angle of the incline. As the angle increases, the force needed to move the box also increases. This is due to the increased weight component acting along the incline, making it more difficult to overcome the force of friction.
