nmsurobert
- 288
- 36
When using a Boyle's Law Apparatus, pressure applied to the plunger can be calculated by knowing the mass of the object on the plunger and the area of the plunger. P = F/A.
The change of pressure inside the cylinder can be calculated using Boyles Law, P1V1 = P2V2
Should the value for the pressure applied to the top of the plunger be the same as P2, the pressure of the gas in the cylinder once the plunger has been compressed? should P2 = F/A ?
I did some math and math shows that they aren't equal. they're close, but not the same. however, i don't know if they should be equal under ideal conditions. using P = F/A, that value is slightly larger than using P2 = (P1V1)/V2
